shirleyh
Joined: 05 Jun 2006 Posts: 15 Location: Perth, Western Australia
Posted: Sat Oct 07, 2006 1:45 am Post subject: Applying cowl heat shield material |
Listers - during the test period on my RV6 I noticed scorch marks on the lower cowl. I've ordered the cowl heat shield material from Vans. Are there any tips from those who have already done it regarding the best way to apply it? I'm thinking about surface preparation of the cowl to ensure good adhesion and techniques for smooth application.
All advice gratefully accepted.
Shirley in Perth, Western Australia
Tim(at)MyRV10.com Guest
Posted: Sat Oct 07, 2006 4:54 am Post subject: Applying cowl heat shield material |
No scorch marks from this method yet...
Degrease and sand the inside of the cowl lightly.
Mix up some West Systems or similar epoxy.
Brush the epoxy on the inside of the cowl all
over the place. Then just peel/apply/trim the
heat shield material and you're done. It's self-stick
if you got the same I did. I have good adherence
pretty much everywhere except one spot where I didn't
get quite enough degreasing done.
shirleyh wrote:
http://forums.matronics.com/viewtopic.php?p=66321#66321
rv8(at)lazy8.net Guest
Posted: Sat Oct 07, 2006 5:56 am Post subject: Applying cowl heat shield material |
Shirley
If you just do a good job of degreasing it will stick fine. The problems
come in that the stuff will not stretch at all, so you have to cut it
into pieces to make it conform to the compound curves of the cowl.
Mine has been fine for 3 years or so now.
John
shirleyh wrote:
Hopperdhh(at)aol.com Guest
Posted: Sun Oct 08, 2006 5:42 am Post subject: Applying cowl heat shield material |
In a message dated 10/7/2006 5:49:12 A.M. Eastern Daylight Time, shirleyh(at)oceanbroadband.net writes:
| Quote: | --> RV-List message posted by: "shirleyh" <shirleyh(at)oceanbroadband.net>
Shirley,
Just clean the cowl good. I used MEK but anything that will cut oil would probably be OK. Put it on in several pieces starting at the bottom like you would if you were roofing so it will shed all the oil that leaks out of your engine (grin). Where the compound curves are you need smaller or narrower pieces so that it won't try to bunch up too much. Don't try to make it look perfect! Just cover anything that is near the exhaust. It is really easier to do than to talk about.
Dan Hopper
RV-7A
Posted: Sun Oct 08, 2006 5:47 am Post subject: Applying cowl heat shield material |
I forgot to mention to coat the inside of the cowl with epoxy thinned with acetone like Vans manual says to. Brush it in good to fill the pinholes -- mainly for the areas that won't get the heat shield.
Dan Hopper
RV-7A
