robin1(at)mrmoisture.com Guest
Posted: Mon Oct 16, 2006 9:51 am Post subject: engines |
John,
That was the humor part of the email thus the bold HIGHLY. As
there are almost no -10 sales recorded and basically no alternate
engines let alone sales of alternate engine -10's. My fundamental point
is that if one wanted to go the alternate engine route for fuel / power
plant savings that they would ultimately experience the "expense" an
alternate engine costs at resale.
I looked at a beautiful 7A slider with a Subaru engine mounted
up front. It was as nice (panel & build) as the $110K 7's that have sold
except the seller was having a hard time getting $70K for it. IMHO most
prospective RV buyers were not willing to take the risk of owning an
alternate engine especially when they don't have the experience of an
alternate engine installation or are the holders of the planes
repairman's certificate.
Happy flying,
Robin
jesse(at)itecusa.org Guest
I like the discussion I am reading about this. I agree completely with Tim’s last post. The IO-540 is perfect for most missions on both economy at altitude and take-off/climb performance. The main problem with the 540 is the upfront cost and the lack of power that might be achievable at altitude with a turbo-normalized engine. Ideally, normalizing a 540 to get more than 80hp at 18k (rough number estimates based on our flying experience in N256H) would be great, maybe even reaching a 200Kt cruise speed. That is what I would like to see happen. The cost of a turbo is high, which would be the only reason for possibly going with a smaller engine and a turbo. You really can perform well at sea level with less power, and it doesn’t make any sense (IMHO) to cruise low because of the fuel burn, so the HP down low is just used to get you up high. You can get as good or better range with a 540 than with a 360 Continental because of the altitude performance (probably, not knowing numbers because Van’s doesn’t publish 15k feet performance on their planes). Again, having more power doesn’t have to be used if you don’t want it (again, following Tim’s comments), but I think I might be willing to sacrifice a little power down low to get more up high. How much would it cost for a Superior 400 with a turbonormalizer? Might we worth a try.
To further this discussion, for those flying, what does the sweet speed of economy seem to be in indicated airspeed? I think it is probably about 120Kts or so. You can’t get that at 18k normally aspirated, so how many horsepower would it take to get that speed up high, and how fast would that be in TAS at standard temps? That’s what I would like to see.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James K Hovis
Sent: Monday, October 16, 2006 1:13 PM
Subject: Re: Re: engines
I think you're slightly missing the point. If you have two identical airframes sitting side-by-side and the only difference is one has a 210hp engine and the other has a 260, you WILL see differences in performance. To me, it's really a matter of the individual builder to decide what type of mission he/she wishes to fly. According to Van's data, you lose about 10 mph in flight speeds, lose 300 fps in climb rate but gain about 125 miles in range (implying better fuel efficiency) (I'd like to see these numbers verified, but Van's has a pretty good track record of meeting the performance figures they publish). Sure, you can back off power in cruise with an O-540 and match the range figures for a 210hp engine, what's your trade-off when you do so? Speed. Personally, I'd rather have the horsepower reserve from a big engine and fly it more economically, say at 165 mph or so. Going fast isn't that big of a deal to me, a 100kt C-150 is still quicker than a car for most "long distance" trips. If I can get a hold of a 210-230hp engine that is significantly cheaper than the 260hp Lycs while weighing equal to or less than the "stock" engine, I will seriously consider it. Having to do some additional engineering and fabrication for a "non-stock" engine shouldn't be a killer either. As I point out you could end up with a lighter installation which has it's own benefits to the airplane's mission. However, I don't see how a TIO-360 installation would be cheaper than and in then end, more reliable than the straight O-540. Don't think that I'm endorsing automotive installations, it is RARE that a 260 hp car engine will weigh less than an O-540 once you consider reduction drive, radiator, etc. needed for such installations.
Again, my main point, if you can live with a lower performing airplane, a smaller engine might be better for YOU if the resulting mission capabilities conform to the mission you wish to have. As a simple IFR family truckster, a 210 hp engine might not be too bad.
