Mark III Classic vs. Mark III Xtra
cwolf41(at)comcast.net
PostPosted: Sun Oct 15, 2006 1:10 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
If I get a Kolb, which one should I buy? The Mark III Classic, or the Mark
III Xtra? I need two seats, so it seems that it's one or the other.
It looks like the main difference between the two planes is the width of
the nose. I understand that the wider nose on the Xtra permits better
placement of the rudder pedals, and gives more leg room. It looks bigger
on the Xtra. I'm about 6'3" tall, and weigh about 250. My flying buddy is
5'8", and weighs 170. Are the rudder pedals (or seats) adjustable on the
Xtra? I saw cockpit pictures of both Classic and Xtra, and it looked like
the Xtra had a LOT more leg room.
Would a guy my size be comfortable in a Classic, or should I definitely go
for the Xtra?
Thanks!
Chris Wolf
Cat36Fly(at)aol.com
PostPosted: Sun Oct 15, 2006 3:17 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
I can tell you the Extra has adjustable rudder pedals. I am 5'4" and have them set at the middle position. It is not easy to adjust them between flights (or pilots) but can be done. There is probably more room in the extra cockpit than a C-150. I now have about 50 hrs on my extra and thoroughly enjoy it (in comfort).
Larry Tasker
MKlllx -583-3 blade warp
N615RT
flyingfox(at)copper.net
PostPosted: Sun Oct 15, 2006 3:47 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
Here is my two bits:
I am 6'3" and weigh 250 pounds. I have sat in both the Classic and Mark
IIIX.
The Classic is 'cozy'. Once in you have plenty of head room but your feet
are definitely tight and I mean that to the point where I didn't feel as if
I had the space for good free controllability of the rudder pedals.
The Mark IIIX is very roomy and once you are in it you have plenty of room.
The problem is getting in and out of the thing. I found that trying to
squeeze through the door openings was a little difficult. Difficult to the
point that I felt like I was not entirely happy with the whole process and
started looking at other airplanes. Kolb brought a Mark IIIX to OSH this
year and I will be honest, I was disappointed when I sat in it because I
really had my hopes up and it was just friggin hard to get through that
door.
The jury is not out. I have a build start date of 2008 because of some other
"wife-generated-home-improvement-mandates" that will eliminate all my shop
space with furniture storage (why we even need furniture I have no idea, but
I have learned not to go there.) so I will continue to trek off to Oshkosh
and sit sit sit in everything until I get it really figured out.
What I wish is that Kolb made a tandem with more room up front. I couldn't
even get into the front seat of the Kolbra and I want doors on both sides of
the airplane that I can remove.
The RANs S-18 came pretty close to perfect but I hate the tail, the wings
don't fold and the airplane is no longer supported by the company as far as
I know.
There is a real need in the world for an airplane made for the genetically
challenged like us. I think they do have one out there with a big enough
cockpit... ...its called a 757 and they are kind of pricey and I am certain
that the wing folding is not an option.
I am seriously considering an AirCam, but that means the price of two Mark
IIIX in one machine. If not for the ingress, egress issue the IIIX would be
about perfect.
Todd
DO NOT ARCHIVE
Todd Fredricks, DO
Flying Fox Services
http://web.mac.com/flyingfoxservices
flyingfoxservices(at)mac.com
Visit my Blog at www.flyingfoxhangar.blogspot.com
PostPosted: Sun Oct 15, 2006 4:18 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
(in comfort).
Larry Tasker
N615RT
Good information. Thanks!
Chris Wolf
PostPosted: Sun Oct 15, 2006 5:39 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
(in comfort).
Larry Tasker
N615RT
Glad to hear the rudder pedals are adjustable. Thanks for the info!
Chris Wolf
PostPosted: Sun Oct 15, 2006 5:56 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
two Mark
would be
| about perfect.
| Todd
Todd:
Ever think about modifying the entrance system to fit your
requirement?
biglar
PostPosted: Sun Oct 15, 2006 6:32 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
As long as you are building a plane, build gull wing doors for it. It's
somewhat of a job, but can be done. See the page in my website by clicking
on the link in my signature, below. Access is Very easy.
