ron.mcgann(at)baesystems. Guest
Posted: Wed Oct 11, 2006 5:25 pm Post subject: Vans Alternator |
All,
Just unpacked my FWF kit. Was planning on the B&C alternator and external reg. Forgot to exclude the Vans ES 60 amp alt from the FWF kit. Backup will be the B&C 20 amp with ext reg. Any negative comments/experiences with the Vans unit??
cheers,
Ron
187 - trimming windows. [quote][b]
sam.marlow
Posted: Wed Oct 11, 2006 8:00 pm Post subject: Vans Alternator |
I know of at least 2 that didn't make it to the first 100 hrs!
McGANN, Ron wrote:
[quote] | Quote: | All,
cheers,
Ron
| [b]
flysrv10(at)gmail.com Guest
Posted: Thu Oct 12, 2006 2:35 am Post subject: Vans Alternator |
My 60 amp "Van model" stopped working at 80 hrs, while on a long X country trip. Had to leave it in Atlantic City and drive to my destination. Ordered the "new" 60 amp from Van overnight and the FBO in Atlantic City installed it while I drove the rest of the way. Hope this one does better as I understand my original alternator was a rebuilt one.
do not archive.
Rob Kermanj
On Oct 11, 2006, at 9:24 PM, McGANN, Ron wrote:
All,
cheers,
Ron
187 - trimming windows. | Quote: |
ntribution
| [b]
rvbuilder(at)sausen.net Guest
Posted: Thu Oct 12, 2006 5:19 am Post subject: Vans Alternator |
If anyone is ordering the FWF kit from Van’s, I recommend you replace the standard 60amp alt with the deluxe model. The stock one is just an auto alternator where the deluxe one is a Plane Power alternator at a very attractive reduced price. From Van’s it is $375 Plane Power’s list price is $569.
Michael Sausen
-10 #352 Fuselage
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sam Marlow
Sent: Thursday, October 12, 2006 10:59 PM
Subject: Re: Vans Alternator
McGANN, Ron wrote:
| Quote: | | All, Just unpacked my FWF kit. Was planning on the B&C alternator and external reg. Forgot to exclude the Vans ES 60 amp alt from the FWF kit. Backup will be the B&C 20 amp with ext reg. Any negative comments/experiences with the Vans unit?? cheers,Ron187 - trimming windows. | 01
pcasson(at)sasktel.net Guest
Posted: Thu Oct 12, 2006 6:11 am Post subject: Vans Alternator |
Anyone know what’s actually failing on these alternators? From my various vehicles and several million miles of driving I’ve never had an auto alternator failure. Perhaps it’s an installation issue (i.e. heat or vibration).
Perry Casson
Posted: Thu Oct 12, 2006 7:02 am Post subject: Vans Alternator |
i am not sure why mine failed. i could not feel the brushes by spinning it. It is back to Van for warranty refund. (I hope).
do not crchive
Rob Kermanj
On Oct 12, 2006, at 10:10 AM, Perry Casson wrote:
Perry Casson
LessDragProd(at)aol.com Guest
Posted: Thu Oct 12, 2006 2:47 pm Post subject: Vans Alternator |
The really disappointing thing about this is that I could not find the contents of the IO-540 FWF kit listed anywhere on Van's website. The Master relay, starter relay and Battery as listed on their web site as included, ARE NOT provided in the 540 kit nor could I find any options to change the alternator. Returning the alternator for a refund/replacement from Oz is a pain in the agates.
Ron
[quote] --
wv4i(at)bellsouth.net Guest
Posted: Fri Oct 13, 2006 2:47 am Post subject: Vans Alternator |
I run a Van's 35A alternator (not the 60A) in my RV6 with over 500TTAF.
It is the original alternator. 2-3 yrs ago, started to see system
voltage go to battery voltage intermittently in flight. Thinking this
was a temp related problem, replaced plug on back of alternator, checked
belt tightness, etc.. No help. Next replaced Van's supplied voltage
regulator (located in cockpit behind instrument panel) with another
Van's VR, same part no, but slightly different style, wiring, etc.
Problem fixed.
Link McGarity
#40622
Posted: Fri Oct 13, 2006 9:58 am Post subject: Vans Alternator |
On all of the subkits, you can contact Van's and have them fax or email a copy of the inventory. I had to do this myself for the Finish and FWF packages so I could go through and remove or change things like the cowl and alternator. I then just made a list of the parts I wanted added or removed and they requoted the kits. With my various changes I think it reduced the cost of both kits by about $5,000 USD. Removing the bulky items like the cowl will hopefully also reduce the shipping charge a little.
Michael Sausen
-10 #352 Fuselage
From: owner-rv10-list-server(at)matronics.com on behalf of McGANN, Ron
Sent: Thu 10/12/2006 5:46 PM
Subject: RE: Vans Alternator
Ron
