Gap seal
susan203(at)centurytel.ne
PostPosted: Sat Oct 28, 2006 11:17 am    Post subject: Gap seal Reply with quote
Does anyone have experience flying a mk3 without a gap seal, I noticed one on Barnstormers but haven't flown mine without it yet, It looks like it may improve airflow to the prop and possibly be more efficient?
Ken Richter in wisconsin
MK3/Geo n50815
Richard Pike
PostPosted: Sat Oct 28, 2006 1:30 pm    Post subject: Gap seal Reply with quote
I would consider flying a MKIII w/o a gap seal to be a Bad Idea.
You know how every airplane has tip vortices rolling off the wing tips as the high pressure air escapes from under the wing and around the tip? (Not a very good description, but you get the idea...)
Without a gap seal, you now have four vortices per airplane, two at the tips, and two in the middle.
Bad Idea.
Richard Pike
MKIII N420P (420ldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
pj.ladd(at)btinternet.com
PostPosted: Sun Oct 29, 2006 2:25 am    Post subject: Gap seal Reply with quote
slyck(at)frontiernet.net
PostPosted: Sun Oct 29, 2006 7:32 am    Post subject: Gap seal Reply with quote
-Unless you do it like this..........
but I agree with Mr. Pike, nothing there at all degrades your lift by
a large percentage.
I tried it and didn't like it. I've also flown conventional tractor
high wingers without
the fairings to the fuselage. Again a serious loss of lift.
BB
 Filesize:  136.64 KB
 Viewed:  297 Time(s)
a58r(at)verizon.net
PostPosted: Sun Oct 29, 2006 11:54 am    Post subject: Gap seal Reply with quote
Pat,
blankety-blank-blank
regards,
Bob N. FireFly 070 Old Kolb
biglar
PostPosted: Sun Oct 29, 2006 12:18 pm    Post subject: Gap seal Reply with quote
Da fix is in da works. Do not Archive.
Larry Bourne
Palm Springs, CA
www.gogittum.com
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
