LIKE2LOOP(at)aol.com Guest
Posted: Sun Oct 15, 2006 1:23 pm Post subject: Weldment part |
In a message dated 10/15/06 5:10:45 P.M. Eastern Daylight Time, fehdxl(at)gmail.com writes:
| Quote: | | I need to get the new WD-415-1's from Van's for $8...or the milled ones from, uh, can't remember the web site's name now, for $38 -- decisions? |
Get the ones from Dave Czachorowski, DBA - Rivethead,
rvsiverbullet(at)verizon.net (rvsiverbullet(at)verizon.net) 302-437-6087
I am not sure what VANs is selling now, but the ones in the KIT are pretty weak. The ones i received from Dave are excellent workmanship. If you hold the two parts side by side, you will wonder how they ever tried selling the one with the kit. Make sure you are comparing apples to apples. I got the weldment nuts, HS attach brackets and rudder stops in one package, call and ask price.
Steve
rwhunter(at)integra.net Guest
Posted: Sun Oct 15, 2006 2:29 pm Post subject: Weldment part |
Here is the web site for the WD 415 by Dave Czachorowski.
http://www.rivethead-aero.com/rv10l
Rob Hunter
Elevators
40432
kearney(at)shaw.ca Guest
Posted: Sun Oct 15, 2006 2:30 pm Post subject: Weldment part |
All
I have just inventoried all my parts including sorting etc. In the process I came across the WD-415’s from Van’s. It looks like a couple of nuts on a stainless square with a couple of welds. You can see between the welds which makes me wonder if it is going to last.
I have been to Rivethead’s website (even before I took the kit plunge) based on comments that I have read in posts over the past three months. I plan to get Rivethead’s part only because it looks like it will last. Should I also be purchasing his other RV10 products (i.e. brackets etc)? Are their other parts in the RV10 kit that I should be replacing with “aftermarket” parts?
Inquiring minds need to know
Les Kearney
RV10 # 40643 - Awaiting tools
fehdxl(at)gmail.com Guest
Posted: Sun Oct 15, 2006 4:48 pm Post subject: Weldment part |
Fellow builders,
Just to summarize...there are three generations of Van's WD-415's ...
v1: no aft weld (single weld across the front of the nut)
v2: one long weld across the front of the nut and a small tack weld on the aft side of the nut
v3: full width welds on both sides of the nut (Also known as WD-415-1).
http://www.vansaircraft.com/pdf/sb06-9-20.pdf
Question for those who bought RivetHeadAero's version http://www.rivethead-aero.com/rv10_005.htm ... it's all aluminum, milled from a solid block, right Any concerns about switching from steel to aluminum?
Thanks!
-Jim
40603
Posted: Sun Oct 15, 2006 6:39 pm Post subject: Weldment part |
In a message dated 10/15/06 6:31:27 P.M. Eastern Daylight Time, kearney(at)shaw.ca writes:
| Quote: | | I plan to get Rivethead’s part only because it looks like it will last. Should I also be purchasing his other RV10 products (i.e. brackets etc)? |
Les. In a word YES. Quality and dont look back.
Steve
wv4i(at)bellsouth.net Guest
Posted: Mon Oct 16, 2006 2:56 am Post subject: Weldment part |
If you don't buy the pre fab HS attach brackets, be very careful as to
dimensions, hole sizes and positioning, etc. I did not catch that the
widths are different, had to order new angle stock fm Air Parts, and do
them again, etc.. Not difficult to make these parts incorrectly.
Definitely want to catch before drilling HS front spar...All considered,
I would just buy the pre fab HS attach brackets, and save time. Probably
other items too. Thanks to all for heads up and info.
Link McGarity
#40622 Elevator
zackrv8
Posted: Mon Oct 16, 2006 4:46 am Post subject: Re: Weldment part |
Also, when I first put on Vans Weldment, the angle of the weldment/nut was wrong because the trim cables would bind against the elevator spar too much. Dave fixed that with the new replacement.
Notice the part number of Vans weldment. It was first used on the RV4 manual trim (maybe even the RV3!).
Zack
[quote="fehdxl(at)gmail.com"]Fellow builders,
Thanks!
-Jim
40603
_________________ RV8 #80125
RV10 # 40512 |
Vern(at)teclabsinc.com Guest
Posted: Mon Oct 16, 2006 7:02 am Post subject: Weldment part |
Zack,
Do the rivet holes for Dave's "weldments" line up with the rivet holes
from Van's? I installed the version 2 units from Vans along time ago and
was wondering if I need to replace the access panels when using the
machined ones.
Vern (324 fuselage:)
zackrv8
Posted: Mon Oct 16, 2006 8:34 am Post subject: Re: Weldment part |
Vern,
You might need to replace them if you already drilled the holes for the old weldment. Daves part has a slightly wider footprint. However, it might work but I don't know for sure because I never drilled the holes in Vans weldment because the darn thing would not line up without bending the trim cables to the point of binding them.
Maybe Anh Vu can chime in here. He had the old weldments on and switched to Dave's billet parts.
Zack
| Vern(at)teclabsinc.com wrote: | Zack,
machined ones.
RV10 # 40512 |
Posted: Tue Oct 17, 2006 7:04 am Post subject: Weldment part |
John,
I think most of the original weldments are made out of stainless steel.
It's not so much the choice of material that has people concerned but
the welds or rather the lack of them. The aluminum ones are designed to
eliminate the weld and with it the possibility of the weld breaking.
Vern Smith(324)