JKH
On 10/16/06, John W. Cox <johnwcox(at)pacificnw.com (johnwcox(at)pacificnw.com)> wrote:
A reduction of 260 to 210 is a 19.2% reduction in BHP. To maintain the same robust HP/Weight and not have an anemic performer, then the gross weight would have to be reduced to 2208 pounds.
For simpletons like me that's 492 pounds of offloaded fuel or passengers cause there just is not that much difference in powerplant weight saved on the empty weight side of the equation. I guess that means a RV-9 with a four banger. Now where is my math supporting a more anemic engine. Oh, yeh – four cylinders instead of six, Fuel Consumption. Oh, no – I forgot about pulling the throttle back and running a more anemic power output. Thus saving the throttle for the quick go arounds and climbouts to avoid weather.
Not all tradeoff are equal in logic. This reminds me of 17 friends who embraced the idea of putting ½ VW engines (yes two cylinders) in Nieuport replicas. I pointed out that with a 254 pound body weight the thing might not fly. He bailed on the project and watched the first prototype crash from lack of power. Conclusion, Van has done a pretty good job with the mission statement of the 4 place RV-10 with a six banger. Now with this logic is there anyone willing to consider a 9 cylinder, 360 hp radial? Kimball did it to satisfy those frustrated four cylinder owners with Pitts.
JWC
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of James K Hovis
Sent: Monday, October 16, 2006 8:16 AM
I wouldn't worry too much about using a lighter, less performing engine in the 210 - 230 HP range if you can live with a little loss of performance. Weight and balance is fairly easy to deal with, move the battery forward to the firewall and make provisions to add lead ballast. The firewall is typically pretty stout and should be able to handle the loading from the battery and a few pounds of lead. I would wait to add any ballast up front until after an empty aircraft weight and balance check is done. If the CG is outside limits, then add ballast as needed. Do check with Van's about ballast installation on the firewall if needed. You could end up with an aircraft with a lighter empty weight which translates into more useful load or more weight to add more avionic goodies.
Everything in aircraft design and performance is a trade-off, give up some top-end performance and get a few more pounds for other things. Van's specs for 260 vs. 210 HP don't look too bad. At gross you lose about 10MPH of speed, but climb rate suffers more at about 300 fps loss. However, at 1,150 fps, it still climbs better than most spam-cans weighing 2,700 lbs....
JKH
On 10/16/06, John Gonzalez < indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)> wrote:
--> RV10-List message posted by: "John Gonzalez" < indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)>
Well said John!
Thank you!
John G. 409
Do Not archive
>From: "John W. Cox" <johnwcox(at)pacificnw.com (johnwcox(at)pacificnw.com)>
>Reply-To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
>To: < rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
>Subject: RE: Re: engines
>Date: Sun, 15 Oct 2006 23:23:11 -0700
>--> RV10-List message posted by: "John W. Cox" < johnwcox(at)pacificnw.com (johnwcox(at)pacificnw.com)>
>Robin, this is out of context but where did you pull your statement "~20%
>of the original pool of prospects. (These numbers are HIGHLY scientific
>based on all recent -10 sales with alternate engines)"?
>I am not aware of one single flying alternate engine RV-10 except N210RV.
>That is only an alternate to the Lycoming (being a Continental). No
>science used in this conclusion. I'm baffled.
>John Cox
>________________________________________
>[mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Robin Marks
>Sent: Sunday, October 15, 2006 7:40 PM
>John,
> Some day you will want or need to sell your -10. That will be when
>you find out how expensive "alternate" engines really cost. I am all for
>the concept of different engine choices (and applaud all who try) but one
>day you will have to convince a buyer to purchase your alternate choice and
>regardless of how nice you built the rest of the plane you should expect to
>shave $20-30K off a comparable plane while at the same time limiting the
>total number of buyers to ~20% of the original pool of prospects. (These
>numbers are HIGHLY scientific based on all recent -10 sales with alternate
>engines)
> When considering the additional time & expense it may take to get an
>alternate engine actually flying and that will far outweigh any potential
>savings.
> A note not covered on the recent discussion "RV7a v. Legacy FG v.
>Glassair SII FT" not mentioned when comparing each model and their
>respective traits is the significant increase in build time between the
>Vans kits and the other choices. Everyone concedes that the other choices
>are beautiful planes but I would prefer spending the extra 2000+ build
>hours actually flying.
