Malcolmbru(at)aol.com Guest
Posted: Thu Oct 12, 2006 6:50 pm Post subject: bungie cords |
I am getting ready to replace my old ones do I need any special tools mal
experimental208nd(at)comc Guest
Posted: Thu Oct 12, 2006 7:03 pm Post subject: bungie cords |
Just a BIG BOWL of Wheaties.
roncarolnikko(at)hotmail. Guest
Ben-PA
Posted: Thu Oct 12, 2006 7:39 pm Post subject: Re: bungie cords |
Malcom,
I attached plans to make a bungee installation tool. This is used on Starduster and Acroduster biplanes. I am building an Acroduster with bungee gear and will need this tool, but my Kitfox 5 has the Grove gear. I don't know if this tool will work on the Kitfox so if you try it let us all know. The biplane guys use baby powder to help the cords slip.
Ben
Description: |
 Download |
Filename: |
Starduster%20Bungee%20Tool.pdf |
Filesize: |
382.58 KB |
Downloaded: |
2862 Time(s) |
_________________ Sign up on the Kitfox Frappr Map:
http://www.frappr.com/kitfox
You can see where fellow Kitfoxers live and pictures of their planes. Be sure to post some pictures of you, your plane, or share the scenery of the Kitfox world. |
Float Flyr
Posted: Fri Oct 13, 2006 1:45 pm Post subject: bungie cords |
I can see every one enjoys putting the bungees on as much as I did. I've
tried olive oil it was ok but the best thing was a piece of rope put through
the eye that I could use the reem on.
Any one with a dictionary of four letter expletives will find a good number
I devised while fitting bungees.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Sjklerks(at)aol.com Guest
Posted: Fri Oct 13, 2006 2:05 pm Post subject: bungie cords |
Do what I did after hours of cussing , call grove and send it asap?
Posted: Fri Oct 13, 2006 2:16 pm Post subject: bungie cords |
Instead of cussing like I did for hours and hours, Call grove and have them send you the alum gear?
lcfitt(at)sbcglobal.net Guest
Posted: Fri Oct 13, 2006 3:44 pm Post subject: bungie cords |
Bungees have not been an issue for about 6 years here, but a wooden wedge
shaped to fit between the top bulkhead tube and the bungee in the slot did a
lot to keep each wrap from slipping. I was able to wrap with bungee to
spare. Changing the bungees stopped being a major problem thereafter.
Lowell
Lynn Matteson
Posted: Fri Oct 13, 2006 3:59 pm Post subject: bungie cords |
I only cussed once, and that was when I wrote out the check for the
Grove gear. I've saved all the rest of the cussin' for the damned
weather around here!
Lynn
On Friday, October 13, 2006, at 05:44 PM, Noel Loveys wrote:
I've
through
number
Noel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Fri Oct 13, 2006 5:00 pm Post subject: bungie cords |
The last two years at about half past December I took the Aerocet floats off and put the funny round things on, bled the brakes and hoped for some decent ice conditions to get airborne. As far as I got with it was to do some slow speed taxiing on one of the aprons at Gander International. Last year I didn't get that far.
This winter I'm going to hold off removing the floats until I see some pretty good ice.
Why ice??? I like my landing strip to be more than thirty miles long.... or is that wide?
Noel [quote]
Kitfox III-A
Float Flyr
Posted: Fri Oct 13, 2006 5:12 pm Post subject: bungie cords |
I'm going to have a look at that.... Sounds like a good idea... Easy on the
fingers too.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Fri Oct 13, 2006 5:13 pm Post subject: bungie cords |
Hope you saved some good ones for the weather around here.
Noel
[quote] --
Kitfox III-A
eskflyer(at)lvcisp.com Guest
Posted: Fri Oct 13, 2006 5:47 pm Post subject: bungie cords |
It takes all of 15 minutes a side to install the bungees . If anyone wants to know how email me personally and i will gladly let you know . It is no different than finally learning how to fly the TD kitfiox and love it . took a little bit of time and thought and just a few ty wraps and now its down to a science. Also there is not one thing at all wrong with the bungee gear it is light and plenty strong Have over 600 hours on my baby now .
