trc1917(at)direcway.com Guest
Posted: Sun Jan 01, 2006 4:26 am Post subject: funnel |
I have had same weird experience with the byproduct of pouring fuel through
a mister funnel. I used to use a rite mix messuring cup and after dumping
the oil in the can, would rinse it with gas. Often, it would leave a white,
milky, paste behind. My guess is it is doing it in the mr funnel bottom
also. always made me wonder if it was doing it in the bottom of my tank but
never found any. never killed an engine with it though. ted cowan, alabama
ulpilot(at)cavtel.net Guest
Posted: Sun Jan 01, 2006 5:33 am Post subject: funnel |
All
When I bought my Firestar in 99, the owner told me he had not drained and
cleaned the fuel tank for a year and it needed cleaning. Well, I did not
heed his word and clean the tank. I had 4 engine outs, 2 on take off, 1 on
down wind and 1 on base.
I kept thinking it was the carb but couldn't find the problem. I finally
decided to clean the tank and found the same milky, white, gooey paste in
the bottom of the tank right next to the fuel pick up. I could start the
engine, do my run up, but the minute I took off with the up angle the paste
would cover the fuel pick up and stop my fuel flow. By this time, I would
be about 2 hundred feet in the air and the engine would stop. Fortunately,
I had plenty of runway in front of me for a power off landing.
I replaced the tank, fuel tubing, fuel pump and carb. This cured the
problem and I made it part of my regular maintenance to drain and clean my
tank every 6 months.
Jim Ballenger
MK III X 582
Virginia Beach, VA
kfackler(at)ameritech.net Guest
Posted: Sun Jan 01, 2006 8:05 am Post subject: funnel |
| Quote: | >I made it part of my regular maintenance to drain and clean my tank every
6 months. |
How do you clean them?
-Ken Fackler
Kolb Mark II / A722KWF
Rochester MI
DAquaNut(at)aol.com Guest
Posted: Sun Jan 01, 2006 8:24 pm Post subject: funnel |