>Robin
| Quote: | | [/url][url=http://www.matronics.com/Navigator?RV10-List]http://www.matronics.com/Navigator?RV10-List |
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com/" target="_blank">http://forums.matronics.comhref="http://wiki.matronics.com/" target="_blank">http://wiki.matronics.com | 012
345678901234567890123456
-- Date: 10/14/2006
10/14/2006
AV8ORJWC
Posted: Mon Oct 16, 2006 10:17 am Post subject: engines |
Heat and vibration are the two reasons that Cessna moved batteries from the firewall to locations aft. I take a contrarian view that the thickness of the material provided by VANS in the firewall is adequate for the weight of the appropriate battery. Marine and RV batteries are built for such vibration abuse and trade weight for durability. The big advantage is distance of the electric cable run. Some builders resort to welders wire which has vastly more strands, much smaller individually which makes it more flexible and it carries higher amperage. Oh, did I mention it is more expensive per foot.
Maybe people are considering welding another bead onto the engine mount for the battery. That is a whole nother consideration. Trade offs/trade offs.
John Cox
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com
Sent: Monday, October 16, 2006 9:59 AM
Genrally putting the battery on the firewall will shorten the life of a battery plus if you do put the battery on the firewall, you should consider creating an easy access to it's location...having the battery close to the starter may not be a bad thing as there is less line lose in the distance from the firewall to the starter as opposed to a location in the rear of the aircraft.
P
[quote] [b]
Deems Davis
Posted: Mon Oct 16, 2006 10:22 am Post subject: engines |
btw Scott, B E A U T I F U L Plane1 Congrats on your 1st flight.
Deems Davis # 406
Finishing
http://deemsrv10.com/
AV8ORJWC
Posted: Mon Oct 16, 2006 10:28 am Post subject: engines |
I yield to your humor and logic. Resale, Insurability and Flying
enjoyment are all qualitative and important factors. Reliability and
Safety are two others for consideration.
JC
Do not Archive
Tim(at)MyRV10.com Guest
Posted: Mon Oct 16, 2006 10:32 am Post subject: engines |
Amen!
One last comment on range since Jesse tripped my memory.
Yesterday I had flown 350 or so miles. I was motoring
along at 160kts or so, and noticed that the range on my
chelton, adjusted for groundspeed and fuel flow, and saw
that I still have well into the 700(nautical) mile range
left on my fuel supply (standard 60 gal). The easiest
way to get economy is to fly higher (to a point), and
go LOP on the mixture. LOP is best done with an IO-540,
not an O-540, in most cases. I figured on this 3000+
mile loop that I saved over $300 on fuel using LOP cruise.
Do that a few times and you start paying for the
engine rebuild faster too. You also stop less often
so you get there quicker.
Sorry that wasn't all that applicable to the 4-cyl
engine discussion...just an anecdote.
Jesse Saint wrote:
| Quote: | I like the discussion I am reading about this. I agree completely with
to see.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org <mailto:jesse(at)itecusa.org>
www.itecusa.org <http://www.itecusa.org>
W: 352-465-4545
C: 352-427-0285
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *James K Hovis
*Sent:* Monday, October 16, 2006 1:13 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Re: engines
JKH
On 10/16/06, *John W. Cox* <johnwcox(at)pacificnw.com
JWC
<mailto:owner-rv10-list-server(at)matronics.com> [mailto:
<mailto:owner-rv10-list-server(at)matronics.com>] *On Behalf Of *James K Hovis
*Sent:* Monday, October 16, 2006 8:16 AM
*To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
avionic goodies.
JKH
On 10/16/06, *John Gonzalez* < indigoonlatigo(at)msn.com
<mailto:indigoonlatigo(at)msn.com>> wrote:
indigoonlatigo(at)msn.com <mailto:indigoonlatigo(at)msn.com>>
Well said John!
Thank you!
John G. 409
Do Not archive
>Reply-To: rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
>To: < rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>>
>John Cox
<mailto:owner-rv10-list-server(at)matronics.com>] On Behalf Of Robin Marks
>John,
>engines)
>savings.
