Tim(at)MyRV10.com Guest
Posted: Sat Nov 04, 2006 8:32 pm Post subject: Cables and heat |
I got a good look around with my lower cowling off yesterday.
I haven't had it off in quite a while, so with a full spark
plug swap it was necessary and provided a good time to check
all of the very bottom areas that I've not checked as often.
I found one thing and now have a suggestion. My prop governor
cable was about 2-3" from the exhaust, just on the front edge
of the heat muff area. You could tell from the sagging green
plastic that this cable had been quite warm at least once.
The cable still operates smoothly, so it seems to be ok. I'm
sure there's a nylon guide inside, which hopefully was protected
from additional heat stress by being surrounded by that steel
sheath. My quick fix was to wrap that area in aluminum tape
to provide some reflection of the heat. I think I should have
taken one more step though. I have some fiberous, very high
temp cloth that's about 1/8" thick. I should have wrapped
the cable with some of that, and THEN surrounded that with
the aluminum tape.
My fuel lines don't get too close to the exhaust, but I noticed
when Vic had his top cowl off that he had a couple of heat
shields that he had made and attached with band clamps around
a couple areas of his exhaust. He had them near one of
the fuel lines, to provide that air gap heat shield for
protection for the lines. I think this would be a good idea
in a couple areas. So, as you're assembling the engine area,
take a good look at your exhaust and if anything is within
3" of it, start thinking of how you can shield it.
I think it might even be nice to put additional shielding
for heat rejection on those firesleeved lines.
zackrv8
Posted: Sun Nov 05, 2006 10:14 am Post subject: Re: Cables and heat |
Tim,
Where my throttle/mixture cables get close to the exhaust on my RV8, I wrapped them in firesleeve. Definetly would be a bummer if these cables melted and were not able to move.
Zack
| Tim(at)MyRV10.com wrote: | I got a good look around with my lower cowling off yesterday.
the aluminum tape.
do not archive |
_________________ RV8 #80125
RV10 # 40512 |
Posted: Sun Nov 05, 2006 12:06 pm Post subject: Cables and heat |
Absolutely! That's why I brought it up...it's a possible safety gotcha.
zackrv8 wrote:
Tim,
Zack
> the aluminum tape.
> Tim Olson - RV-10 N104CD - Flying
> do not archive
RV8 #80125
RV10 # 40512
http://forums.matronics.com/viewtopic.php?p=72416#72416
av8or(at)cox.net Guest
Posted: Sun Nov 05, 2006 3:34 pm Post subject: Cables and heat |
Another way to address the problem is to wrap the exhaust pipe/header with exhaust heat wrap. A friend of mine, who's also an A&P, found the lower cowling on his RV-9A was getting to hot from the exhaust pipes from the discoloring of the inside. He used exhaust/header heat wrap with great success. It's available at your local auto parts stores like Advance Auto, Auto Zone, etc. They come in various widths and lengths. He used the 1" x 50' roll for about $35. Here's a weblink to one: http://www.partsamerica.com/ProductDetail.aspx?categorycode=3638B&mfrcode=DEI&mfrpartnumber=010101
John Lenhardt
#40262
coop85(at)bellsouth.net Guest
Posted: Sun Nov 05, 2006 5:09 pm Post subject: Cables and heat |
I used some similar stuff on my Q-2 a long time ago and have a question for the group. I was cautioned after the fact about the wrap possibly holding moisture and causing long term problems for the pipes. As I think about it, holding moisture on something that gets really stinkin’ hot is somewhat doubtful in my mind but I was wondering if anyone else had hear similar or other concerns about wrapping the pipes.
Marcus
40286
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Lenhardt
Sent: Sunday, November 05, 2006 6:34 PM
Subject: Re: Re: Cables and heat
John Lenhardt
#40262
ScooterF15
Posted: Sun Nov 05, 2006 6:00 pm Post subject: Cables and heat |
For what it's worth: I remember in the literature included with the Vetterman exhaust system, Larry warned against using automotive pipe wrap on his exhausts.
Jim
In a message dated 11/5/2006 8:13:00 P.M. Eastern Standard Time, coop85(at)bellsouth.net writes:
Marcus
40286
John Lenhardt
#40262
zackrv8
Posted: Sun Nov 05, 2006 7:22 pm Post subject: Re: Cables and heat |
Scooter,
Roger that. I talked to Larry on the phone for about 15 minutes on this very subject. He is totally against wrapping the pipes and also against coating the pipes. I can't remember the exact converstaion (it was before LOE 2006), but it has something to do with the pipes being a heat sink on an aircooled engine.
Zack
quote="ScooterF15"]For what it's worth: I remember in the literature included with the Vetterman exhaust system, Larry warned against using automotive pipe wrap on his exhausts.
Jim
Marcus
40286
Another way to address the problem is to wrap the exhaust pipe/header with exhaust heat wrap.? A friend of mine, who's also an A&P, found the lower cowling on his RV-9A was getting to hot from the exhaust pipes from the discoloring of the inside. He used exhaust/header heat wrap with great success. It's available at your local auto parts stores like Advance Auto, Auto Zone, etc. They come in various widths and lengths. He used the 1" x 50' roll for about $35. Here's a weblink to one: http://www.partsamerica.com/ProductDetail.aspx?categorycode=3638B&mfrcode=DEI&mfrpartnumber=010101
John Lenhardt
#40262
RV10 # 40512 |
rvbuilder(at)sausen.net Guest
Posted: Tue Nov 07, 2006 12:42 pm Post subject: Cables and heat |
Sounds like bubkis to me. You are better off keeping the heat in the
pipe and getting it out of the cowling. Also, John Forsling has the
exact opposite recommendation. That being to have pipes ceramic coated
for the reason I mentioned.
One big word of caution on using a wrap, the main reason a lot of
people don't like it in aircraft is because it happens to be good at
holding on to liquids like oil. Not something you want in large
quantity in contact with a very hot exhaust and no way to pull over if
it ignites.
Michael Sausen
-10 #352 (2 more weeks to retrieving my project in TX)
