michele.delsol(at)microsi Guest
Posted: Tue Jan 24, 2006 11:00 pm Post subject: Alternator output wire size |
Hi all =96 I have been following this list for some time mainly to educate
myself as to putting together the electrics on my RV8, now at the canoe
stage. I purchased Van=92s harness, figured it would give me a head start but
I find that I question some of the choices made, namely the size of the
Alternator output. Am planning on a 40amp alternator, aft mounted battery.
Vans has chosen #8 awg =96 if I look at BK=92s figure 8-4 on temp rise vs wire
size, I read 21 amps for a 10=B0C rise and 40amps for 35=B0C rise. Since I shall
be running a 40amp alternator I figure that 35=B0C is too much since the wire
will be bundled with others =96 I=92d be better of with a larger wire. If I put
a #6, temperature rise at 40amps is somewhere around 20=B0C.
My question to you guys who have been there : should I go for #8 or # 6?
Mich=E8le
nuckollsr(at)cox.net Guest
Posted: Wed Jan 25, 2006 5:37 am Post subject: Alternator output wire size |
At 07:59 AM 1/25/2006 +0100, you wrote:
<michele.delsol(at)microsigma.fr>
shall
I put
If you're worried, go #6. The operating temperature limit on Tefzel
is 150C. See:
http://www.aeroelectric.com/Reference_Docs/Mil-W-22759/22759slash16.pdf
The time you're alternator will spend at 40+ amps is measured in
| Quote: | Thanks,
Mich=E8le
< with experiment. >
< --Lawrence M. Krauss >
Posted: Wed Jan 25, 2006 5:41 am Post subject: Alternator output wire size |
shall
I put
is 150C. See:
The time your alternator will spend at 40+ amps is measured in
minutes per flight cycle and usually happens in the first few minutes
of flight while recharging the battery. What's the hottest environment
that the wire will traverse? For a 35C rise, you can operate in a
150-35 or 115C environment indefinitely. For the vast majority of
the time, your alternator will be running much less load.
I don't think the #8 wire selection is a really big concern.
klehman(at)albedo.net Guest
Posted: Wed Jan 25, 2006 5:50 am Post subject: Alternator output wire size |
Hi Mich
I used 8awg for that. In practice the 40 amps is seldom there for very
long although I guess it could be considered continuous in some
circumstances as you have observed. I've noticed that several folks have
used 8awg with even larger alternators although I would not.
I think you've got html turned on in your mail program which puts those
numbers in your posts here (at least on my computer) and makes them
somewhat difficult to read.
Ken
Michle Delsol wrote:
Mich=E8le
Dan.Beadle(at)hq.inclines Guest
Posted: Wed Jan 25, 2006 9:42 am Post subject: Alternator output wire size |
The SIGNIFICANT current from the battery to the front end of the
aircraft is the starting load - this is normally 5-10x the alternator
sizing.
Once the aircraft has started, most of that 40A alternator output is
going to the main buss and all of the loads (lights, radios, etc.).
Recharging the battery is only one of the loads. If you look at an
aircraft with a load meter, a discharged battery only gets about 1/3 of
the total alternator output. Once the battery is re-charged from the
startup procedure, there is very little current flowing back there.
So, I wouldn't worry so much about steady state currents to the rear of
the aircraft. I would worry more about the starting currents over that
wire and the voltage drop. If you pull 80Amps during startup (cold
engine), there can be significant voltage drop through the wiring,
causing less voltage to the starter for slower RPM and harder starts....
Dan
Posted: Wed Jan 25, 2006 11:39 pm Post subject: Alternator output wire size |
Thanks Ken and Bob - 8awg wins hands down - and I'll turn off HTML.
Michele
