d_emond(at)mweb.co.za Guest
Posted: Sun Oct 29, 2006 9:35 am Post subject: Z12 Architecture |
I have gone with the Z-12 architecture. B&C 60 Amp main and 20amp standby as
well as the necessary controllers as per Bobs architecture.
How does one test this setup?? I have heard that should I pull the field
breaker on the main alternator( with the engine running), the standby unit
will come into play.
Must I leave the 60amp off line until the engine is switched off, before re
setting??
Dave Emond
RV 10 - #40159
Finish Kit
nuckollsr(at)cox.net Guest
Posted: Sun Oct 29, 2006 10:58 am Post subject: Z12 Architecture |
At 07:32 PM 10/29/2006 +0200, you wrote:
<d_emond(at)mweb.co.za>
as well as the necessary controllers as per Bobs architecture.
re setting??
You need to order the Standby Regulator to go
with the SD-20. This regulator gets set for about 1 volt
below normal alternator output voltage (13.2) See
http://www.bandc.biz/Bc217.pdf
After you start the engine, leave the main alternator off
and the SD-20 should pick up the load and the "sb alt loaded"
light will come on showing it's on line. Bus voltage should
be about 13.2 at the point. Turn the main alternator on,
the light should go out and the bus voltage rises to 14.2.
See also:
http://www.bandc.biz/410Finaltest.html
http://www.bandc.biz/BC410-installinstructions.pdf
< with experiment. >
< --Lawrence M. Krauss >
Posted: Mon Oct 30, 2006 12:23 pm Post subject: Z12 Architecture |
Thanks Bob
