rosestar(at)sonic.net Guest
Posted: Sat Oct 28, 2006 6:21 am Post subject: Test Flight |
I am about two months from finishing N601BD, so I am soliciting thoughts
about the test flight. I am a relatively low hours pilot. With mixed
emotions about it, I am leaning to having someone more experienced make
the first flight. I've read several "first flight" articles, pamphlets
and even a full book about it. What have others done? Safety, of
course is my conern. The distraction of monitoring all those statistics
in a three to five minute tour in the pattern seems like a heavy load.
Any thoughts?
Brad
Posted: Sat Oct 28, 2006 7:38 am Post subject: Test Flight |
I am the same time away from flying my 601xl. what you need before you get behind your plane is some time in the type. If something should go wrong at least I would have the "feel" for the plane. In case of a problem you want to set your plane for best glide, position for a landing spot, then work out the problem, If you are not comfortable in the plane I personally feel like i would be behind the plane in stead of ahead of it. If built well, flying the first flight in a 601 should be a cake walk. It is an easy plane to fly, however it is not a cherokee. The pitch sensitivity is tight compared to production aircraft, tight steering is an understatement on the last 601 I flew. if you thought of going somewhere, I swear it read my mind and was going in that direction.
What I did was call the factory to see where I can get some hours in a 601xl. If you call around, you can rent for some time to get the feel of the 601.
to make a long story longer,
My advice is get some time in someone elses 601.
Juan 601 xl Tampa
dredmoody(at)cox.net Guest
Posted: Sat Oct 28, 2006 10:47 am Post subject: Test Flight |
If you have doubts and second thoughts, then you are not the guy to fly the
plane for the first couple of hours. Your doubts will reduce your
concentration and make you less fit to be the test pilot than you actually
are. While we're on the subject, another pilot who has never flown a plane
like yours is not a great choice either. Mid Atlantic Sportplanes (and
probably others) offer instruction in the 601XL.... is that your model? You
did not make that clear. In any case, get enough time in the model you built
to feel confident (not over-confident... that's dangerous too) then do your
own test flight if you want to.
Ed Moody II
Rayne, LA
601XL/Jabiru/cabin area
and even a full book about it. What have others done? Safety, of course
is my conern. The distraction of monitoring all those statistics in a
three to five minute tour in the pattern seems like a heavy load. Any
thoughts?
Brad
Posted: Sat Oct 28, 2006 11:00 am Post subject: Test Flight |
I face the same dilemma and will find a "qualified" test pilot for the first
flight or two - someone skilled enough to react quickly and correctly to any
unusual behavior of the aircraft. But it places you in a difficult moral
position. You are asking someone to risk their life based on your
construction skills. Best to get them involved in observing your
construction so they can make an informed decision.
As to tracking all the data here are a couple of ideas:
- just fly the plane and observe general flight characteristics
- have someone on the radio log readings and observations you broadcast (on
an empty channel)
- buy a small digital voice recorder and connect it into your intercom - my
Lightspeed headset has a cell phone interface which I'll be testing. The
voice recorders are cheap. My Sony ICD-B300 cost under $40 at the local
office supply superstore.
- Install one of the "cheap" glass panels and log the data output. The GRT
and Dynon units send data out the serial port which can be captured by a
laptop while the MGL Avionics' Enigma can record to its own memory card.
-- Craig
Posted: Sat Oct 28, 2006 11:29 am Post subject: Test Flight |
On the left coast you can get 601XL time at Dragonfly Aviation in Santa
Rosa, CA (just down the road from Michael Heintz's Quality Sports Planes).
There are also these folks in western Colorado (but I'm not sure they
actually have a 601XL yet): www.gjsportpilot.com/
I believe there is also 601XL instruction available in Arizona but I have
lost the link.
If you can't find a 601XL consider the Evektor Sport Star at St. Charles
Flying Service in MO. That is what I soloed in and its flight
characteristics resemble the 601XLs.
-- Craig
rstone4(at)hot.rr.com Guest
Posted: Sat Oct 28, 2006 11:57 am Post subject: Test Flight |
Rosalie,
It's a good safe design so if you have built it the way it was designed
to be built it should be a safe airplane to fly. So much for equipment
failure. If you are a low time pilot get one of the local flight
instrtuctors who has a lot of experence flying different aircraft to go with
you until you feel that you can handle the plane. When you feel safe by
yourself, pay the guy off and fly alone.