Take care fly safe fly low fly slow fly fun fly KITFOX
John Perry
Kitfox 2 N718PD
582/ subbie soon
TD/ Straight floats
HOT PINK IVO inflight
Lynn Matteson
Posted: Fri Oct 13, 2006 8:24 pm Post subject: bungie cords |
I've got some dandy's saved up for this winter. This'll be my first
winter of (hopefully) flying my bird, and I'm betting it's a long
windy, snowy one. The trouble is, it seems to have started early around
here, as we just set or tied State (Michigan) records for earliest/most
snowfall. Folks in the Upper Peninsula got 20" yesterday, with
Kalamazoo getting 6.5", and that's just 65 miles west of me.....wahhhh,
I want to take my checkride!
Lynn
Noel
N369LM |
Fox5flyer Guest
Posted: Sat Oct 14, 2006 3:33 am Post subject: bungie cords |
Other than a little "dust" we didn't get any accumulation here Lynn,
fortunately. I'm neither mentally, nor physically prepared to deal with
that crap yet, but at some point I guess I'd best start thinking about it.
The longer it holds off the longer I can still fly out of my strip.
Deke
NE Michigan
Mikado International Airport
dave
Posted: Sat Oct 14, 2006 3:47 am Post subject: bungie cords |
NO Ski Flying Deke ?
We got about an inch or so here the last few days but 100 miles east 10 to
20 inches I hear.
Ski flying is some of best flying you can get next to float flying and you
get the extra performance boost from the cold dense air. !
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Lynn Matteson
Posted: Sat Oct 14, 2006 4:56 am Post subject: bungie cords |
Yeah, same here, Deke, we got just enough to make footprints stand out
for about an hour, then gone. But it was coming down so hard as to make
viewing across the road almost impossible.
Hey, I just noticed that you have achieved "International"status at
your home airport...does that mean I need to get endorsed for Class B
airspace before expecting to land there? : )
Lynn
with
it.
Deke
NE Michigan
N369LM |
smokey_bear_40220(at)yaho Guest
Posted: Sat Oct 14, 2006 5:39 am Post subject: bungie cords |
Oh wait. Are those float attachment points on my Fox?
I been using them for the snowplow.
Ya got customs and ag there too Deke?
No guys. Nothing stops Deke. I think he just isn't
winterized yet this year.
Kurt S.
out of my strip.
Deke
NE Michigan
alnanarthur(at)sbcglobal. Guest
Posted: Sat Oct 14, 2006 7:02 am Post subject: bungie cords |
Hi All,
I can change the bungie cords on my Series 5 by myself in about 30 min. each.
I use zip ties and a cargo tie-down strap (the kind that when you pull it tight, the spring loaded friction lever holds it tight).
First, mark the old bungie across the top with a marking pen and remove it.
2. Lay out the old beside the new and transfer the marks to the new one, marking all the way around the new cord. Now with the new bungie cord,
3. make a loop around the gear and
4. about a foot up on the free end form a "free end loop" and secure it with a zip tie.
5. Take the cargo tie-down over the fuselage carry-through tube and hook it to the "free end loop" .
6. With the cargo tie down, pull up on the "free end loop" till the first mark on the new bungie is on top, then secure the gear loop tightly with one or two zip ties.
7. Release and unhook the cargo tie down and cut the zip tie on the "free end loop" and make another loop around the gear.
8. Repeat 3 thru 7 till all gear loops are on and secure the final end loop of the new bungie on the post.
9. "Carefully" cut all the zip ties holding the individual gear loops.
I don't even break a sweat.
Hope this makes sense.
Allan Arthur
Kitfox 5, N40AA
Rotax 912s, Warpdrive 3 blade
Byron Airport, CA (C83) Hanger C8
john beirne
Posted: Mon Oct 16, 2006 10:32 am Post subject: Re: bungie cords |
Hi Guys,
where can i purchase a new set of bungies already made up with the nicopress fitting (for a Mark III)
thanks
