		tya2(at)4-fly.net Guest
				 Posted: Wed Nov 08, 2006 9:54 am    Post subject: 601 /lycoming exhaust Suggestions |
				Here is the deal on Lycoming 0-235 exhaust systems.   Zenair and AMD sell a 4 into 1 crossover exhaust system with shrouds for the AMD Alarus CH2000.   Same aircraft different names, and a certified aircraft.  Comes complete with shrouds for carb heat and cabin heat.   This is a complete bolt on system for the 0-235 including the short stacks to the cylinders.   A fairly simple system.   The hardest point was getting the hole for exhaust stack right on my CH2000.   This system replaces single side systems that the CH2000 came with.   I still have one good one and one repairable one (if you a welder!!!!) .    The Lycoming 0-235 is used in Cessna 152s, Tomahawks, and Skippers if you are looking for used aircraft exhaust systems.    The Cessna 150 uses a Continental 0-200 and I can't say a 150 exhaust system will work on Lycoming...
  If you don't know what you are doing, call AMD and ask if there CH2000/Alarus system will fit on a 601.   If it does buy it.   I do not regret my new system, although I liked the old system's simplicity better.    Leaking exhaust systems can kill you.   I live in an area where cabin heat and defrost are essential.   My life or my family members lives are not worth fooling around with, carbon monoxide sucks...
  Reg Lukasik, Edmonton, Alberta
  1995 CH2000 with the latest Zenith AMD exhaust system...
  At 11:37 AM 11/8/2006 -0600, you wrote:
  [quote]Will a C-150 exhaust system fit properly onto a 601 with a Lycoming 235?  Does anyone have any recommendations about where to buy an exhaust system that will fit?  Swapping Subaru for 0 235.
  Z coleman
  601 HDS
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