Bob Stone, Harker Heights, Tx
ZodiacXL
Posted: Sat Oct 28, 2006 12:10 pm Post subject: Test Flight |
I thought that during the fly-off period there could only be a pilot in the
plane (i.e. no "passenger")?
-- Craig
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Sat Oct 28, 2006 2:50 pm Post subject: Test Flight |
Brad
I just went through the same decision process. This is the second plane I
have built. I was very concerned about the first flight on the first plane
I built and went with a test pilot. I was glad I did, since when I finally
did fly it myself it was a handful for awhile. After 400 hours in homebuilts
and a couple of hours familarization in the 601XL I was confident I could
make the first flight in my 601XL and I did.
If you have any doubts about your capabilities to do the first flight, you
probably should not do it. You probably could handle it if everything goes
right, but will you keep enough presence of mind when issues occur.
My first flight in the XL required significant backpressure to fly level.
After a very focused but uneventful landing I ended up readjusting the stab.
My second flight had a partial engine power loss, resulting in a short
careful flight around the pattern and luckily a landing with no incident.
Both issues really get your attention and test your flight capabilities.
Hopefully neither you nor your test pilot will have any issues but just be
prepared mentally in case of.
Happily ,I'm into the 2nd hour of test flying and things are going well.
George May
601XL 912s
Use your PC to make calls at very low rates
https://voiceoam.pcs.v2s.live.com/partnerredirect.aspx
Posted: Sat Oct 28, 2006 10:54 pm Post subject: Test Flight |
Thanks for the responses regarding the upcoming first test flight in my
601xl. I should mention that I have 5.5 hours in 4 different Zodiac
XL's. The last 2.9 hours were in Dragonfly's 601xl for my bienniel
flight review. The others were demo flights. So I do have some time in
the design and feel comfortable in the plane, subject to more time and
experience. In fact, I love the plane! The first demo flight resulted
in the decision to buy a 601xl kit. I like the idea of flying with a
recorder for verbal observations. These suggestions have been great
advice. Please continue with your thoughts. They are greatly
appreciateed.
Brad
blb7037(at)cox.net Guest
Posted: Sun Oct 29, 2006 9:22 am Post subject: Test Flight |
I am in the same boat on first flight. I am working with an EAA Flight Advisor to complete the EAA's Flight Advisor Program which gives you a plan from an experienced pilot. My insurance requires it. I am also looking for a way to get the 3 hours in Make and Model required by the insurance. The operator in Arizona has been out of service all Summer due to a canopy mishap so I have not got that done yet. It is hard to find a test pilot to do your first flight that will meet the insurance companies rules. Also get FAA Advisory circular AC 90-89A. It's a must for first flight and the phase one flight test time.
Don't give up. It takes a lot more time to prepare for the first flight than it does to do the flight.
Brian Briggerman
N601AZ
lgingell
Joined: 10 Jan 2006 Posts: 50 Location: Lake California Airpark 68CA
Posted: Sun Oct 29, 2006 9:45 am Post subject: Re: Test Flight |
Brad,
(I may have told you most of this before, but...)
I had about an hour in the demo XL (mexico) and a few hours in an HDS before my first flight. I went through the same thing. I was at around 100 hours, so not terribly experienced.
I flew several types in the week before my first flight (high wing, low wing, fast homebuilt), and a couple of flights *right* before I took the zodiac up.
By the time I got in the Zodiac, I felt very 'adaptable'...but it turned out so easy to fly that I think I had a harder time flying the other airplanes the week before.
However, I had done extensive taxi test lifting wings, nose wheel etc. to verify all the controls and authority. ..and I had lots of pairs of qualified eyes look over the airplane.
It was an amazing experience. I'm glad I did it, but I would have been fine if I didn't. I'd never of taken risks for the sake of saying 'I flew it first'.
Cheers,
..lance
http://lancegingell.com/plane.asp
_________________ Zodiac XL/Jab 3300
http://lancegingell.com |
JAPhillipsGA(at)aol.com Guest
Posted: Sun Oct 29, 2006 10:02 am Post subject: Test Flight |
Well, Brian, just you call the airlines and get you a ticket over here to Georgia and we can fly us some XL hours. Let me know at least 30 minutes before arrival so I can sober up and we're off. Best regards, Bill of Georgia [quote][b]
