rdunhamtn(at)hotmail.com Guest
Posted: Sat Nov 04, 2006 4:25 am Post subject: RF ground |
Fellow Nuckollheads,
I've been doing a lot of reading on-line concerning eliminating RFI in the
HF band in my mobile 10/11 meter installation. The current wisdom seems to
be to "ground everything" which I am in the process of doing. BUT... All the
ham gurus recommend using tinned braided wire for RF grounding in preference
to the usual copper w/ insulation "hook-up" wire. I can't figure out why
this would matter. And then, of course, the real meat of the matter... If I
do this to my SkyRanger, will it decrease RFI through my VHF Comm???
Rodney in TN
Use your PC to make calls at very low rates
https://voiceoam.pcs.v2s.live.com/partnerredirect.aspx
N6030X(at)DaveMorris.com Guest
Posted: Sat Nov 04, 2006 6:46 am Post subject: RF ground |
I hope that's just an 11m installation But where is the RFI occurring?
I'm not sure what they are talking about re: tinned braided vs
copper, but it sounds like nonsense to me. Unless you're dealing
with high power levels and very tiny hookup wire, the RF is going to
get grounded either way. RF travels down the circumference of wire,
so larger diameters are better - to a point. You won't notice the difference.
Your VHF comm radio should already have good shielding, so going
crazy with grounds is not necessary. A single ground should
suffice. What RFI are you trying to eliminate?
Dave Morris
N5UP
Amateur Extra Class
At 06:24 AM 11/4/2006, you wrote:
<rdunhamtn(at)hotmail.com>
in the HF band in my mobile 10/11 meter installation. The current
wisdom seems to be to "ground everything" which I am in the process
of doing. BUT... All the ham gurus recommend using tinned braided
wire for RF grounding in preference to the usual copper w/
insulation "hook-up" wire. I can't figure out why this would matter.
And then, of course, the real meat of the matter... If I do this to
Rodney in TN
nuckollsr(at)cox.net Guest
Posted: Mon Nov 06, 2006 7:21 am Post subject: RF ground |
At 07:24 AM 11/4/2006 -0500, you wrote:
the ham gurus recommend using tinned braided wire for RF grounding in
preference to the usual copper w/ insulation "hook-up" wire. I can't
figure out why this would matter. And then, of course, the real meat of
the matter... If I do this to my SkyRanger, will it decrease RFI through
my VHF Comm???
Rodney in TN
Most of my experiences dealing with RFI problems
in aircraft have root causes founded in poorly
designed hardware or inattention to installation
requirements. These often create situations where
the owner/operator is struggling to 'band-aid' the
system to accommodate the deficiencies over which
the fellow has no control.
Adding bond straps, shields, moving bundles, etc
are all part and parcel of the RFI alchemists ingredients
that are OCCASIONALLY components of a recipe for success.
A well considered approach to solving a RFI problem
requires that you identify the antagonist and deduce
the exact propagation mode from antagonist to victim.
More often than not, the real success comes from fixing
some deficiency in the antagonist or its installation
as opposed to "helping" victims live in the unhealthy
environment.
We need more details about your system: Power levels,
antenna and feed line installation, etc. What systems
are victimized by the transmitter?
Posted: Mon Nov 06, 2006 2:35 pm Post subject: RF ground |
Sorry for the confusion.
I'm not trying to solve an RFI problem. I'm setting up the radios and want
maxiumum transmit and receive abilities and clear audio on both ends. I was
thinking that RF grounds might make the "system" (XCOM/Sonex or CB/F150)
more effecient. I was wondering if braided wire bonding straps were really
better than stranded wire... and if so, why??? And what's the difference in
bonding between VHF (air) versus HF (truck) as far as technic is concerned.
I'm just one of those wierdos that thinks it's cool to hear a guy in the
pattern in Fort Payne, Alabama when I'm in the pattern in Sweetwater,
Tennessee :O)
Rodney in TN
What's so really cool about flying is all the hobbies within the hobby!
DO NOT ARCHIVE
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Mon Nov 06, 2006 7:16 pm Post subject: RF ground |
In a message dated 11/06/2006 4:37:39 PM Central Standard Time, rdunhamtn(at)hotmail.com writes:
| Quote: | I'm just one of those wierdos that thinks it's cool to hear a guy in the
Tennessee :O) |
You ain't got no monopoly on weirdness, specially 'round these parts- wierd thing is that I can communicate with planes in the pattern at airports 100+ miles away on my Microair 760 and still can't hear the damn Cherokee with the ancient radio 1/4 mile away in the pattern at my home base- the really cool thing is that the staff at my home base (SYI) is so cool that they hear me coming in and offer alerts as necessary if they know the offending Cherokee is airborne and nearby- anybody else base at an airport that cool?
Totally shameless plug: Did I mention what a really COOL airport Shelbyville, TN is? Best gas prices anywhere and if ya stop in, grab aholt of the manager and challenge him to his claim that he is the first dude to loop an F-111...
RVs are GREAT & SYI is too!
Mark do not archive
_________________ From The PossumWorks... |
Posted: Tue Nov 07, 2006 4:52 am Post subject: RF ground |
At 05:34 PM 11/6/2006 -0500, you wrote:
was thinking that RF grounds might make the "system" (XCOM/Sonex or
CB/F150) more effecient. I was wondering if braided wire bonding straps
were really better than stranded wire... and if so, why??? And what's the
difference in bonding between VHF (air) versus HF (truck) as far as
technic is concerned. I'm just one of those wierdos that thinks it's cool
to hear a guy in the pattern in Fort Payne, Alabama when I'm in the
pattern in Sweetwater, Tennessee :O)
What are you going to "bond" and to "where"?
When we qualify various appliances both for their
potential roles as antagonists and as victims
the equipment is tested "as installed" in the
airplane.
If you find that there is value in adding a bonding
strap to cure a problem, then this is indicative of
poor appliance design and deficient testing.
Unless the manufacturer's installation instructions
call for extra-ordinary additions of RF bonding
leads, then adding them just for the heck of it
(or in hopes of achieving performance nobody else
has) is wishful thinking.
< with experiment. >
< --Lawrence M. Krauss >
