Noel
Joined: 13 Jan 2006 Posts: 21 Location: Montreal, Qc, Canada
Posted: Tue Oct 10, 2006 11:35 am Post subject: New 6 Gals. tanks |
Hell all !
I have installed 2 new gas tanks bought from TNK co.
and wanted to share my findings with the group ...
These are the new 6 US gallons ones. The first thing i noticed
is that they are made of a quite thin plastic ... much thinner than
what i had before.
After fitting the pickup fitting i changed all the fuel
lines to black auto fuel line. I use a type made by Gates which their
catalog says it is suitable for gaz "and other petoleum distilates"
A friend of mine used exactly the same type of lines on it's 582 without
any poblem and the lines we're as strong after 5 years ...
On the clearance side ... The thanks are about 2 inches taller ...
it is a tight fit in my Twinstar Mk II but the thank do not interfere
with the aileron controls ... but the starting rope rubs a bilt against
the
thank near the cap which may cause a problem in the long run ...
I may have to fit some sort of guide to avoid this ...
Overall, i am quite pleased by the result having gained 2 gallons or a good
40 minutes more endurance with my 503 DC ...
I just hope the tank will prove to be stong enough over time ...
Noël
Twinstar MK II
Arty Trost
Joined: 25 May 2006 Posts: 206 Location: Sandy, Oregon
Posted: Tue Oct 10, 2006 1:40 pm Post subject: New 6 Gals. tanks |
Noel -
Would you post info about TNK - how to contact them as
well as the item # for the tanks? Also, what color
are the tanks? The standard red, or opaque white
or...?
Arty
--- Noel Bouchard <noel(at)teledata.qc.ca> wrote:
Hell all !
thing i noticed
much thinner than
what i had before.
fuel
Gates which their
on it's 582 without
years ...
inches taller ...
rubs a bilt against
the
long run ...
over time ...
Noël
Twinstar MK II
browse
Subscriptions page,
FAQ,
Web Forums!
Admin.
www.LessonsFromTheEdge.com
"Life's a daring adventure or nothing"
Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Tue Oct 10, 2006 2:00 pm Post subject: Re: New 6 Gals. tanks |
"O" Noel, you didn't have the "O" in "Hello". They would eat you for lunch, for such a discrepancy.
You are 100 % correct on the gas tank wall thickness. It still works well even when flipped over with plane, as I have done. The walls do vacuum in a bit when they drain at high speed (as in pumped out with Facet pump directly to a reserve tank, no resistance). But they hold up quite well. I believe they can use that tank because the wall interiority is connected to the fact that they are contained within a structure and have a metal frame around them, as in my Firestar.
The bottom wall is a bit thinner than I would like as I use both the Facet and the Rotax mechanical pump discharging from the bottom, verses the strainer suction weighted tube hanging down inside. At least for me, the rubber expansive inserts work well and have held up without leaking. Even when I inverted my Kolb abruptly with a full tank.
You might want to apply a trick that Planecrazzy used to draw air from a point lower than the tank. You would then have to close off any air intake on top or in the cap and use a hole, possibly in that small nozzle with the cap on the other side of the top. No one thinks of being inverted until they are. But the other good side of the tube going below is that rain and splashed weather won’t enter your tank
Ohio Ralph
Ralph Hoover
Posted: Tue Oct 10, 2006 2:08 pm Post subject: Re: New 6 Gals. tanks |
Sorry, I meant to say "integrity !
Ohio Ralph
DO NOT ARCHIVE!
Noel
Posted: Tue Oct 10, 2006 4:39 pm Post subject: New 6 Gals. tanks |
Noel
Posted: Tue Oct 10, 2006 4:46 pm Post subject: New 6 Gals. tanks |
Noel
Posted: Tue Oct 10, 2006 5:48 pm Post subject: New 6 Gals. tanks |
Richard Pike
Posted: Tue Oct 10, 2006 6:19 pm Post subject: New 6 Gals. tanks |
Frustrating, isn't it?
Richard Pike
MKIII N420P (420ldPoops)
(do not archive) <grin>
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Noel
Posted: Wed Oct 11, 2006 4:31 am Post subject: New 6 Gals. tanks |
Noel
Posted: Wed Oct 11, 2006 4:32 am Post subject: New 6 Gals. tanks |
noelbou(at)cam.org Guest
Posted: Wed Oct 11, 2006 6:13 am Post subject: New 6 Gals. tanks |
Posted: Wed Oct 11, 2006 6:30 am Post subject: New 6 Gals. tanks |
Noel
Are you a politician? You keep talking but you aren't saying very much.
Your posts have been working. What are you doing different?
Rick Neilsen
Redrive VW powered MKIIIc
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Wed Oct 11, 2006 6:41 am Post subject: New 6 Gals. tanks |
Noel, you've become a man of few words...
DVD
On 10/11/06, Noel Bouchard <noelbou(at)cam.org (noelbou(at)cam.org)> wrote:
ô¿ô "Attitude is everything ~ pick a good one"... [quote][b]
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