Maybe you'd like to buy an almost completed Mk III Classic - cheap - with
gull wing doors already built, but with no engine ?????? Smile
Lar. Do not Archive.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
Vamoose
www.gogittum.com
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
PostPosted: Sun Oct 15, 2006 6:44 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
John;
As a aerodynamic structural engineer, I make a pretty good ER doctor, if you
know what I mean. Smile
Todd
two Mark
would be
| about perfect.
| Todd
Todd:
requirement?
Todd Fredricks, DO
Flying Fox Services
PostPosted: Mon Oct 16, 2006 10:20 am    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
My long-lost twin brother!
I have sat in both the Classic and Mark IIIX.
door.
I guess I need to go sit in both aircraft, and see for myself. But I hear
what you're saying, and it sounds like the Xtra would be a good idea for a
guy like me. Definitely must check this out.
What do you need furniture for, if you have an airplane? Wink
However the solution to your problem is quite simple; build another shop!
Aren't the Kolb doors removable now?
I know.
challenged like us.
Yeah, I think most planes are designed by guys who are 5'8" and weigh 170
pounds.
Paul Allan, Microsoft multimillionaire and owner of the Portland
Trailblazers, has a 757 that he keeps at Boeing Field, near Seattle. He
uses it to haul his friends and basketball team around. He also has a very
large hangar to keep it in, so folding wings is probably not a priority for
him.
about perfect.
That is exactly the sort of information I was looking for. And the fact
that you are my size, makes the information doubly useful. Thanks very
much!
Chris Wolf
PostPosted: Tue Oct 17, 2006 3:28 am    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
John H sent me a suggestion that I modify the airframe to suit my
purposes. I replied that I am not an aircraft structural engineer...
..however, it is widely known that John H did exactly that to his
own Classic, which was then just the Mark III. Frankly, I have always
thought that John's version looks better than the stock one.
The point to all that is this, for us genetic deviants, the Mark IIIX
is really the only way to go, unless you chop the front end off the
Classic ala Adriel Hasey.
I would recommend sling seats, as much for available backside width
over the molded products as weight savings. I sat in the slings in
London and the molded job at OSH. Slings are much better. I would
also consider talking to the London KY folks about the door
arrangement, the structural side. I have no idea how 'structural'
that door frame is, but if it could be modified to increase the
height of the upper cross member, it would be a great way to allow
big guys to get in.
The lower door sill is probably where it needs to be. Frankly it
serves to protect the throttle and other fragile bits and works well
ergonomically.
If the Mark IIIX is the airplane that I end up with, the panel layout
will change but even so, there is plenty of leg and foot room for my
size 13R gunboats. The center stick is probably also the best bet
over the dual control sticks. I had good control throw on the center
arrangement and it is a lot like Zenith's set up, which I find very
comfortable to use. Dual control sticks are not so good, because I
like to feel the stops when I move the stick... ...not my thigh.
Uncle Craig 'Milow' has done some really beautiful work with the
panel arrangement and there is plenty of space in the machine for
avionics and other instruments. The purists here will start choking
on that, especially when I tell them that I will have two comms and a
WAAS/LNAV IFR GPS in whatever I build, but that is only because I am
a passionate IFR pilot who likes to shoot approaches for fun, I am
gadget obscessed and I live in a hollar in Southeast Ohio where one
draw looks like the next. One airstrip sits on a ridge, the
other...the long one...down in a valley. On hazy VFR Ohio days it is
nice to know exactly where you are always.
The only other consideration from my perspective is storeability. I
ditched my 172 because I realized that I was spending the equivalent
of a Garmin 495 every year on hangars and my annual was enough to buy
a new navcom every two years and I was 45 minutes away and flew my
airplane no more than 20 hours a year. So off it went. I have a large
shop with 18 foot high garage doors but they are only 12 feet wide.
Whatever it is it needs to fold so I can use my shop for a hangar.
I cannot speak for Glastars, but I doubt that anyone has purposely
gone out and destroyed them in flight. Homer Kolb did that with his
design. An actual in-flight test to failure, so we know the absolute
structural limits of the design. That says it for me.
The AirCam wings can come off and be put back on in about 30 minutes.
Not nearly as convenient as the Kolb, but for low altitude with no
forced landing area flying, two engines will always trump one.
