matt(at)n559rv.com Guest
Posted: Thu Jan 26, 2006 5:48 pm Post subject: Troubling Airworthiness Directive... |
I just received an AD in the mail regarding cylinder heads on Lycoming 320 and 360 engines manufactured by ECI. It requires that the
cylinders be replaced before 800 hours or if you are over 800 than within 60 hours.... This could cost a fortune, who pays for this? I am a
recent aircraft owner for the first time and have not encountered this before. I cant imagine that the manufacture (ECI) doesnt have some
kind of liability. My engine just had an overhaul 40 hours ago!
- Matt
alexpeterson(at)earthlink Guest
Posted: Thu Jan 26, 2006 6:07 pm Post subject: Troubling Airworthiness Directive... |
that the cylinders be replaced before 800 hours or if you are
who pays for this? I am a recent aircraft owner for the first
that the manufacture (ECI) doesnt have some kind of
- Matt
If you have the cylinders on an RV, compliance is not required. However,
most RVers will comply, and I understand that for four new cylinders the
price from ECI will be $1300 total. They aren't paying for the labor.
Welcome to an imperfect world.
Alex Peterson
RV6-A N66AP 708 hours (lucky, at least for now, to have Millennium
cylinders)
Maple Grove, MN
ronlee(at)pcisys.net Guest
Posted: Thu Jan 26, 2006 6:25 pm Post subject: Troubling Airworthiness Directive... |
At 06:56 PM 1/26/2006, you wrote:
- Matt
Before you get upset read the AD. It is probably on their website and
may not even apply to you.
Ron Lee
Posted: Thu Jan 26, 2006 6:52 pm Post subject: Troubling Airworthiness Directive... |
It is for a certified plane (Grumman). I guess that I dont have to comply until it is at 800 hours, but it will still hurt the resell value if I
dont do it.
How often do people get AD's that cost them thousands of dollars on a whim? At least with cars they are recalls and the manufacturer
picks up the cost of replacement...
- Matt
dbris200(at)sbcglobal.net Guest
Posted: Thu Jan 26, 2006 6:59 pm Post subject: Troubling Airworthiness Directive... |
They're paying $475 for labor, it's included in the $1350 exchange
price that they are charging me. The AD doesn't affect all ECi
cylinders, just the "Classic Cast". The replacements are "Titan" which
are a step up. They also pay shipping one way.
Dave
| Quote: | If you have the cylinders on an RV, compliance is not required. However,
Alex Peterson
cylinders)
Maple Grove, MN
eddyfernan(at)aol.com Guest
Posted: Thu Jan 26, 2006 7:09 pm Post subject: Troubling Airworthiness Directive... |
FYI.
This does not apply to the new ECI Titan cylinders that many kit builders including myself purchased. Of course you can double check that with ECI .
Eddy Fernandez
RV-9a Finishing
ECI O-320
Larry Bowen
ECI will pay for a pro-rated labor reimbursement for removal & installation.
http://www.eci2fly.com/pdf/05-8.pdf
last paragraph.
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
[quote] --
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Kellym
Posted: Thu Jan 26, 2006 8:03 pm Post subject: Troubling Airworthiness Directive... |
First of all, determine whether the AD applies to the exact serial
number cylinders you have. Given your overhaul is so recent, it is very
unlikely, but get with your overhauler and be CERTAIN. It is the owner's
responsibility. An engine still under warranty is likely to get much
more consideration than the basic coverage mentioned in the AD.
dont do it.
- Matt
KCHD |
n395v
Posted: Fri Jan 27, 2006 5:07 am Post subject: Re: Troubling Airworthiness Directive... |
| matt(at)n559rv.com wrote: |
picks up the cost of replacement. |
Do a search on the 400 series Cessna wing spar AD.
$60,000 out of every owners pocket because Cessna did a theoretical study that contains "confidential data not available to the public"
No reimbursement by Cessna, all out of the owners pocket. It affects so many planes it will take Cessna 5 years to mfg all the kits.
_________________ Milt |
Bruce(at)glasair.org Guest
Posted: Fri Jan 27, 2006 6:16 am Post subject: Troubling Airworthiness Directive... |
Perhaps it's time for a class action suit against Cessna.
Bruce
www.glasair.org
Rhonda(at)bpaengines.com Guest
Posted: Fri Jan 27, 2006 6:29 am Post subject: Troubling Airworthiness Directive... |
Keep in mind that the longer you run the cylinders, the less ECI will
"discount" the replacement Titan cylinders.
