Compressor Issues
Tim Gagnon
PostPosted: Fri Oct 06, 2006 5:00 am    Post subject: Compressor Issues Reply with quote
So I take off and am flying along when I do an instrument check and my primary pressure is not moving. Not going down and certainly not going up! I turn around, head back to the airport and land without incident. Taxing in I am using air that is not being replenished.
Pull the "output" line off the snot valve, have a brave mechanic put his finger over the port and crank the engine....nothing! So, I have a compressor that is Tango Uniform.
I have been told that the coupling could be inop and could replace just that instead of the whole pump. I am in need of either.......sources??
Thanks in advance.
ReadeG(at)Cairnwood.com
PostPosted: Fri Oct 06, 2006 5:23 am    Post subject: Compressor Issues Reply with quote
Tim:
Take the filter off the top of the compressor and while pulling prop through
determine if valve at the top of the compressor is moving - if it is then
you can replace the "top" or compressor alone. If the there is no movement
of the piston then you've probably sheared the drive coupling and have to
replace the right angle drive assembly.
I've done both - the former is a little easier, the latter requires lots of
patience and Gumby like agility with offset angle wrench. You have to
remove a bunch of stuff to get decent access -
Call me for the details if you want -
Reade
215.914.0370
[quote] --
dsavarese(at)elmore.rr.co
PostPosted: Fri Oct 06, 2006 5:34 am    Post subject: Compressor Issues Reply with quote
Tim,
Before you pull the compressor, remove the output check valve from the
compressor, clean it thoroughly and make sure the little "valve" is able to
move with the spring pressure. If the output check valve is carboned up and
the little valve is stuck, then you may have sheared the shear coupling.
Reinstall and test again for output. Did you check the line going into the
"snot" bottle for air from the compressor or did you check the output of the
snot bottle? I have seen the snot bottle so blocked up that it would not
allow the air to pass through it. It's not bad idea to pull the snot
bottle and flush it out every year or two.
Dennis
Tim Gagnon
PostPosted: Fri Oct 06, 2006 4:33 pm    Post subject: Re: Compressor Issues Reply with quote
Dennis,
I have done what you suggested and think it is a no $hit compressor issue. I did get some gunk cleaned out of the check valve and snot valve.
Reade, I may indeed call you for some suggestions. I looked at who to get that thing off and if I were six inches tall with 11mm hands, I would be golden..but.....
If all else fails, I will take my .40 cal with me to the airport.
Anyone know of a source for parts for these things or is it recommended to get the whole thing overhauled? The airplane is 22 years old and has had a rough life...until now. I want this to be done right.
PostPosted: Sat Oct 07, 2006 3:55 am    Post subject: Compressor Issues Reply with quote
Tim,
I'm not sure if Carl/Jill can overhaul your compressor. But it certainly
wouldn't hurt to ask. I believe Doug Sapp, Carl/Jill may have them in stock
as well as Steve Culp of Culps Specialties in Shreveport, LA. Steve
advertises on Ebay with a lot of M14 parts including compressors. Steve
may also have the shear couplings in stock.
Dennis
Tim Gagnon
PostPosted: Sat Oct 07, 2006 11:29 am    Post subject: Re: Compressor Issues Reply with quote
This thing is a mofo to get off. I will have to slam the Russians for this one. A bitch of a part surrounded by a fine airplane.
I have three nuts off and feel like I have been kicked in mine. I have to step away and took another look at this.....
viperdoc(at)mindspring.co
PostPosted: Sat Oct 07, 2006 3:14 pm    Post subject: Compressor Issues Reply with quote
Hope you have the Russian tool kit or your gonna some really bad names and
that is not going to help either. Dennis has done that I count 3 or is it 4
times now.
Doc
[Original Message]
To: <yak-list(at)matronics.com>
Date: 10/7/2006 2:37:05 PM
Subject: Re: Compressor Issues
http://forums.matronics.com/viewtopic.php?p=66408#66408
PostPosted: Sat Oct 07, 2006 4:21 pm    Post subject: Compressor Issues Reply with quote
More than that Doc.
Dennis
PostPosted: Sat Oct 07, 2006 4:30 pm    Post subject: Compressor Issues Reply with quote
Personally, I think it's the worse job in the engine compartment.
Dennis
Tim Gagnon
PostPosted: Sat Oct 07, 2006 4:33 pm    Post subject: Re: Compressor Issues Reply with quote
dsavarese(at)elmore.rr.co wrote:
More than that Doc.
Dennis
I am all ears....and busted knuckles.
Any advice....what other items to take off to make it easier, methods of removal...stuff like that. Or you could always come up and I could learn from the master! A cold beer awaits....
mark.bitterlich(at)navy.m
PostPosted: Wed Oct 11, 2006 1:51 pm    Post subject: Compressor Issues Reply with quote
Think so? Pull the starting air distributor off, and then try to put it
back on and get it to work again.
Mark
PostPosted: Wed Oct 11, 2006 2:02 pm    Post subject: Compressor Issues Reply with quote
By this time, I guess you have for sure determined that it is indeed
the compressor that is bad. Normally, it is either the banjo fitting
leaking, or the line going from the compressor banjo fitting to the snot
valve itself that has failed.
The best method to determine this is to remove the line from the snot
valve and reverse pressurize the line from some high pressure source.
You can then hear where the leak is coming from and fix it.
9 times out of 10, it is NOT the compressor.....
Mark Bitterlich
N50YK
PostPosted: Wed Oct 11, 2006 6:15 pm    Post subject: Compressor Issues Reply with quote
You're right Mark. You win!
Dennis
