pcasson(at)sasktel.net Guest
Posted: Sun Oct 22, 2006 6:21 pm Post subject: Vans wiring kit - mods for fuel injection |
Hi All,
The Van's RV-10 wiring harness kit is designed for a carbureted engine with a boost pump. I'm
installing a fuel injected engine so need to make some modifications. It looks as if the easy thing
would be just to install a 10A breaker and upsize the wire to convert the boost pump circuit to a
injection pump circuit but is that really what is best? Seems to me we want that pump running as
long as the ignition switch is in a run position and not switched with the master on/off. Like to
hear what others are doing.
Perry Casson - still wiring....
Regina, Canada
jesse(at)itecusa.org Guest
Posted: Mon Oct 23, 2006 4:32 am Post subject: Vans wiring kit - mods for fuel injection |
The kit comes with (or at least used to) a switching breaker (5A) for the
boost pump. For Injected engines, you need a 10A. You can just switch out
the breaker and change the size of wire, if necessary, based on the amperage
and the length of the run. You don't ever, that I can think of, need the
boost pump when the master is off, and you mainly just use it for startup
when the master is on, of course. You definitely do not want to run it all
the time when the ignition switch is in the RUN position. Just a breaker
would certainly not be the way to go, even if it is a push/pull breaker.
You want a switch, but again, that is what the kit comes with. It just
happens to have the breaker in the switch as well (switching breaker) to
keep things simple.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Posted: Mon Oct 23, 2006 5:39 am Post subject: Vans wiring kit - mods for fuel injection |
So I think you are telling me somewhere on the large lump in the corner of the shop (aka io540) is a
mechanical fuel pump and the electric one is just a backup? I guess I better read that stack of
manuals and ask questions less....
I guess I've missed a step in technology between carbureted C150's and EFI where everything is
electric.
Perry Casson
Posted: Mon Oct 23, 2006 9:44 am Post subject: Vans wiring kit - mods for fuel injection |
Perry Casson wrote:
So I think you are telling me somewhere on the large lump in the corner of the shop (aka io540) is a mechanical fuel pump
Yup
| Quote: | and manuals
Maybe, but probably not
| Quote: | and ask questions less....
Definitely a NOT!!! It's how we learn. We're not born with knowledge,
just survival instinct. Everything we learn, we learn from others
..... well, mostly ..... we do learn from doing stupid things .....
hmmmmm maybe I'm stretching this a little
| Quote: | I guess I've missed a step in technology between carbureted C150's and EFI where everything is
electric.
Oh yeah! I find it amazing that the Feds keep harping on safety ....
safety .... safety ..... and yet they still prevent a certificated
aircraft from enjoying the technology advances since the stone age. I
really believe that electronic ignition (EI) coupled with electronic
fuel injection (EFI) would be a huge step forward in making our engines
more fuel efficient and prevent high cylinder temps on takeoff etc. EI
would eliminate fixed firing advance and EFI would take care of the
changing mixture requirements. But, I guess I tend to dream too much.
Maybe when I have more time to fiddle .....
Linn
Perry Casson
james.k.hovis(at)gmail.co Guest
Posted: Mon Oct 23, 2006 11:34 am Post subject: Vans wiring kit - mods for fuel injection |
The Feds are still in the stone age when alternators/generators lived extremely short lives and batteries tended to discharge fairly quickly due to the high draw from old-style electronics. Modern EFI systems have minimal draw compared to landing lights, etc. Batteries today have AHr ratings for the wieght unheard of 30 years ago. There's NO REASON for not using electronic engine monitoring/management.
On 10/23/06, linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)> wrote: [quote]--> RV10-List message posted by: linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
Perry Casson wrote:
| Quote: | --> RV10-List message posted by: Perry Casson <pcasson(at)sasktel.net (pcasson(at)sasktel.net)>
Yup
...... well, mostly ..... we do learn from doing stupid things .....
electric.
Linn
jwt(at)roadmapscoaching.c Guest
Posted: Mon Oct 23, 2006 3:59 pm Post subject: Vans wiring kit - mods for fuel injection |
Why would the fuel injected engine require a different breaker size for the
boost pump?
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Finish kit - wheel fairings, cowl prep
LarryRosen
Posted: Mon Oct 23, 2006 5:22 pm Post subject: Vans wiring kit - mods for fuel injection |
The carburated fuel pump is a Facet Pump and the injected engine uses an
ES Airflow fuel pump. Thats the difference, but I do not know if there
is any difference in power requirements. The electrical design per
Van's wiring diagram calls for a 5 amp toggle switch breaker with 18 AWG
wire. And no note for a difference between the 2 pumps.
Larry
boost pump?
John Testement
40321
Richmond, VA
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Tue Oct 24, 2006 6:09 am Post subject: Vans wiring kit - mods for fuel injection |
I don't know why, but the pump for an IO requires more than 5 amps. When
talking to Van's, they said that the kit was for the O engine, not the IO,
so I would need to go with a 10 amp switch. Again, I don't know why, but I
know it is true.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Bill Schlatterer
Posted: Tue Oct 24, 2006 5:30 pm Post subject: Vans wiring kit - mods for fuel injection |
The Facet pump for the O series carb model draws only 1 amp according to
Spruce
http://www.aircraftspruce.com/catalog/eppages/facetpumps.php
Suspect the higher pressure OI pump would take a little more oomph!
Bill S
7a
Don
Posted: Thu Oct 26, 2006 3:30 pm Post subject: Re: Vans wiring kit - mods for fuel injection |
If your installing the Airflow Performance boost pump P/N 3090050, you will require a switched 10 amp circuit. We recommend a 10 amp breaker with #16 gauge wire minimum to supply the pump. The pump will draw 5-6 amps (at) 30 PSI and there's a little inrush current on start up thus the 10 amp breaker.
Don