>Robin
* <http://www.matronics.com/Navigator?RV10-List>*
*_http://www.matronics.com/Navigator?RV10-List_*
*href="http://www.matronics.com/Navigator?RV10-List" target="_blank"> <http://www.matronics.com/Navigator?RV10-List>*
*_http://www.matronics.com/Navigator?RV10-List_***
*href="http://forums.matronics.com/" target="_blank"> <http://forums.matronics.com/>*
*_http://forums.matronics.com <http://forums.matronics.com/>_***
*href="http://wiki.matronics.com/" target="_blank"> <http://wiki.matronics.com/>*
*_http://wiki.matronics.com <http://wiki.matronics.com/>_***
*http://www.matronics.com/contribution*
-- Date: 10/14/2006
10/14/2006
Jack.Phillips(at)cardinal Guest
Posted: Mon Oct 16, 2006 11:00 am Post subject: engines |
OK, now you're beginning to get into an area of real interest to me.
Tim, do you have GAMIjectors to allow you to use LOP operation?
I recently got the engine for my RV-10, an O-540-A1D5 (from an Aztec).
I'm considering converting it to an IO-540 with GAMIjectors just to be
able to save some fuel, running it LOP. I've had at least one RV-10
owner tell me he wishes he had a carbureted O-540 rather than the IO-540
in his plane (he's had real problems with hot starts). The conversion
will cost between $3,000 and $4,000. If I can really save $300 on a
single long trip, it would certainly be worth it. Or should I just
leave well enough alone and put that $3,000 into avionics and keep the
carburetor?
Opinions? (I figure this group has some)
Jack Phillips
# 40610
deutscht(at)rhwhotels.com Guest
Posted: Mon Oct 16, 2006 11:45 am Post subject: engines |
Don't mean to be a know it all however I have a lot of experience
running large Lycomings lean of peak.(and I also stayed at a Holiday Inn
Express last night) We have had good luck LOP if you fly high and/or
keep the power at 65% or less. It is important to have good engine
monitoring system allowing a good read on each cylinder egt and temp.
Just keep all the temperatures well within Lycombing's recommendations
ie cht's below 380* or so. Remember it is temperature not amount of
fuel that will hurt your engine. The trade off for LOP is reduced power
to 65% or less.
Tom Deutsch,
#40545 engine hung and wiring panel
Posted: Mon Oct 16, 2006 11:55 am Post subject: engines |
Phillips, Jack wrote:
Nope, Aerosport just balances the standard ones with their
engines....I believe GAMI does the same thing, but at a higher
cost and Bart will swap injectors for free until you get the
proper ones. Mine are close enough that it runs real well
LOP, but far enough off that some day I'm going to perfect
the 2 or 3 cylinders that are furthest from the center.
| Quote: | I recently got the engine for my RV-10, an O-540-A1D5 (from an Aztec).
carburetor?
Strange...and RV-10 owner with hot start problems? Which FI system?
I have precision, and although you can screw it up and make it
start hard, I've never had anything remotely close to causing
me big headaches. At LOE it amazed some people at how easily
it started cold, and hot starts aren't much worse if done right.
When I flew to Oregon for Van's Homecoming, I figured I saved
a little over $200 or $220 by running LOP. So in the last
month or slightly more, that's $500 in savings for sure.
Obviously if it were me I'd get an IO-540...but if you're really
thinking mogas, then stick with the "oh". I myself am too
squeamish to try Mogas even if I had an O-540, due to the
concept of vapor lock....real or perceived.
As far as saving money to put into avionics....if you want my
possibly un-popular opinion....I'd build the plane EXACTLY
the way you WANT it to be...regardless of the cost being $3000
or even $10000 higher. You don't want to spend $150,000+ on
a plane and still go away thinking you "wish you woulda"...
