georgewells(at)adelphia.n Guest
Posted: Fri Nov 03, 2006 10:39 am Post subject: radio problemradio problem |
I have about the same problem but it is with my compass !!
If the compass is located anywhere except above the radio stack it works fine. If I mount it in the center on the panel cover above the radio stack the readings go goofey !! This is with the radios powered up or off ?
Any suggestions for a fix ? I was thinking of a grounded piece of copper screen above the stack.
ruebd(at)skymail.csus.edu Guest
Posted: Fri Nov 03, 2006 11:03 am Post subject: radio problemradio problem |
Your problem is most likely an electromagnetic one, and as such, copper won’t help much. You will need to use mu metal, which is a good magnetic conductor. A radio shop should be able to supply this. Plain old steel might solve it, and it won’t need to be real thick, so try some thin stuff first, before you do a permanent install.
Remember that the compass is a very sensitive magnetic instrument, so anything with a permanent magnetic field needs to be as far away from it as practical, but shielding is the way to keep the field from being a problem when this cannot be done.
Duane Rueb
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of George Wells(at)adelphia.net
Sent: Friday, November 03, 2006 10:38 AM
Subject: Re: radio problemradio problem
[b]I have about the same problem but it is with my compass !![/b]
[b]If the compass is located anywhere except above the radio stack it works fine. If I mount it in the center on the panel cover above the radio stack the readings go goofey !! This is with the radios powered up or off ?[/b]
[b]Any suggestions for a fix ? I was thinking of a grounded piece of copper screen above the stack.[/b]
[b]Thanks[/b]
0123456789012345
Guy Buchanan
Posted: Fri Nov 03, 2006 11:16 am Post subject: radio problemradio problem |
At 10:37 AM 11/3/2006, you wrote:
| Quote: | Any suggestions for a fix ? I was thinking of a grounded piece of copper
I had this problem and it was caused primarily by the two panel
supports running aft from the windshield cross braces. They were heavily
magnetized. (Apparently arc welding causes the 4130 steel used in our
airframe to magnetize.) I used Sacramento Sky Ranch's rental degauss kit to
degauss the whole area and have had no problems since. I removed my panel
to do it since I wasn't sure whether the avionics would survive the degauss
field.
I never tried shielding. I would ask the AeroElectric list on
Matronics. That's where I've seen the most discussion regarding shielding.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Posted: Fri Nov 03, 2006 12:58 pm Post subject: radio problemradio problem |
Yes, the degaussing is a great idea, and as you did, it is good to
remove the panel first. If you can't do that, then magnetically shield
the items most likely to be affected, such as the compass. The airframe
should have a neutral magnetic field, so as not to influence the compass
too much. This is a very good thing to do before finishing our
airplanes.
Duane Rueb
barry(at)pgtc.com Guest
Posted: Fri Nov 03, 2006 1:59 pm Post subject: radio problemradio problem |
George, don't mount the compass above the radios unless it is a dry compass. Mine leaked on the com and it cost $300 to get it fixed besides the problem of coming back in with the handheld. I'm buying a vertical card, dry compass. However, the compass worked well there, it was dead on everytime I checked it with the rose.... which was about the only time I ever looked at it.
Barry West
ddsyverson(at)comcast.net Guest
Posted: Fri Nov 03, 2006 2:27 pm Post subject: radio problemradio problem |
Barry & all,
Vertical card compass...... exactly what I have been hoping & trying to get.
Spruce seems to have been out of stock for the last 100 years (ok - just one
year). Local aircraft wrecking yard seems to be out. Any idea where a person
can actually GET a vertical card compass?
Dave S
St Paul MN
M-7 nosedragger
On Friday 03 November 2006 3:58 pm, Barry West wrote:
| Quote: | George, don't mount the compass above the radios unless it is a dry
card, dry compass.
dave
Posted: Fri Nov 03, 2006 2:42 pm Post subject: radio problemradio problem |
http://www.cfisher.com/
link on left side of page about 4 down "compass swing ."
That a little program that makes a compass card I use.
Once you plug in the numbers just print on sticky paper.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Fri Nov 03, 2006 4:21 pm Post subject: radio problemradio problem |
Na....Put the compass somewhere where it will work.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Fri Nov 03, 2006 4:27 pm Post subject: radio problemradio problem |
Probably something ferrous under the panel cover or in the stack itself. I.e. the cases or mounts for the avionics themselves. I don't think copper, even grounded screens magnetic waves. It is a good thing to notice though.
Noel [quote]
Kitfox III-A
Float Flyr
Posted: Fri Nov 03, 2006 4:46 pm Post subject: radio problemradio problem |
Funny thing about compasses.... They are the first instrument your plane
should have ...... And the last one you will ever look at.
Noel
[quote] --
Kitfox III-A
Fox5flyer Guest
Posted: Sat Nov 04, 2006 2:25 pm Post subject: radio problemradio problem |
Thanks Dave. Good contribution.
Deke Morisse
List Janitor
Dave
Posted: Sat Nov 04, 2006 10:07 pm Post subject: radio problemradio problem |
--- Noel Loveys <noelloveys(at)yahoo.ca> wrote:
| Quote: | Probably something ferrous under the panel cover or
I agree. Grounded copper only works on moving
magnetic fields, like that produced by alternating
current, not stationary magnets, like in the ferrous
metals.
Kurt S.
Low, Low, Low Rates! Check out Yahoo! Messenger's cheap PC-to-Phone call rates
(http://voice.yahoo.com)
kirkhull(at)kc.rr.com Guest
Posted: Sat Nov 18, 2006 8:07 pm Post subject: radio problemradio problem |
I finally had a chance to try out another antenna and it solved the problem.
Thanks everyone
