billmileski
Posted: Thu Nov 02, 2006 10:49 am Post subject: 701/912S colder weather operations |
List,
My 701 will be entering its first New England winter, and I have had marginal oil temps already. I do have an oil thermostat on the shelf in the hangar, but am wondering whether to add the complexity or just tape over the oil cooler. How are you others operating in the cooler outdoor temps doing, and what would you suggest?
Bill Mileski
NYTerminat(at)aol.com Guest
Posted: Thu Nov 02, 2006 11:21 am Post subject: 701/912S colder weather operations |
Bill,
I installed an oil t-stat and am very happy with it. Even during the summer months, the warm up before the run up is quicker, in the winter it keeps the temps around 180 degrees. I used to tape over my oil cooler but with the Skyshops firewall forward installation it blocked the air to the muffler and reduced the heat output to the cockpit. T-stat is the way to go.
Bob Spudis
N701ZX 912s/87hrs
In a message dated 11/2/2006 1:52:00 P.M. Eastern Standard Time, mileski(at)sonalysts.com writes:
List,
Bill Mileski
mfothergill(at)sympatico. Guest
Posted: Thu Nov 02, 2006 12:30 pm Post subject: 701/912S colder weather operations |
Hi;
Duct tape the rad as the temps get lower. By now, my oil cooler is
completely covered. Some of the water rad is also covered.
CH-601HDS 1000+ hrs (10 winters)
UHS Spinners
billmileski wrote:
List,
Bill Mileski
http://forums.matronics.com/viewtopic.php?p=71836#71836
daveaustin2(at)can.rogers Guest
Posted: Thu Nov 02, 2006 12:34 pm Post subject: 701/912S colder weather operations |
Bill,
I just put aluminium tape over the oil cooler - one strip for the fall and
then complete cover when it really gets cold.
Dave Austin 601HDS - 912, Spitfire Mk VIII
billmileski
Posted: Thu Nov 02, 2006 12:36 pm Post subject: Re: 701/912S colder weather operations |
Thanks, Bob. If you wouldn't mind, could you tell me where you put it, and if you needed 90 degree adapter(s) on the oil cooler, or anything else that might help. And a six pack of your favorite expensive beer, if you ever visit CT, if you could offer up a pic or two!
guess I should be better at using:
hughfr(at)evertek.net Guest
Posted: Thu Nov 02, 2006 1:18 pm Post subject: 701/912S colder weather operations |
How does the oil thermostat work on a dry sump engine?
Does it restrict oil flow or bypass the cooler?
Hugh
Posted: Thu Nov 02, 2006 7:50 pm Post subject: 701/912S colder weather operations |
Bill,
It is installed above the oil filter, I will try to take a picture and send to you if I can before leaving for FL on Sat morning. I don't remember which fittings I used.
In a message dated 11/2/2006 3:38:01 P.M. Eastern Standard Time, mileski(at)sonalysts.com writes:
| Quote: | Thanks, Bob. If you wouldn't mind, could you tell me where you put it, and if you needed 90 degree adapter(s) on the oil cooler, or anything else that might help. And a six pack of your favorite expensive beer, if you ever visit CT, if you could offer up a pic or two!
Posted: Thu Nov 02, 2006 7:52 pm Post subject: 701/912S colder weather operations |
Hugh'
The t-stat bypasses most of the oil from the cooler and as the temp rises to 180 degrees it opens up to allow more oil through the cooler.
Bob Spudis
In a message dated 11/2/2006 4:20:13 P.M. Eastern Standard Time, hughfr(at)evertek.net writes:
| Quote: | --> Zenith-List message posted by: "Hugh Roberts" <hughfr(at)evertek.net>
Hugh