The bottom line is that you need to sit in some Kolbs, talk with the
London folks, they are all as nice as can be, and frankly consider
where you live. If you live in the flatlands, you don't need but one
engine because you always have lots of options. If you live in the
mountains or near the water, two engines becomes a consideration,
especially if you plan on doing a lot of low altitude flying.
It is a tough thing in the end because these machines tend to become
an extension of the pilot. You cannot look at John Williams Kolbra,
or Hauck's Mark III or Jeremy Lezin's Chiquita AirCam or Uncle
Craig's Xtra and not say, that is a unique machine and a reflection
of its owner. There is nothing 172-generic about experimentals.
So whatever you build/buy will become your baby and in the forums
everyone will say, Oh, Miss P'Fer, that's Hauck's airplane. It is
pretty cool actually. And much like your kids, it becomes a
crapshoot. You put your heart into the thing and in the end, it is
never perfect, but you love it and it is yours and it works for you.
Todd
DO NOT ARCHIVE
PostPosted: Tue Oct 17, 2006 12:13 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
...however, it is widely known that John H did exactly that to his
big guys to get in.
ergonomically.
That's a great deal of very useful information, Todd. Thanks!
Todd
DO NOT ARCHIVE
An inspiring concluding thought. It ought to be archived!
Chris Wolf
PostPosted: Tue Oct 17, 2006 1:15 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
This might be the way to go, Lar since I was planning on putting a wire
cutter up the windshield anyway. I might see if structurally I can alter the
Mark IIIX canopy to allow for those doors.
Todd
DO NOT ARCHIVE
Larry Bourne
Palm Springs, CA
a58r(at)verizon.net
PostPosted: Tue Oct 17, 2006 2:27 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
Todd,Now I see why you want two fans...to drive that wire cutter right through those pesky EHT lines, even the paired ones?
regards,
Bob N.    FireFly 070 Old Kolb
PostPosted: Tue Oct 17, 2006 2:42 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
Well, the issue is wire-strikes. I have already known three helicopter crews that have hit wires and never saw the towers or the wires. The wire cutters saved their lives. So as a low altitude flier I intend to put them on my airplane. I know it sounds crazy but fly around south east Ohio a while and you realize that even with the best recon, you can miss the small ones pretty easily. They are not that big and I can probably salvage a set off an old OH-58.
Todd
On 10/17/06 6:18 PM, "Bob Noyer" <a58r(at)verizon.net> wrote:
Todd,
regards,
mail Forum -
t">http://www.matronics.com/Navigator?Kolb-List
; - NEW MATRONICS WEB FORUMS -
matronics.com
; - NEW MATRONICS LIST WIKI -
onics.com
;- List Contribution Web Site -
;   -Matt Dralle, List Admin.
://www.matronics.com/contribution
Todd Fredricks, DO
Flying Fox Services
[img]cid:3243955293_12976932[/img]
 Filesize:  803 Bytes
 Viewed:  10155 Time(s)
PostPosted: Tue Oct 17, 2006 3:04 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
wire
alter the
| Todd
Todd:
Like I said the other day, you can modify the entrance system to fit
you and still maintain structural integrity of the aircraft.
My mkIII was designed for one pilot and one mission. This aircraft
fits me, and if it fits anyone else, it is lucky.
Contact Donnie Sizemore reference modifications to existing aircraft
kits, or to modify a fuselage before it is complete to prevent undoing
a lot of work that has already been done. Bryan Melborn will also
work with you.
Take care,
PS: Wire cutter? Like the Grey Baron said, "Gonna need two engines
to drive the wire cutter." Wink
planecrazzzy
PostPosted: Tue Oct 17, 2006 3:45 pm    Post subject: Re: Mark III Classic vs. Mark III Xtra Reply with quote
Big Lar....
Say it AIN'T so.....
Gotta Fly...
Mike & "Jaz" in MN
Lar.
biglar
PostPosted: Fri Oct 20, 2006 3:04 pm    Post subject: Mark III Classic vs. Mark III Xtra Reply with quote
Yup. Maybe even the engine, too, for enuf money, but the redrive that
caused my problems is long gone in the trash. More later...........just
got home from interviews. Do not Archive.
Larry Bourne
Palm Springs, CA
Vamoose
www.gogittum.com
Larry Bourne
Palm Springs, CA
"Vamoose"