Rhonda
flyboy.bob(at)gmail.com Guest
Posted: Fri Jan 27, 2006 7:13 am Post subject: Troubling Airworthiness Directive... |
First make sure you cylinders are the ones affected . . . I'm told that
"Classic Cast" cylinders haven't been made since 2001?? "Titan" cylinders
(post 2001) are not included in the AD. If you engine only has 40 hours on
it maybe they are ECi "Titan" cylinders?
Good Luck,
Bob
On 1/26/06, Matt Johnson <matt(at)n559rv.com> wrote:
- Matt
Posted: Fri Jan 27, 2006 7:18 am Post subject: Troubling Airworthiness Directive... |
Another point . . . these cylinders were "certified" by the FAA to "perform
equal to the original manufacturer's part" . . . shouldn't the FAA pick up
their share of the blame and cost?? Perhaps ECi doesn't agree with the
FAA's conclusion . . . it becomes a sticky situation?!
Bob
Bruce
www.glasair.org
deruiteraircraftservices( Guest
Posted: Fri Jan 27, 2006 7:24 am Post subject: Troubling Airworthiness Directive... |
| Quote: | Perhaps it's time for a class action suit against Cessna.
I believe that's exactly the reason Cessna stopped making single engined
airplanes in the 80's..............
flyeyes(at)mac.com Guest
Posted: Fri Jan 27, 2006 7:30 am Post subject: Troubling Airworthiness Directive... |
On Jan 27, 2006, at 8:12 AM, Bruce Gray wrote:
Bruce
www.glasair.org
(snip)
(snip)
C'mon Bruce. A lawsuit on planes that haven't been manufactured in
over 30 years? Should t-34 owners sue Beech for the wing spar ADs on
those airplanes? Small wonder that it's difficult to find honest
support for older airplanes.
hemico
Posted: Fri Jan 27, 2006 8:11 am Post subject: Re: Troubling Airworthiness Directive... |
Here is an interesting article on Aviation Product Liability.
http://www.avweb.com/news/avlaw/181885-1.html
Bob C...There is a small section in the article that speaks to FAA certification.
Skippy
flyrv6(at)bryantechnology Guest
Posted: Fri Jan 27, 2006 8:15 am Post subject: Troubling Airworthiness Directive... |
That didn't stop the class action against Cessna for lack of shoulder
harnesses in their 30-40 year old planes. Before the shoulder harness was
even thought of.
However, class action lawsuits award all the plaintifs enough money to buy
dinner for one and the lawyers millions. What is the benefit? I am not a
lawyer, so none for me.
dan.beadle(at)inclinesoft Guest
Posted: Fri Jan 27, 2006 8:21 am Post subject: Troubling Airworthiness Directive... |
I am a C414A owner. I watched this AD progress through. The cost is
probably closer to $90K with real labor rates.
FORTUNATELY, like the eci AD, it only applies in certain situations - in my
case with 18000 airframe hours. I have 4500 hours on the airframe and fly
250 hours a year. With a little math... That is another 52 years of service
I can expect.
And, if I were convinced that it were a safety issue now, I would apply the
AD. $90K is only 15% of the value of the airplane. And it is far less than
the value of my life.
I am a little bit miffed that Cessna will not share the engineering data so
we can understand it - but that is probably the result of lawyers afraid
that the data will hang them.
Dan
Dave Johnson
Joined: 11 Jan 2006 Posts: 7 Location: Erie, CO (48V, BJC)
Posted: Fri Jan 27, 2006 10:21 am Post subject: Troubling Airworthiness Directive... |
In my humble opinion, that is precisely the wrong answer. I watched the
Cessna 400 series wing spar AD unfold very closely, and at the core of
it, pretty much everyone agrees that Cessna's actions were the result of
trying to limit its exposure to liability suits. The only spar failures
recorded were in airframes that always flew fully loaded, low down in
the summer thermals, and with a light fuel load- precisely the
conditions which apply maximum stress to the wing spars. BUT, Cessna is
still on the liability hook for airplanes sold many years ago, because
they have supplied parts for them which resets the liability period for
another 17 years.
They are in an impossible situation with lawyers coming from all over
the place to take a piece. Damned if they don't take action on the
slightest indication of a problem, damned if they do because owners will
sue them for making them spend the money. My opinion? Stop class action
and liability suits on aircraft manufacturers, because that's the root
of the problem (and promote an understanding among all of mankind that
life has risks...the failure to accept this has created the litigious
business climate we have today). The Cessna 400 series wing is built
hell for stout, but that doesn't amount for shit in front of a jury.
Dave
Bruce
www.glasair.org
Posted: Fri Jan 27, 2006 11:02 am Post subject: Troubling Airworthiness Directive... |
Dave, you are completely right IMHO but it shouldn't stop at aircraft
manufactures. There should be very strict criteria applied to class action
lawsuits as well.
