n8vim(at)arrl.net Guest
Posted: Sat Oct 21, 2006 4:33 pm Post subject: What Wire for Wiring? |
Hey Y'all!
What type of wire should I use for wiring? Teflon? Tefzel? Tin
coated copper? silver coated copper?
I looked at wiremasters.net, and it appears that for 14ga. Tefzel, the
length is 1,200ft. I'm quite sure I don't need THAT much, especially in
only one color. (What am I doing wrong?)
Also, does anyone have an initial "shopping list" of wire that you
bought to start off with? Would you mind sharing it?
-Jim 40384, deburring bottom wing skins
rene(at)felker.com Guest
Posted: Sat Oct 21, 2006 4:42 pm Post subject: What Wire for Wiring? |
I ordered mine by foot from Stein.
http://www.steinair.com/
Rene'
40322
N423CF
Finish Kit and a lot more.......
801-721-6080
Tim(at)MyRV10.com Guest
Posted: Sat Oct 21, 2006 5:10 pm Post subject: What Wire for Wiring? |
For most things, Tefzel. Also, wiremasters.net will send you whatever
lengths you want (at least they did for me). Buy extra, it's cheap.
Your needs will vary greatly if you are going to wire your own
panel. Plan ahead, and determine loads for things like landing
lights and such, and add up all of the different wire lengths
you'll plan to run to each area of the airplane. Don't be afraid to
order an extra 100 or 200' of the most common sizes or even some
of the others. You'll find wiremasters has great prices, and if you
run short after your initial order and needs small quantities from
some other place, you'll find the price much higher...so better to
spend it initially with good planning..
James Hein wrote:
Hey Y'all!
What type of wire should I use for wiring? Teflon? Tefzel? Tin coated
AV8ORJWC
Posted: Sat Oct 21, 2006 6:55 pm Post subject: What Wire for Wiring? |
James, If you decide on the full spool, let me know your surplus. I am
getting a passion for used tools, and supplies. I think there is a
market. One of our mechanics at work used to be a Snap-On dealer and is
unloading $20,000 of left over product.
The question will be is that Snap-On retail pricing or dealer cost. I
will post if the prices are reasonable.
Your wire pursuit interests me. Continue the hunt.
John Cox 40600
Do not Archive
dlm46007(at)cox.net Guest
Posted: Sat Oct 21, 2006 8:22 pm Post subject: What Wire for Wiring? |
[quote] For the guy who originally asked the wiring question.......
You should try and standardize on a few sizes and buy that in quantity of
100 ft or 500 ft spools. Obviously you will need no more than 20 ft of 002
for the starter to battery contactors. The aircraft mechanics handbook
which
is a good reference for a lot of subjects, has diagrams for the load
carrying capabilities of the various sizes in free air and in conduits.
You
want to be able to carry at least 300A in the starter circuit.
I bought 3 sizes besides the 002; they were 8, 14,20 . These were standard
aircraft wiring. I also bought several short spools of size 22 shielded
pairs, triplets and quads. These come in handy when you want to reduce the
chance of RFI in things like magnetometers, digital lines to servos,etc.
you
will also probably need to buy a 50-100 ft piece of RG400 for the
antennas.
Another consideration is segregating the digital lines from the heavy DC
or
pulsating DC where possible. For example in my aircraft the starter wiring
passes through the left side of the aircraft, while the trim, AP servo
harness, GADAHRS harness, magnetometer, OAT circuits are down the right
side.
Another consideration is switchable breakers for operating the appliances
and pullable breakers for all other items. A little more expensive but
simple because every appliance has its own bus position. Bus bars can be
made from copper strips purchased from Aircraft Spruce. They are .5" x
.125"
x 24". Buy drilling holes at regular intervals along the copper bar a very
low resistance distribution of bus voltage is achieved.
I tried the picture and it did not come through, email
me directly if you want a picture.
> Do not Archive
Posted: Sat Oct 21, 2006 8:27 pm Post subject: What Wire for Wiring? |
whichis a good reference for a lot of subjects, has diagrams for the load
[quote]> carrying capabilities of the various sizes in free air and in conduits.
> You
> standard
> the
> you
> antennas.
> or
> wiring
> side.
> .125"
> very
>> Do not Archive
stein(at)steinair.com Guest
Posted: Sat Oct 21, 2006 9:05 pm Post subject: What Wire for Wiring? |
Hi James,
Stick with the standard M22759/16 Tefzel wire...don't bother with teflon,
silver plated, etc...or surplus stuff (you never know what you're getting).
Also, if you spend more than a few hours "hunting" for a deal, you've just
wasted enough time to buy what you want and what you need brand new.
Depending on what you're doing with the plane and panel, buy at least the
following initially:
200' AWG22
200' AWG18
150' AWG16
50' AWG20
50' AWG14
25' AWG12
25' AWG10
100' RG-400 Coax
a dozen male BNC's, a half dozen female BNC's, a couple hundred PIDG ring
terminals, and some heatshrink.
Now, depending on if you want colors or not you can split all that up. The
above wiring amounts could vary pretty significantly depending on if you're
wiring your own panel or not, whether you're going full boat on lighting,
radios, IFR/VFR, etc.. I wouldn't waste my time buying whole spools then
trying to sell the surplus. Heck, wire is relatively cheap, we're talking
about something that costs pennies per foot...you'll only spend a couple/few
hundred bucks of wire total. Why waste your time goofing
around.......figure out what you need, what colors you want and just buy it.