[quote] Opinions? (I figure this group has some)
Jack Phillips
# 40610
AV8ORJWC
Posted: Mon Oct 16, 2006 12:18 pm Post subject: engines |
GAMI runs an excel spreadsheet to determine volumetric efficiency per
cylinder. Tuned induction and a balanced flow engines make the big
difference. In the Beech F-33 (IO-520BB) we tested, there were only two
differing sizes between six cylinders. EGT similarly at differing fuel
flow rates were the test. It takes a recorder and a pilot. Invest
about an hour and you will have your answers. The goal is not to have
any single cylinder being fried at one time. We ran it at multiple
altitude and flow rates.
My guess is avionics will give the greatest return. However, that said,
I am a big proponent of LOP for individuals with six CHT and six EGT
probes working correctly and a pilot knowing when to richen the mixture.
The GAMI injectors do a quantum leap in efficiency in the Continental
systems.
Do not Archive
Deems Davis
Posted: Mon Oct 16, 2006 12:30 pm Post subject: engines |
I was hot to trot on GAMI and asked my engine builer to add them, He
cautioned me (politely of course) that the biggest benefit from the
GAMI's is to Continental engines. Apparently the Lyc's are more
efficient at burning the fuel as a stock engine. I'm putting in a AFP
fuel system, and they have the same ability to 'tune' their injector
nozzels as does the GAMI.
Deems Davis # 406
Panel/Finishing
systems.
Do not Archive
sschmidt(at)ussynthetic.c Guest
Posted: Mon Oct 16, 2006 1:27 pm Post subject: engines |
I was also interested in the Gami injectors but Bart at Aerosport
steered me away from them. If I remember right, he felt he could
balance them as good or better without the complexity and price. He
didn't feel they offered much. I would just check into it and ask
around.
Here is the truth with all of this, none of it really matters a lot.
They all seem like big decisions when you are planning and building but
when you are flying all you really care about is that the engine runs
great, you have good communication, and the weather is good. I spent
days and days (maybe months or a year) planning my panel, paint, wiring
and interior. When you take off it is nice to have some of the features
but really you are looking outside and having a great time.
I do have some rules that I always follow when buying anything. Always
buy something that is proven (Van's). ALWAYS get the most (approved)
horsepower you can (260 HP). Always plan on 20-30% more than you
thought even though your budget is down to the fifth significant figure.
I live by these rules whether I buy a car, motorcycle, or a plane. I
can't tell you how many people I have had to talk into buying the 1100cc
bike over the 700cc.
Scott Schmidt
johngoodman
Posted: Mon Oct 16, 2006 5:55 pm Post subject: Re: engines |
Wow!
I didn't mean to help start a firestorm, but the discussion has been very enlightening. Obviously, there are lots of trade-offs in the engine department. Frankly, I would be very happy with an IO-540, and will probably get one. The O-540 is a possiblility (I've noticed the hot start issue when I tag along with my brother and his RV formation buddies).
My real concern is the availability of 100LL. It is my understanding that there are only two refineries left in the world that still produce it. What if 100LL becomes as hard to find as whale oil? Also, what are the issues with fuel tanks that were designed for - and only contain - 100LL? Obviously, there would be a run for autogas, and I assume that a way would be found to adapt an IO-540 to autogas. But autogas is a chemical soup that the industry and states feel free to alter on a whim.
The real answer for our generation of flyers is diesel/jetA. That's all I'm looking for - a diesel 540 (g).
GRANSCOTT(at)aol.com Guest
Posted: Mon Oct 16, 2006 6:16 pm Post subject: engines |
In a message dated 10/16/2006 9:59:30 PM Eastern Daylight Time, johngoodman(at)earthlink.net writes:
| Quote: | The O-540 is a possiblility (I've noticed the hot start issue when I tag along with my brother and his RV formation buddies).
I fly behind an O-540 for a number of years and in flying behind the IO-540 also...the IO has occasionally a "re-start" problem if you try to start it in the cold start mode. The O 540 is almost bullet proof in starting.
Lead additive...only one company makes the lead active for leaded gas and their plant is located in the UK. Most O-540 can use regular gas (leaded or unleaded) but if you think you're going to get an alcohol blended gas then you've got to make sure the pump's, lines etc will not be plasticized by the alcohol. Your fuel burn will be high with the alcohol as it's not delivering as many BTU's as pure gas.
