Float Flyr
Posted: Wed Oct 25, 2006 9:30 am Post subject: Guy --- Re: Warp Drive Hub |
High Altitude Compensator.... Basically it redirects some vacuum from the
intake and directs it to the float bowl to make the amount of fuel passing
through the main jet reduce with altitude. It allows you to fly at greater
altitudes and you won't spend as much time lifting and dropping the needles.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Wed Oct 25, 2006 4:21 pm Post subject: Guy --- Re: Warp Drive Hub |
Noel, You can still get artic sparrow kits too where the needle has a screw
on it silver soldered on and you turn on knob for each carb.
I have a friend with that on his Rotax and it works ok. I am not sure if
it really worth the effort though unless you routinley fly from Sea level to
over 7500 alot.
To me it just something else to screw up. I can get away chnaing needles
once in fall which I just did all the way rich and then revert back again in
spring again.
Keep it simple.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Thu Oct 26, 2006 5:14 am Post subject: Guy --- Re: Warp Drive Hub |
Using the HAC you would only use the most rich setting on your main needle.
The rest of the leaning would be done with the HAC. Of course you would
still check your needles every ten hours or so.
My reason for looking at the HAC is that I an planning a trip from coast to
coast in Canada. The plan is to traverse the whole Enchilada, from St.
John's harbour in the East to Victoria harbour in the West. In between there
is a little bump called the Rocky Mountains that I would like to be able to
traverse with altitude to spare.
Noel
[quote] --
Kitfox III-A
lcfitt(at)sbcglobal.net Guest
Posted: Thu Oct 26, 2006 6:42 am Post subject: Guy --- Re: Warp Drive Hub |
Is the Bing carburetor from the 912 adaptable to the two stroke Rotaxes. I
have never seen this brought up before, but the Bing has an altitude
compensating diaphragm and the carb is suposed to adjust mixture up to
10,000 ft., I believe.
Lowell
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Thu Oct 26, 2006 8:32 am Post subject: Re: Guy --- Re: Warp Drive Hub |
I'll bet you'll find a problem with 2-stroke engine pulse vibration if someone were to trry and adapt a 912 carb to a 582. I believe it would be rough on needle seats or some other problem.
Rex
Colorado
Guy Buchanan
Posted: Thu Oct 26, 2006 11:48 am Post subject: Guy --- Re: Warp Drive Hub |
At 06:14 AM 10/26/2006, you wrote:
| Quote: | Using the HAC you would only use the most rich setting on your main needle.
I'm using the HACman and like it. You only get about 80F of EGT variation,
though.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
occom
Posted: Thu Oct 26, 2006 12:34 pm Post subject: Guy --- Re: Warp Drive Hub |
Float Flyr
Posted: Fri Oct 27, 2006 9:22 am Post subject: Guy --- Re: Warp Drive Hub |
I may have to go North through Saskatchewan thee isn't too many places to
put down on floats on the prairies. I've been considering getting a set of
full lotus amphibs just for the trip. What I'd really like is a set of
amphib Aerocets. I have the straight Aerocet and like them. Crossing from
Newfoundland to the mainland is going to be tricky too. I haven't decided
yet whether to go the Quebec North shore or straight across the Cabot
Straight. The straight is close to 100 Mi. but there are usually many ships
there. The flight form the park outside Port Aux Basques to Sydney is about
140Mi it will require a good day.
Noel
[quote] --
Kitfox III-A
