Fred.Stucklen(at)UTCPower Guest
Posted: Thu Oct 12, 2006 4:23 am Post subject: Throttle cable length |
I'm installing an O-360-A1A engine converted over to an IO-360-A1A using a Precision Fuel body, on an RV-7A. It looks like I can use the standard FAB airbox and a lot of the other Fire Wall Forward components (Van's service dept says that I'll need to swap out the VA-149 for the VA-182 and delete the Gascolator.) They also indicated that a longer mixture cable may also be needed, but no one with the Fuel Injected 360 had confirmed this for them, so they weren't sure.
Can anyone out there that has installed the IO-360-A1A (vertical sump) engine comment on the final throttle and mixture cable part numbers (& lengths) ???? Even an IO-320-D1A installation should have the same cables.......
Fred Stucklen
RV-7A N924RV
Erich_Weaver(at)URSCorp.c Guest
Posted: Thu Oct 12, 2006 8:03 am Post subject: throttle cable length |
I have an IO-360B1B (vertical induction) with an Airflow Performance fuel
injection. I had to replace my mixture cable from Vans with a longer one -
around 4 inches longer if I remember right, but im not absolutely sure on
that figure. I guess this may not be of much value since you have the
Precision system, but if you order the cable several inches longer than the
minimum length needed, its still very usable. Too short doesnt work at
all.
regards
Erich Weaver