Diesel...not too many selections for aviation engines out there in large HP engines. Delta Hawk said they would create a larger engine after the successful introduction of the 4 cyclinder engine. I understand that they have finally begun delivering a few engines...my buddy Pete received his a week ago. But they are really 2-3 years behind where they said there were going to be...but at least they are in some sort of production. Guess you can see if SMA or Theilert can produce an engine in your time frame.
P
acs(at)acspropeller.com.a Guest
Posted: Mon Oct 16, 2006 7:23 pm Post subject: engines |
Good points Scott and congratulations on such a fine turn out of your
aircraft.
John 40315
jdalton77(at)comcast.net Guest
Posted: Tue Oct 17, 2006 5:12 am Post subject: engines |
Jesse,
I agree with everything you said . . . except one little thing
The IO-540 is "almost" the perfect choice. Like any other aircraft engine - it's way too expensive for the average builder. It's does seem to be the perfect technical spec - just too costly to purchase and maintain (overhaul is also obscene).
The rationale on aircraft parts in general, including engines, being so expensive is the liability and insurance that's required for certified aircraft. OK, I'll buy at least some of that. But Lycoming has ignored that concept altogether. While we can buy an airframe for a fraction of the cost of a certified airframe, we are still "stuck" with a "certified" price on an engine.
It couldn't cost so much to build these could it?
Jeff
Posted: Tue Oct 17, 2006 5:44 am Post subject: engines |
I agree that we are stuck paying most of the certified price for an experimental version of the IO-540, and that stinks. I also know that people have tried making aircraft engines that will replace the lycosaurs and have failed. A perfect example is N450HP (Lancair 4P with aluminum block V8 in it) sitting in my shop here after 10+ years of building, waiting for engine, waiting for backup computer, waiting for better gearbox. It still hasn’t flown and the guys that own it have so much stinking money invested in this stinking engine that they can’t afford to take it off and put on a certified engine so they can fly it. I know this isn’t always the case, but there are Continental and Lycoming engine all over the ramp that have a lot of flying hours on them, and just about every small plane A&P knows more about them then about the precious few other engines out there. I like what Superior is doing with their experimental engines, although they are not innovating much, but rather copying designs with small modifications. Again, they are improving a little bit on something very proven. I wish we could buy a 260HP experimental engine with a very proven track record for $20,000, but I don’t see that happening. I know this is going to get a little heat from the Subaru fans, which is fine, but there are roughly 50 RV-10’s flying with IO-540’s and “not nearly as many” with anything else, which is where this whole discussion started. Get a row of Subie-10’s at Oshkosh 2007 and I promise you there will be a lot more people getting on that train.
Now, how to we convince Lycoming that we shouldn’t be paying as much as we are for their experimental engines because they don’t have the certified data tag. Oops, that crazy supply and demand curve is coming back again. I guess the flat answer is, they charge that much because they can and we still buy them. We’re shooting ourselves in the foot (feet?), but are really enjoying the flying!
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jdalton77
Sent: Monday, October 16, 2006 3:08 PM
Jesse,
Jeff
Posted: Tue Oct 17, 2006 6:40 am Post subject: engines |
Reading the previous post to which Jesse replied, I guess I think
part of the issue with the engine purchase choice that I
don't see the total logic in is that a lycoming is
"way too expensive for the average builder". 2 points.
First, so far the "Average RV-10 builder" has put in a Lycoming
IO-540 into their plane. (nothing against you Dan...
Mr. Soobie man. )
Next, I think that many, but not all (yeah yeah yeah, not you
Mr. Bob K with your engine that keeps you out of mac-n-cheese
during the build) alternative engines will be found to eventually
cost just as much to install, with all the mods you'll have to
live through doing.
Then finally, I'd suggest that if someone truly thinks that
a Lyc. is outside of the "average" builders budget, then to me
that's just throwing up a huge red flag that maybe budget-wise
the person got in over their head with the RV-10 project.
So far I'm guessing that the *average* price of the finished
and flying RV-10's is actually OVER the $150K mark. The
RV-10 kit isn't really something I would see the "average"
person building...I'd think that most of us are a bit
above average if we can consider building an RV-10. The
average person where I live, lives in a family with about
a 40-45K/year family income...certainly not something that
will allow them to build an RV-10 in most cases. I feel this
3rd point is an important one because people really need to
know what they're getting into when they start the kit, and
it is truly not something everyone can or should try to afford.
