crazyivan
Posted: Wed Nov 08, 2006 8:24 am Post subject: IvoProp Numbers |
After replacing my GSC Prop with an IvoProp Here are a few numbers for comparison. I have a Kitfox Speedster with a 912 UL (80hp). These aren't strict test condition numbers but they are close...
Conditions: temp-50F Wind<5knots Takeoff weight-appx 920lbs
68" GSC Prop: Takeoff- 300 to 350 feet
Best climb- 900'/min
Max cruise- 108 mph
70" IvoProp Ultralight 3 blade set for cruise:
Takeoff- 250 feet
Best climb- 1200'/min
Max cruise- 120mph
Same IvoProp set for climb:
Takeoff- 200 feet
Best Climb- about 1500'/min
Max cruise- 110mph
_________________ Dave
Piper PA-22/20 |
propellerdesign(at)tele2. Guest
Float Flyr
Posted: Wed Nov 08, 2006 10:22 am Post subject: IvoProp Numbers |
Are we missing something here???
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Ben-PA
Posted: Wed Nov 08, 2006 10:48 am Post subject: Re: IvoProp Numbers |
Noel,
I didn't get the numbers either. They are on the web page.
Max cruise- 108 mph
Takeoff- 250 feet
Max cruise- 120mph
Takeoff- 200 feet
Max cruise- 110mph
Ben
_________________ Sign up on the Kitfox Frappr Map:
http://www.frappr.com/kitfox
You can see where fellow Kitfoxers live and pictures of their planes. Be sure to post some pictures of you, your plane, or share the scenery of the Kitfox world. |
Ben-PA
Posted: Wed Nov 08, 2006 11:51 am Post subject: IvoProp Numbers |
That's weird, I copied and pasted the specs and they didn't come through on the email just like the original.
DO NOT ARCHIVE
crazyivan
torgemor(at)online.no Guest
Posted: Wed Nov 08, 2006 1:39 pm Post subject: IvoProp Numbers |
Well Noel,
| Quote: | Are we missing something here???
You'll have to click this link, to get the numbers.
IMHO., the numbers could be printed here
Torgeir.
Posted: Wed Nov 08, 2006 2:41 pm Post subject: IvoProp Numbers |
I am surprised that Dave's GSC did that good, What stile is it you have on the Warp? straight or taper?
Jan
Float Flyr
Posted: Thu Nov 09, 2006 5:48 am Post subject: IvoProp Numbers |
Got the figures. thanks
They are well ahead of what I'm getting around the same weight on Aerocet
straight floats. I actually haven't done any measurements on take off
distance but the times are around 8 to 10 seconds.
My climb out is initially around 1000fpm (at) 6800rpm.
I cruise at around 6000 to 6200 rpm and the ASI reads around 75 mph GPS
readings average out to around 100mph.
I also changed from a GSC 68" prop to an Ivo in flight adjustable. I found
the performance to be improved but the biggest change is the Ivo is lot
smoother. In fine pitch ( take off ) the Ivo doesn't ingest as much water
as the GSC there fore doesn't have the same problems with water pitting.
One thing that boosted my overall performance was the installation of a Tiny
Tach. The original Kitfox tach was so far out to lunch I doubt it will ever
come back. I'm considering removing it.
Noel
[quote] --
Kitfox III-A
kitfoxjunky(at)decisionla Guest
Posted: Fri Nov 10, 2006 9:33 am Post subject: IvoProp Numbers |
I run an IVO Medium on my 912S powered KF IV. If you want to get an idea of performance off the water...check out this google video showing a landing/takeoff sequence. I have the prop pitched for 100 MPH cruise...and I did not yank or flap it off the water. I can get off much quicker than this if I put my mind to it.
http://video.google.ca/videoplay?docid=-8050884520231071945&q=kitfox
Gary Walsh
KF IV Anphib 912S
C-GOOT
www.decisionlabs.com/kitfox
"Noel Loveys" <noelloveys(at)yahoo.ca>
Sent by: owner-kitfox-list-server(at)matronics.com
11/09/2006 08:47 AM
Please respond to kitfox-list
cc:
Subject: RE: IvoProp Numbers
--> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
Noel
