GENTRYLL(at)aol.com Guest
Posted: Mon Oct 30, 2006 8:53 am Post subject: Landing Practices |
I am new at taildragging and am having a problem doing three point landings in that I am stalling out a litte too high each time and bouncing. I attribute this to being used to a 172 where I physically sit higher because of the bigger plane. Is it best to try to land with a little power like in a wheel landing then backing off the power and pulling back on the stick after the main gear is on the runway or maybe even just continue with a full wheel landing?
propellerdesign(at)tele2. Guest
Posted: Mon Oct 30, 2006 9:59 am Post subject: Landing Practices |
If you do a wheelie you decide to make a wheelie before you land, and same with a 3-point landing.
When you do a wheelie, at the moment the tire just barley touch the asphalt or grass, you pull the throttle and move the stick an inch or two forward, then keep the tail up until you have full down elevator, when the tail start to come down you firmly apply full up elevator.
On a 3-point, you let the speed bleed of, with stick slowly backward, without ballooning or touching the ground until it stall from 3 inch alt.
And keep the rudder in motion.
Jan
Posted: Mon Oct 30, 2006 10:13 am Post subject: Landing Practices |
It's that last 3 inches that's getting me. It ends up about two feet of fall and what seems like ten feet of bounce. Luckily she has plenty of power to get out of it.
dave
Posted: Mon Oct 30, 2006 10:56 am Post subject: Landing Practices |
There are some take offs and Landings here http://www.cfisher.com/kitfox/
scroll down the left side near bottom
Kitfox Movie Fresh from the Trailer Park.
DOWNLOAD NOW 17 mgs.
right clik save as.........
Hope that helps
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
wingnut
Posted: Mon Oct 30, 2006 11:30 am Post subject: Re: Landing Practices |
I had the same problem when I transitioned to the kitfox (still bites me occasionally). I eventually remembered something my instructor told me. Rather than trying to judge where the ground is right under me, look strait ahead to the end of the runway. I'm close to the ground when the picture out the front of the window starts to look the way it does when I'm on the ground. That helped me to get more consistent but I didn't really start getting smooth landings until I'd just done a whole bunch of them. No substitute for practice.
| Quote: | I am new at taildragging and am having a problem doing three point landings in that I am stalling out a litte too high each time and bouncing. I attribute this to being used to a 172 where I physically sit higher because of the bigger plane. Is it best to try to land with a little power like in a wheel landing then backing off the power and pulling back on the stick after the main gear is on the runway or maybe even just continue with a full wheel landing?
lcfitt(at)sbcglobal.net Guest
Posted: Mon Oct 30, 2006 12:45 pm Post subject: Landing Practices |
This sounds like me early on. My glasses were the progressive type bifocals
which give no peripheral correction at all. I had a real hard time finding
the ground. That said, it seems that if you are bouncing after the wheels
touch, you are not in a true three point. Typically when this happens, you
stall with the tail up a bit and when the mains touch, the tailwheel drops
increasing the angle of attack and you are flying again at the new angle.
You might check to see that you are full stick back in the stall and also
there have been issues about inability to get the tail down - inadequate
elevator authority. Lots of guys have taped the gap to increase elevator
authority. In short, others have had this issue and it is not necessarily
the fault of the pilot.
Lowell
dave
Posted: Mon Oct 30, 2006 12:55 pm Post subject: Landing Practices |
Lowell,
Did you see that video? Would taping my gaps help me Lowell?
Also a good technique is same as glassy water landing........ slow decent
and fly to ground
Dave
Posted: Mon Oct 30, 2006 2:08 pm Post subject: Landing Practices |
I like the slow decent, fly it to the ground technique. That was about what I had decided would work best for me. I don't know what "taping my gap" means, though.
Guy Buchanan
Posted: Mon Oct 30, 2006 3:24 pm Post subject: Landing Practices |
At 08:52 AM 10/30/2006, you wrote:
| Quote: | | I am new at taildragging and am having a problem doing three point landings in that I am stalling out a litte too high each time and bouncing. I attribute this to being used to a 172 where I physically sit higher because of the bigger plane. Is it best to try to land with a little power like in a wheel landing then backing off the power and pulling back on the stick after the main gear is on the runway or maybe even just continue with a full wheel landing? |
If you pull back on the stick after the mains are on you'll go flying again. If you do a wheel landing you push forward to plant the mains and then keep pushing forward trying to lift the tail until it touches. Then you bring the stick back full.
1. Get a copy of "Stick and Rudder" and read it.
2. Get a copy of "The Compleat Taildragger Pilot" and read it.
3. Sit in your aircraft on the taxiway and mark three points on the windscreen; two to mark the horizon and two to mark the centerline. The marks for the centerline should then defocus to four when you focus at infinity, with the centerline in the middle of the four dots. Next apply fine line tape lines dot to dot, leaving you with the horizon and a "gun sight" for centerline.
4. When you land, make sure you are looking primarily right and left and not straight ahead. It's much easier to judge height if you do so. Glance ahead to keep things straight, but you should use right and left for altitude and drift. (Most taildraggers require right and left for everything, as there is literally no view forward.)
