av8rps(at)tznet.com Guest
Posted: Sun Oct 15, 2006 5:41 pm Post subject: Model V with O-200; questions |
Anyone out there flying a model V with an 0-200 continental 100 hp? A friend of mine just bought one like this and reports a 85-90 mph cruise speed and a 400-500 fpm climb rate. The airplane is 900 lbs empty and is equipped with a Warp drive prop. I have a model 6 specs page that shows a 120 mph cruise and a 1200 fpm climb rate. I realize the factory numbers might be somewhat optimistic, but are they that far from the truth? Or is the warp drive the wrong prop for this engine and airframe?
Paul Seehafer
janderson412(at)hotmail.c Guest
Posted: Sun Oct 15, 2006 6:01 pm Post subject: Model V with O-200; questions |
Does seem a little behind in performance. I have a Model V with EA81 T
72"Warp drive and guess it's around 120HP. I get 1700fpm at 60kts with just
me on board and 3/4 tanks. Mine is a heavy beast - 945lbs.
Subject: Model V with O-200; questions
Date: Sun, 15 Oct 2006 20:39:16 -0500
Paul Seehafer
Check out the latest video (at) http://xtra.co.nz/streaming
fjo(at)telecom.com.co Guest
Posted: Sun Oct 15, 2006 6:24 pm Post subject: Model V with O-200; questions |
Paul
I’m flying a VIXEN model V with a 0-200 continental 100HP and my reports is the following : cruise speed 100mph, climb rate 300-500fpm with 70mph and 3000’’feet with 10000’feet the climb rate is almost 50-80fpm . Prop warp drive 70”, static RPM 2600 elevation 2000f. I’d like to get the specs of the factory.
Francisco
De: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] En nombre de Paul Seehafer
Enviado el: Sunday, October 15, 2006 8:39 PM
Para: kitfox-list(at)matronics.com
Asunto: Model V with O-200; questions
Paul Seehafer
Posted: Sun Oct 15, 2006 7:50 pm Post subject: Model V with O-200; questions |
Francisco;
Interesting specs. Much like what my friend is experiencing. Here is a copy of the specs sheet page for a model 6 Kitfox (along with the IV on the lower part of the page).
I wonder if a different prop, say one from a 150 Cessna would improve the performance? Have you ever tried a different prop on your Vixen?
Paul
Description: |
Filesize: |
212.81 KB |
Viewed: |
419 Time(s) |
Fox5flyer Guest
Posted: Mon Oct 16, 2006 3:01 am Post subject: Model V with O-200; questions |
I can't speak for the factory specs and I tend to agree with what you say in that they tend to embellish them. That being said, your reported cruise/climb speeds for the 0200 are definitely low. Something is seriously wrong there, but then again, drag reduction is a pretty big factor, especially with the struts. That doesn't explain the poor climb rate though. Possibly the engine isn't producing rated power?
Deke
dave
Posted: Mon Oct 16, 2006 4:44 am Post subject: Model V with O-200; questions |
Francisco,
You never said what rpm you are turning .
I am assuming this is a landplane ?
If on floats and at 100F then I appologize.
Is this a new engine install ?
Dave
----- Original Message -----
Quote: | From: Francisco J Ocampo (fjo(at)telecom.com.co)
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Sunday, October 15, 2006 10:22 PM
Subject: RV: Model V with O-200; questions
Paul
Francisco
Paul Seehafer
| [quote][b]
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Mon Oct 16, 2006 6:58 am Post subject: Model V with O-200; questions |
Paul
I have never tried a different prop. May be would be better another prop like a Sensenich
Francisco
Enviado el: Sunday, October 15, 2006 10:32 PM
Asunto: Re: Model V with O-200; questions
Francisco;
Paul
Description: |
Filesize: |
212.81 KB |
Viewed: |
422 Time(s) |
Posted: Mon Oct 16, 2006 7:08 am Post subject: Model V with O-200; questions |
Deke
The engine today is only 300Hrs of fly and has all struts checked may be I thing the poor speed and climb is for the motor weight. I spocke with the factory about this 5 years ago and they told me that the all the planes are not identity.
Francisco
De: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] En nombre de Fox5flyer
Enviado el: Monday, October 16, 2006 6:00 AM
Deke
Posted: Mon Oct 16, 2006 7:32 am Post subject: Model V with O-200; questions |
Dave
I always flying with 2550Rpm, the plane only has a 300hr of fly. And we installed the weelpants
Francisco J ocampo.
De: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] En nombre de Dave
Enviado el: Monday, October 16, 2006 7:42 AM
Francisco,
Dave
Fox5flyer Guest
Posted: Mon Oct 16, 2006 8:57 am Post subject: Model V with O-200; questions |
That 100hp should pull the airplane faster than what you indicate so assuming the airplane is well fared and the engine is OK, then it's entirely possible that your problem lies in your prop selection. Maybe calling Sensenich again and talking to their tech support might give some insight. My S5 with 100hp Subaru cruises 108 at 3900rpm and a typical climb is somewhere around 850 to 1200 fpm depending on temp and load. One thing I do have that is different from you is an electric cockpit adjustable prop (CAP) which may account for the big difference. Airmaster makes a nice unit, but I don't know if they make one to fit on an 0200. http://www.airmasterpropellers.com/wa.asp?idWebPage=3672 Personally, I'll never have another airplane without a CAP. They're especially nice when on floats.
Good luck,
Deke
dave
Posted: Mon Oct 16, 2006 9:05 am Post subject: Model V with O-200; questions |
Francisco, your 0-200 only gonna be giving you about 80 hp or so at 2550 ...... at best on a perfect engine
You should see 2650 to 2750 for take off , so basically you missing at least 20 % of your performance there alone .
So for example........
If you see 800 fpm you missing at least 160 fpm so that brings you back closer to 600 fpm
Has the compression been checked in this engine ? And is this the prop that warp recos for this engine /airframe combo ? It would be a benefit to give them a call and maybe you just got to fine up that prop a bit to get higher rpm.
If you even flown a plane then change to seaplane prop that alone will tell the story on performance gains.
Dave
[quote] From: Francisco J Ocampo (fjo(at)telecom.com.co)
Sent: Monday, October 16, 2006 11:31 AM
Dave
Francisco J ocampo.
De: owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com) [mailto:owner-kitfox-list-server(at)matronics.com] En nombre de Dave
Para: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Francisco,
Dave
57_kid
Posted: Wed Oct 18, 2006 9:16 am Post subject: Model V with O-200; questions |
Paul
I have a series V with a 0-200 , Cruise at 115 MPH at 2400 RPM ( i don't like to run at 2550 ) get about 1000 FPM climb using a warp drive 3 Blade. My empty weight is 860 and my motor is at about 1/2 life 700 hr's on it, and if you are to use the warp drive you should find that it is very smooth and a lot quieter IMHO than my 2 blade wood prop.
Steve
[eccles]
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Paul Seehafer
Sent: Sunday, October 15, 2006 8:39 PM
[quote] Anyone out there flying a model V with an 0-200 continental 100 hp? A friend of mine just bought one like this and reports a 85-90 mph cruise speed and a 400-500 fpm climb rate. The airplane is 900 lbs empty and is equipped with a Warp drive prop. I have a model 6 specs page that shows a 120 mph cruise and a 1200 fpm climb rate. I realize the factory numbers might be somewhat optimistic, but are they that far from the truth? Or is the warp drive the wrong prop for this engine and airframe?
Paul Seehafer
Quote: |
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matron
| [b]
