Joel
Joined: 06 Oct 2006 Posts: 57 Location: Bremerton, WA USA
Posted: Sun Oct 08, 2006 7:15 am Post subject: Seat pan covering |
We are about to begin covering the fiberglass seat pan of our model 5 and
have seen some other Kitfox seats where fabric was bonded to the seat pan
near the edges and over the 'hump'. Any recommedations on what to use to
glue the fabric in place?
Joel
Model 5 912 GTA CS prop Aerocomp amphibs
Express yourself - download free Windows Live Messenger themes!
http://clk.atdmt.com/MSN/go/msnnkwme0020000001msn/direct/01/?href=http://imagine-msn.com/themes/vibe/default.aspx?locale=en-us&source=hmtagline
_________________ Joel Mapes Kitfox 5 912 ULS Aerocomp amphibs |
ddsyverson(at)comcast.net Guest
Posted: Sun Oct 08, 2006 7:32 am Post subject: Seat pan covering |
Joel,
Go to the fabric store and ask for some spray on adhesive for this purpose.
Just about any fabric store will have this stuff. This is the best way to go.
I have also used gorilla snot (commonly known as "contact cement" used for
things like gluing down formica) for gluing down edges of fabric to hard
surfaces; BUT, and I mean BIG BUT on this one - many of the man made fabrics
and fabric backings dissolve in the solvents used in this stuff, while it
works real well for cotton & wool. - also - it does not come in a spray form
and the water based products are basically worthless in the long run. If you
use this it has to be brushed on and only get the kind with the stinky
solvents if you want it to last.
Dave
On Sunday 08 October 2006 10:14 am, Joel Mapes wrote:
Joel
Float Flyr
Posted: Sun Oct 08, 2006 5:27 pm Post subject: Seat pan covering |
There is also an acid free spray contact cement that you will find at photo
shops... My experience with the stuff is it may dry our and separate in a
couple of years.
I've had limited success with carpet tape and two sided foam tape. The best
part of this stuff is it sticks well and is easy to replace if it comes
unstuck. What I've found to be totally useless is any hot glue... If it
ever sticks it will release with in a couple of weeks.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
tc9008(at)aol.com Guest
Posted: Mon Oct 09, 2006 3:35 am Post subject: Seat pan covering |
I used velcro strips
Travis