5. Fly down the runway under power at about 5-10 over stall. Keeping everything centered fly the plane down until you just skiff a wheel. Bring it up and try to fly down the length of the runway at 1' or less altitude, slipping the aircraft as required to align with the centerline. If you bounce don't push, just add a little power, get stable, then fly back down to the runway at minimum airspeed. Try to do this without looking forward, or just glancing forward for centerline. If the air's stable, and you're feeling really skilled, bring the speed down to just above stall and float it all the way down the runway. Go around and repeat as required.
6. Practice, practice, practice!
Guy Buchanan
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Posted: Mon Oct 30, 2006 4:04 pm Post subject: Landing Practices |
Missed the video Dave.
I am just reporting the experience of others on the list. I'm sure someone
will chime in regarding elevator authority. I think it can also be a result
of landing with lots of flaps. Flaps will tend to pitch the nose down and
a bit of up elevator is then needed to hold the nose up. At the touch down
point you may run out of elevator, then as before, if the mains touch first,
the tail will drop and with the increased angle of attack, you are flying
again.
Lowell
dave
Posted: Mon Oct 30, 2006 5:00 pm Post subject: Landing Practices |
Lowell,
A few videos here http://www.cfisher.com/kitfox/
bottom left is one with lot of landings . I have no Gap seals and alot or
take off and landing with flaps , do you think it needs a gap seal ? And if
so what will I gain?
Dave
Coffee break at the Trailer park Hangar
Download 4.8 meg
GENTRYLL(at)AOL.COM Guest
Posted: Mon Oct 30, 2006 6:19 pm Post subject: Landing Practices |
That video is something else. I had a lot of takeoffs and landings that looked like that but they were not planned. Maybe someday.
Posted: Mon Oct 30, 2006 6:26 pm Post subject: Landing Practices |
I have done a lot of reading and understand the mechanics. Your explanations on how to get the feel of things make a lot of sense. I will be sure to try them next chance I get. I had this same stalling out a little too high problem also in both a 150 taildragger and a Citabria. I was using the transitions lens also so glasses off now.
smokey_bear_40220(at)yaho Guest
Posted: Mon Oct 30, 2006 7:43 pm Post subject: Landing Practices |
Darn Guy,
That is what I was going to say, but not nearly as
well.
Kurt S.
--- Guy Buchanan <bnn(at)nethere.com> wrote:
| Quote: | At 08:52 AM 10/30/2006, you wrote:
| Quote: | If you pull back on the stick after the mains are on
you'll go flying
plant the mains and
full.
and read it.
three points on the
the centerline. The
when you focus at
right and left for
and left for
over stall. Keeping
centerline. If you
as required.
Guy Buchanan
to Bob Ducar.
Access over 1 million songs - Yahoo! Music Unlimited
(http://music.yahoo.com/unlimited)
Guy Buchanan
Posted: Mon Oct 30, 2006 8:18 pm Post subject: Landing Practices |
At 04:03 PM 10/30/2006, you wrote:
| Quote: | I am just reporting the experience of others on the list. I'm sure someone
My IV ran out of authority with full flaps until I sealed the elevator gap
with clear tape. It will go all the way to stall now, power on or off. (My
CG is about 14.7" and I have my HS as high as it will go.)
Guy Buchanan
Deceased K-IV 1200
Guy Buchanan
At 07:43 PM 10/30/2006, you wrote:
| Quote: | Darn Guy,
well.
Your too kind. :-[
Guy
Deceased K-IV 1200
Guy Buchanan
| Quote: | Darn Guy,
well.
Oops. You're too kind. :-[
(Man I hate it when I do that. And in public, too.)
Guy Buchanan
Deceased K-IV 1200
Posted: Mon Oct 30, 2006 8:31 pm Post subject: Landing Practices |
I guess the best answer to your question. If it aint broke, don't fix it.
Gap seals have helped others that have had difficulty getting the tail down
for full stall landings.
Lowell
Posted: Mon Oct 30, 2006 9:29 pm Post subject: Landing Practices |
Heck, I only mess up in public. Like my best landings
no one ever sees. But the day I got a crowd.... I hit
that little dip in the grass runway squarely and
bounced 7 times. (Never over a foot high, but bounce,
bounce, bounce...)
Or the time I tried to do the 1/2 flaps landing on
pavement and dump the flaps to make it stick trick.
Yanked up instead of pushing down on the handle.
Straight up 10 feet, hover? Then a nice recovery
while the next plane could hardly talk for laughing
over the radio.
Forgiven, but not forgotten Guy
Kurt S.
| Quote: | (Man I hate it when I do that. And in public, too.)
| Quote: | Guy Buchanan
to Bob Ducar.
Get your email and see which of your friends are online - Right on the New Yahoo.com
(http://www.yahoo.com/preview)
janderson412(at)hotmail.c Guest
Posted: Mon Oct 30, 2006 11:51 pm Post subject: Landing Practices |
My old instructor (ex WW2 Spitfire pilot) said always look straight ahead at
the end of the runway..Never look out the side in case she bolts on you.
When you see the side markers or side if the stip at shoulder height gently
out your perifial, pull back. Done me fine for many years/hours. And I wear
progressives...~j~
You wrote 30 Oct 2006 15:12:40 -0800
Guy Buchanan
Read the latest Hollywood gossip (at) http://xtramsn.co.nz/entertainment