As someone who regularly buys wire in 10,000' - 20,000' spools and keeps
over a half million feet of wire "hanging around", I can tell you playing
with spools to save a few percent is a waste of time on an item like this,
for one airplane. With your Avionics or engine it's a different story
because you can save a lot of dough, but in the wiring it's such a cheap
item to begin with that it's not worth much effort to save a buck.
Just my 2 cents as usual!
Stein.
Posted: Sun Oct 22, 2006 5:07 am Post subject: What Wire for Wiring? |
Stein gave some good info below, but I think his quantities on the
wires are way short for most RV-10's.
My initial order was:
100ft EACH of 7 different colored wires 22 ga
300ft white 22ga
300ft white 20ga
500ft white 18ga
100ft white 16ga
100ft white 14ga
100ft white 12ga
Things I can't find right now were how much twisted pair shielded
wire I got.
I think I got 200' of triplet wire and probably 300' or more of
single pair shielded. If you're not doing your own panel or
harnesses for avionics, a lot of this could change greatly, but
I don't have a lot of wire left over. Also, the lightweight
purists would gasp, but there were times where I ran out of things
like 18ga, so I ran a 16 (I think I ordered some 10ga and maybe
some additional 12ga later), and I think I ran 12 in place of 14
on a run too, rather than re-order wire. Wire is bought cheaper
in quantity than in short sections, and you're better off ordering
much more than you need than paying additional shipping charges.
I didn't have mine as well planned as I should have when I ordered
the wire.
Stein has great prices on heatshrink and ring terminals too, so
if you're doing your own panel I'd highly recommend Stein's
ring terminal KIT. Beyond that, you may want to add some additional
terminals to it. I have some extras left over for sure, but
it was very nice to just dig into the kit and have them there
rather than try to order the exact quanity...and the kit had
it's own separation sections. I ordered at least 25' of
3 or 4 different sized heatshrink. Stein's prices are great
on that, and I find it useful on other projects too.
Stein is right that it wouldn't at all pay to buy large
spools and sell it off later. Just buy some good round
numbered lengths and try to overestimate. You'll be
surprised how cheap wire actually is. My first order was
just over $200, and then I added some of the shielded pairs
and RG-400, but I'd be surprised if my total wire outlay
was over $400 or $450. It's pretty much insignificant
in the cost of the plane. (Heck, anything under $1000 is
nothing to the RV-10).
Sticking with white wire will make it easier to put together
an order for the proper amounts. Some people like to use
1 color for signals and hots, like Red for hots, white for
signals, and black for grounds. Some people like to use
multiple colors for things to make them more traceable.
If you're building your own AP harnesses, then it is kind
of nice to buy separate colors for those, which is what I
used some of my 100' lengths of colored on. I also used
some red and black throughout the panel. For the most part
though, I used white. Buy some skinny heatshrink to put over
wire labels.
While you're at it, if you're getting wire or anything
else from Stein, pick up a bunch of tools. His prices
were great on those too. If you do your own antenna wires,
get the RG-400 crimper and definitely get his side cutters. The
large cutter he sells works awesome on #2 welding wire.
As far as antenna connectors for that RG-400, check your
antennas. I found I also needed 4 or more TNC connectors,
as well as BNC. The WSI and the GNS-480 use TNC.
Oh, and if you're going to go with some fuses and some breakers,
Stein has good prices and selection on the fuse panels and fuses.
Can you tell that once you start wiring you've opened the
box? It's a lot of miscellaneous stuff, but you'll
absolutely save some money doing it, and go away with some
cool tools for your toolbox too. (Or sell them to the next
guy)
Stein Bruch wrote:
Hi James,
200' AWG22
200' AWG18
150' AWG16
50' AWG20
50' AWG14
25' AWG12
25' AWG10
100' RG-400 Coax
Stein.
wv4i(at)bellsouth.net Guest
Posted: Sun Oct 22, 2006 5:17 am Post subject: What Wire for Wiring? |
Take a look at www.AeroElectric.com articles, etc... Huge library of
articles, how to's, schematics, reference info. Aircraft wiring....want
stranded wire of proper gauge for anticipated load(s) and length, and
properly breakered to protect the wire (yes, the wire,,,this will spur
discussion, I'm sure), with a non-toxic insulation,
i.e.teflon/zel/whatever (when hot or on fire)...beyond that, the
considerations and options go forth....
Link Mcgarity
RV10/#40622 elevator
RV6/N42GF/flying (all new instrument panel, and wiring thereto in 2004)
jwt(at)roadmapscoaching.c Guest
Posted: Sun Oct 22, 2006 7:13 pm Post subject: What Wire for Wiring? |
Jim.
Strongly recommend you get and read the Aeroelectric Connection by Bob
Nuckels. Also Stein at SteinAir has been incredibly helpful to me and sells
wire by the foot. If you email me direct I can give you some other
resources.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Finish kit - wheel fairings, wiring panel
AV8ORJWC
Posted: Sun Oct 22, 2006 7:55 pm Post subject: What Wire for Wiring? |
Okay Tim, I'll bite. What is your price for the sale of your cool
wiring tools? I am ready with Cash $$.
You were kidding?? Oh, Okay, can you list the cool electrical wiring
tools you won't sell as a start point for beginner's.
Posted: Mon Oct 23, 2006 3:25 am Post subject: What Wire for Wiring? |
You're correct to assume I'm not parting with any electrical tools.
Riveting tools some day may go (I doubt it) but electrical, never.
I use them all the time for other projects.
But, here's a good list for you since it's basically most of them.
http://www.steinair.com/tools.htm
