dave
Posted: Sat Oct 21, 2006 2:55 am Post subject: Guy --- Re: Warp Drive Hub |
Guy, please post some pics of the Exhaust There is a length in the Rotax
manual for length from exhaust port to the muffler including the cone( that
is the part that Skystar modified with a few bends as well as chopping off
about 1 " or so of the y pipe manifold but if does seem to work ok.)
Timing etc -- call Rotax Bob Robertson. I have called him for advice many
times and it always free but keep in mind I buy all rotax stuff from him as
well.
I think I read that your engine sat idle over 10 years during build time ?
Possible issues there like crank seals but ask Bob.
Your prop sounds way over propped at your 13 degree setting. What was it
at before you changed it ? . I don't measure my WARP with degrees but set
all the blades all the same. I did measure last week though and I think it
was around 10 degrees or so at the tip . Yours being a 2 inch large dimater
I would stay closer to 10 degrees. ( mine is 68" ) I set by RPM and how
it works but I think WARP should be 10 to 11 degrees area. I used the Warp
protractor thingy and re pitched to all the same. I think I made it 1/2
degree finer approx. and my static went from 5850 5900 to 6150 - 6200 and
my in flight WOT went from 6600 to 6900 or so. I also dropped the clip
on carb needles one notch to the bottom notch so it all the way rich now.
and egts have come down from 1200+ to 1100 or a bit less in cruise.
Temps here are average 30F to 45F degrees this week. and our elevation is
about 950 asl.
I would set your prop to give 6200 to 6400 rpm static to start and
coarsen it about 1/4 degree at a time from there as needed. Assuming you
have stock jetting ( I think the needle is a 11G) the clip should be on
second notch from bottom of needle but if EGTS get over 1200 in cruise I
would drop one more notch. I think you said that you have some EIS or
engine gauges etc ? How is the impulse achieved ? A tiny tach will
confirm or an optical tach that your gauge reading is infact accurate.
Tiny Tach --order one from Bob when you call him and he will send out
overnight. EGT confirm it by the look of the spark plugs.
Do you have another 582 owner near you with allot of experience? I would
get him over to help you out as well is possible. Personally I Think you
are getting in way to deep on the technical stuff and you have most likey
some simple issues here to resolve.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Guy Buchanan
Posted: Sat Oct 21, 2006 6:53 am Post subject: Guy --- Re: Warp Drive Hub |
At 03:55 AM 10/21/2006, you wrote:
| Quote: | Guy, please post some pics of the Exhaust There is a length in the Rotax
I couldn't find this. Do you have it?
| Quote: | Timing etc -- call Rotax Bob Robertson. I have called him for advice many
well.
Good idea.
| Quote: | Your prop sounds way over propped at your 13 degree setting. What was it
I had it at 12 degrees.
| Quote: | I don't measure my WARP with degrees but set
about 950 asl.
Thanks for this info. It's very helpful. My previous WOT was 6550. Maybe it
would help to bring it up closer to 6700.
| Quote: | A tiny tach will
I have an optical tach and have confirmed the RPM readings on the GRT EIS
are accurate.
| Quote: | Do you have another 582 owner near you with allot of experience? I would
Man I've got hordes of people with lots of experience, probably too many,
as I get lots of opinions! I'm looking for hard data, like yours. All the
anecdotes get contradicted with every new opinion!
| Quote: | Personally I Think you
Nah. The technical stuff is fun. I'm learning a lot. I'm even going to
write my own prop optimization software when I get the time. I agree my
problems are probably simple, (excess drag, inadequate horsepower,) but
it's a learning experience to chase them down, and you'd be surprised how
hard it is to compile useful comparison data; there are so many variables.
Thank you for your patience and assistance. I really do appreciate it. I
know if I bug everyone enough I'll find the piece of the puzzle I'm looking
for.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
dave
Posted: Sat Oct 21, 2006 7:46 am Post subject: Guy --- Re: Warp Drive Hub |
Guy, go to page 25 section 10
http://www.rotax-aircraft-engines.com/pdf/dokus/d00287.pdf
But Like i said before you are getting a clouded vision of a simple
problem of prop setting.
Keep in mind Props like your are being used successfully on many 582s so
thinkiing about writing software etc is not necessary in my opinion.
We are talking proven designs and props here so no needto re-invent the
wheel .
I just in from flying last 2 hours. did about 10 take offs and landings
when i got back ..... and all were 150 to 200 feet at th most
wind about 3 knots or less temp 5 C elevation 950 '
Warp set at 6200 static. cruies at 5800 85 to 88 or so at 500 agl
Dave
Guy Buchanan
Posted: Sat Oct 21, 2006 5:34 pm Post subject: Guy --- Re: Warp Drive Hub |
At 08:44 AM 10/21/2006, you wrote:
| Quote: | I just in from flying last 2 hours. did about 10 take offs and landings
Dave,
I timed your Kitfox video and got about 7.2 seconds from first
motion to obvious vertical motion. This works out to about 212' to 40mph. I
timed my early morning take-off today at 8.66 seconds. (A little crude
since it's hard to fiddle with the watch while taking off!) This works out
to 254' to 40mph. I'll have to check my measurements, since 254' is not
near as bad as the 540' I originally estimated.
Guy Buchanan
Deceased K-IV 1200
dave
Posted: Sat Oct 21, 2006 5:51 pm Post subject: Guy --- Re: Warp Drive Hub |
Guy --
Put away the slide rule and pace out 100 feet intervals at 100 200 300 400
feet or what ever you llike .
When you break ground you will know where you leave and it not a vidoe cam
will catch it .
I got a few clips today -- let me see if i can get clip put together for
you shorty.
Dave
PS CONGRATS on breaking into the under 300 foot club-- sure beats 700 to
1000 feet eh !!
Guy Buchanan
Posted: Sun Oct 22, 2006 7:50 am Post subject: Guy --- Re: Warp Drive Hub |
Dave,
Thanks for the reference. This is much better than the old thing I
received with my engine.
Guy Buchanan
Deceased K-IV 1200
