kearney(at)shaw.ca Guest
Posted: Sun Oct 22, 2006 7:48 am Post subject: Torque Wrenches |
Hi
I have been reading the archives regarding torque wrenches. Section 5 of the builder’s manual refers to torque specifications from 20 – 1500 in-lbs for AN bolts AN3 – AN10. My empennage kit only has AN3 & 4 bolds which implies all I need for now is a wrench that will do 20 – 70 in-lbs.
My question is: what is the largest bolt size I will have to deal with on the RV10. Is there a recommended torque wrench size? If I want to cover off the requirements of Section 5, it looks like I will ultimately need at least two torque wrenches. Is this really the case?
Inquiring minds need to know.
Les Kearney
Rv10 # 40643 – still awaiting tool order
bcondrey
Posted: Sun Oct 22, 2006 10:56 am Post subject: Re: Torque Wrenches |
The vast majority of the bolts are AN3 and AN4 size. There are some larger size bolts to hold on the engine mount, wings, wheels, etc. IIRC, the largest is AN7.
You will indeed wind up with multiple torque wrenches.
Bob
Tim(at)MyRV10.com Guest
Posted: Sun Oct 22, 2006 4:11 pm Post subject: Torque Wrenches |
You'll need a big one (1/2") for the prop and a few
things. You'll need a medium one (3/8") for a few
duties like spark plugs and such. You'll find a lot
of use for an inch-lb small one (1/4") for doing your AN3's
and AN4's. So really, if you wanted to be perfectly
prepared, I'd start shopping for good deals early.
Les Kearney wrote:
| Quote: | Hi
Les Kearney
jesse(at)itecusa.org Guest
Posted: Sun Oct 22, 2006 4:31 pm Post subject: Torque Wrenches |
I have one each of the two that Avery sells (the plastic-handle CDI's). The
small one is used mainly, but the big one will be needed for engine mount,
engine install, wing install and prop install. Those few are probably
important enough to get a good one, although you could also borrow one for
that need, I reckon. Did I just say, "I reckon?" Man, I have been out of
MN and in FL too long, ay Tim and Stein? (answer, "Ya sure, you betcha!")
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Posted: Sun Oct 22, 2006 5:06 pm Post subject: Torque Wrenches |
Tim / Jessie
As we would say in Newfoundland, "lovely tell yer mudder". I get to buy a
couple or three torque wrenches! Maybe I'll just find another -10 builder
and steal theirs when they are not looking. Oops, did I just say that out
loud!
Thanks for the info, any excuse to buy more tools.
Cheers
Les Kearney
Rv10 # 40643 - still awaiting tool order
wv4i(at)bellsouth.net Guest
Posted: Mon Oct 23, 2006 4:33 am Post subject: Torque Wrenches |
You'll need in-lbs and ft-lbs. Drive sizes can be accommodated with
adapters, although with extensions you technically incur a correction
factor, math. Source. Get good ones. Harbor Freight, avoid re Q
wrenches, IMHO.
Link McGarity
#40622
Mike Whisky
Posted: Sun Feb 10, 2008 3:05 am Post subject: Jaw Wrench for Torque Wrenches |
Hi,
I saw somewhere in the forum quite some time ago pictures of jaw wrenches or extensions for a torque wrench. Does anyone know where to order these.
I Have some nuts that can't be reaches with the torque wrench nut.
Michael
_________________ RV-10 builder (flying)
#511 |
Posted: Sun Feb 10, 2008 4:43 am Post subject: Torque Wrenches |
Hmmm. Might you be talking about 'crows foot' wrenches???? Little
wrench ends with a hole for a 1/4 or 3/8 drive???
For our needs, a set from Harbor Freight will do just fine. Sears has
them, and I'd look in Ace too.
Linn
Michael Wellenzohn wrote:
Hi,
Michael
RV-10 builder (engine, prop, finishing)
#511
http://forums.matronics.com/viewtopic.php?p=163269#163269
Mike Whisky
Posted: Sun Feb 10, 2008 5:00 am Post subject: Re: Torque Wrenches |
Yes "crow foot" wrench is the word, thanks. I'll try to find out if they also ship to Europe.
Michael
#511 |
ScooterF15
Posted: Sun Feb 10, 2008 8:52 am Post subject: Torque Wrenches |
You might just try putting a bolt through one end of an endwrench. Might save you some time waiting for delivery in Europe. Here's picture:
http://forums.matronics.com/viewtopic.php?t=7379&highlight=wrench
-Jim
In a message dated 2/10/2008 8:07:05 A.M. Eastern Standard Time, rv-10(at)wellenzohn.net writes:
| Quote: | --> RV10-List message posted by: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Michael
#511
http://forums.matronics.com/viewtopic.php?p=163276#163276
Who's never won? Biggest Grammy Award surprises of all time on AOL Music.
Posted: Sun Feb 10, 2008 11:11 am Post subject: Torque Wrenches |
That may solve your problem Michael, especially if you looking to torque your prop...a crowsfoot would not allow me to tighten my prop nuts, I borrowed a Snap-on torq wrench with an open end adapter made just for that from a local A & P....it cost him $400!!!!. But as always, the right tool for the right job does wonders....Jim's idea is pretty trick.
Rick S.
40185
drfred(at)suddenlinkmail. Guest
Posted: Sun Feb 10, 2008 12:26 pm Post subject: Torque wrenches |
Michael
I want to echo Rick and Mr. McGrew. I have a set of the crows foot
wrenches and have yet to be able to use them to torque _any_ of the hard
to reach places. I made up an open end wrench and used them. The
calculator really helps.
Rick:
I'm getting to the point of doing the doors. I saw your comments on the
vansairforce site. Is the set of recessed handles on ebay the ones that
are compatible with a lock? I wasn't real clear on that point.
Also, when my friend broke his wheel pants on his RV 10, I had my dad
make up two sets of the beefed up extensions and I now have an extra
set. I already have a pair installed. Does anyone want them for
$60??
Fred Williams
903 491 5207 cell
dlm46007(at)cox.net Guest
Posted: Sun Feb 10, 2008 12:50 pm Post subject: Torque Wrenches |
You an make the tool for about $20 to torque the prop. Buy a good quality open ended wrench, 3/4" IIRC. heat and create an S with the wrench. Then weld a short 3/8" socket adapter on the center of the wrench. Torque wrench is inserted into the adapter and open end wrench goes tot he prop nut.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked
Sent: Sunday, February 10, 2008 12:07 PM
Subject: Re: Re: Torque Wrenches
Rick S.
40185
Posted: Sun Feb 10, 2008 3:41 pm Post subject: Torque wrenches |
Fred,
Yes the ones FS on Vansairforce/E-Bay are the ones with the built in lock...make sure you get the cylinders with them, his picture shows them removed.
Rick Sked
40185
Posted: Sun Feb 10, 2008 3:46 pm Post subject: Torque Wrenches |
Also, The web RV guru on the -7 side of world (and one of the best sites for all RV's) Dan Checkoway shows how to fabricate on that will work as well....search Dan's site. His idea is neat too..
Mike Whisky
Posted: Mon Feb 11, 2008 10:14 am Post subject: Re: Torque Wrenches |
Great,
thanks you all for your advice!
Michael
#511 |
