		ray.stlaurent(at)vsea.com Guest
				 Posted: Fri Oct 20, 2006 7:09 pm    Post subject: RAC stick wiring question |
				I was looking at the Y control stick and my RAC stick grip and realized I
 haven't a clue how to get the wires safely out of
  the stick and keep them from being tangled. I've seen pictures but never
 where the wires went.
 - Ray St-Laurent
 701/Pegasus wings/Suzuki
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dredmoody(at)cox.net Guest
				 Posted: Sat Oct 21, 2006 6:43 am    Post subject: RAC stick wiring question |
				I haven't done my dual sticks for the Zodiac yet but when I did a Ray Allen
 grip with four trim buttons and a ptt on my ultralight, I was concerned
 about the delicate fine wires too. Find a hobby store or an aquarium supply
 place and buy some clear plastic tubing just barely big enough to draw the
 wires through. You may have to run a single "fish" wire through it first to
 pull the Ray Allen wires through. The tubing will protect the wires around
 tight spots and bends and clear tubing allows you to see the inside to
 monitor the inner wires as the plane ages.
 The other option is to make the splice to the whatever multistrand cable you
 use such that it ends up inside the stick tube. If you do that you have to
 leave enough slack in that multistrand cable to run it out of the top of the
 stick, do the connections and heat shrink, then pull the whole mess back
 down to mount the grip. The ecess has to be secured somewhere out of the way
 in case you need slack to repair or replace later.
 Ed Moody II
		Tommy Walker
  Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
				 Posted: Sat Oct 21, 2006 9:05 am    Post subject: Re: RAC stick wiring question |
				Also, I plan to drill a small hole near the bottom of the yoke, install a grommet and route the wires through that grommet to prevent wear at that point.
 Tommy Walker In Alabama
  	  | dredmoody(at)cox.net wrote: | 	 		  I haven't done my dual sticks for the Zodiac yet but when I did a Ray Allen
 Ed Moody II
  _________________ Tommy Walker
N25A  -  Anniston, AL |
		NYTerminat(at)aol.com Guest
				 Posted: Sat Oct 21, 2006 8:52 pm    Post subject: RAC stick wiring question |
				This is exactly what I did and it worked out quite  well. I used the Ray Allen 7 switch grip.
  Bob Spudis
  CH701/ 912S  85hrs
  In a message dated 10/21/2006 10:44:37 A.M. Eastern Daylight Time,  dredmoody(at)cox.net writes:
   	  | Quote: | 	 		  The other option is to make the splice to the    whatever multistrand cable you
		RayStL
				 Posted: Sun Oct 22, 2006 9:16 pm    Post subject: Re: RAC stick wiring question |
				Thanks for the ideas guys. I'll have the wire bundle exit the yoke, through a grommet, just under the hinge  to minimize the cable movement.
  _________________ Ray St-Laurent
701/Pegastol wings/Suzuki engine |
