JPI 800 & manifold pressure
douglas.weir(at)us.calyon
PostPosted: Mon Oct 30, 2006 7:05 am    Post subject: JPI 800 & manifold pressure Reply with quote
I have a JPI 800, and recently I have noticed the manifold pressure will become highly erratic after maybe 30 minutes of flight time. It is somewhat intermittent, and does not always demonstrate the same behavior.
I have looked at the hardware and do not see any obvious loose fittings - do you have any suggestions of how to go about trouble-shooting, and what the likely culprit might be?
Also, I recently had a bird strike which will require replacement of the vertical stabilizer - other than Fletcher, are there other reliable sources of replacement parts for my Tiger (it's a '79)?
Doug
*** Calyon ****************************************************
This message and/or any attachments (the "message") is intended for the sole use of its addressee. If you are not the addressee, please immediately notify the sender and then destroy the message. The unauthorized disclosure, use, dissemination or copying (either whole or partial) of this e-mail, or any information it contains, is prohibited. E-mails are susceptible to alteration and their integrity cannot be guaranteed. As this message and/or any attachments may have been altered without our knowledge, its content is not legally binding on CALYON Corporate and Investment Bank. All rights reserved.
