		Thom Riddle
				 Posted: Thu Oct 05, 2006 4:22 am    Post subject: Vamoose' Ex-Reduction DriveVamoose' Ex-Reduction Drive |
				Big Lar,
 Thanks for the great photos. ALWAYS enjoy them.
 I sure hope you get your speed reducer situation fixed so you can do
 your own flight-seeing. I know a direct drive is not going to give you
 the performance you want but if you did that as an interim solution
 while you saved your pennies for a good speed reducer, at least you
 would be able to fly. Of course if your density altitude is too high or
 your runway too short then that might not work. Just a thought.
 Thom in Buffalo
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		biglar
				 Posted: Thu Oct 05, 2006 5:14 am    Post subject: Vamoose' Ex-Reduction DriveVamoose' Ex-Reduction Drive |
				Thanks, Thom.  I just wish I had more time to take those pictures.  Full
 time would be nice.  lol   Someday.......??
 Me being me, if the plane was flying as a direct drive, procrastination
 would probably delay further work indefinitely.       The biggest thing
 against that, tho', is lower performance in an area known for huge density
 altitude compensations, and the Palm Springs area is partly surrounded by
 huge mountains, and the remaining areas are mostly MOA's.
 Lar.                      Do not Archive.
 Larry Bourne
 Palm Springs, CA
 Building Kolb Mk III
 Vamoose
 www.gogittum.com
  _________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
				 Posted: Thu Oct 05, 2006 6:49 am    Post subject: Vamoose' Ex-Reduction DriveVamoose' Ex-Reduction Drive |
				Lar/All
 It isn't all that bad. I flew for four years with a direct drive VW. With a
 direct drive engine a MKIII will be a single place airplane and it will
 cruise app 10 mph slower but it is real smooth. The problem Lar would have
 is that his engine wouldn't make a good direct drive engine and his engine
 mount holds the engine in the wrong direction. Direct drive engines need to
 have a modified case and crank that allows for a extra large bearing on the
 pulley end to handle prop loads.
 Rick Neilsen
 Redrive VW powered MKIIIc