Looking at the homebuilt market as a whole, I'd say the
"average builder" would be looking more towards buying an
RV-9 kit or maybe even less, from a cost perspective. The RV-10
will never be built...dare I say never EVER be built, for costs
similar to planes like RV-9's. One good comment I saw this
week was to plan for at least $20-30K more than you expect...
or was it 20-30%. I can say that until I actually had every
avionics item, paint, interior, and other item figured out
and priced (maybe just under 1 year from completion of the kit)
I had steadily been finding these unexpected things and
didn't have a predictable total...and it was probably $40-50K
beyond what I Initially figured my minimum build cost could
be...and $30-40 above my initial *expected* build cost. But,
to get what you want you sometimes have to adjust your
goals accordingly. Despite what you see invested in my panel,
my total cost is probably not actually that far out of whack
from what an "average" RV-10 will cost...for many reasons.
My guess is that a recently starting build may very well
end up spending within $10,000 to build an "average" RV-10.
But, averages are built on bell curves....so far most of
the completed RV-10's are probably very near center of the
curve for what you'll see when there are 100 or 200 of
them flying.
Lyc's are a big hunk of cash, no doubt, but in the overall
scheme of things, you're not going to save huge percentages
of the total cost by doing anything different. (Except
for you Bob K. )
Jesse Saint wrote:
[quote] I agree that we are stuck paying most of the certified price for an
Jesse Saint
I-TEC, Inc.
W: 352-465-4545
C: 352-427-0285
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *jdalton77
*Sent:* Monday, October 16, 2006 3:08 PM
Jesse,
Jeff
BPA(at)bpaengines.com Guest
Posted: Tue Oct 17, 2006 7:05 am Post subject: engines |
The cost of a new Lycoming C4B5/D4A5 in certified status EXCHANGED is almost 50 grand according to Lycoming 2006 pricing index. If no engine core is available to swap out with them, you have to add the core value, driving the cost over 60 thousand dollars. Lycoming won’t even sell an overhauled engine without a core return. This is because the core market has dried up.
The experimental kit engine on the other hand is certainly a better option cost wise, the down side being of course that it cannot be certified even if maintained as such. The advantage is the shops that build these kit engines have the capability to ‘tailor’ the engine to your needs (within reason). There are lots of options to enhance the performance of the engine that don’t come in a certified factory engine. Balanced rotating assemblies, re-worked cylinders, options on accessories, higher compression just to name a few. The list goes on and on…….
Liability is a factor in any business whether it’s for profit or non profit (although who’s in business NOT to make a profit), big shop or small. Just because the engines are experimental does not lessen the liability on Lycoming’s part. They are just as responsible whether it’s certified or experimental. The overhead to operate these engine shops would shake you to your boots! Take a look for a minute. You have an employee with 30 years of time invested in your company. He expects a return for his investment (good wage, benefits) and rightly so, just as production is expected from them. Multiply this by 6,500 employees as in the case of Lycoming and other big manufacturers. Add to this the cost of having organized labor, and you quickly add 30% to your overhead. Utilities, taxes, wages, insurance both health and liability, freight, all add to the cost of the product. This is one reason Lycoming out sources where in years past all manufacturing was done in house. Now we get back to the liability (again). Because of out sourcing the manufacture of parts, quality control suffers because you can’t keep as tight a reign on it, which in turn raises the cost of liability. It is a viscous cycle that seems to get bigger and bigger.
Allen Barrett
Barrett Precision Engines, Inc.
www.barrettprecisionengines.com
dlm46007(at)cox.net Guest
Posted: Tue Oct 17, 2006 7:57 am Post subject: engines |
One should use the rule of threes on any aircraft project. Take the cost of
the airframe kit including the freight to get it to you, then add that cost
again for engine and prop, and again for avionics and finishing. The cost of
the airframe (QB) is 45-50K so triple it and you have the final costs to
have a decent flying machine. Same calculation works for two place kits.
