Richard Pike
Posted: Wed Nov 08, 2006 2:18 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
If you are anywhere close to a normal glide speed, and the spots are staying
lined up, you will not land either short or long, you arrive at the spot.
Perhaps after you figure in the flare and tocuhdown, you might add another
50 feet or so, but the basic concept remains unchanged, you arrive at the
intersect point, which is defined by looking at where the point on the
windscreen intercepts the point on the ground, and neither is moving up or
down.
By the same token, if you see another aircraft at your altitude, on an
intersecting course, and it is moving neither forward or back (or right or
left) relative to your position, you will hit it. Same principle.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Wed Nov 08, 2006 2:41 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
anywhere close to a normal glide speed, >>
Hi there,
I agree with that but with those words you have involved another factor in
the equation.
My point was that you can keep your eye, a spot on the screen and a spot on
the ground in line and either get slow and stall or get fast and dive in. If
you dont believe me you will find that you can draw a straight line at any
angle from horizontal to vertical and an inexperienced pilot reading Johns
post could find themselves in trouble.
Sure the system works OK but only if you monitor the speed which of course
an experienced pilot will do automatically He wasn`t the guy I was worried
about
Cheers
Pat
do not archive .
Posted: Wed Nov 08, 2006 2:42 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
They only thing for sure is that the Ercoupe would get there first, but I
bet that the touchdown spot would be about
Hi there,
ask any glider pilot and he will tell you that there are two best gliding
speeds. One for distance and one for time. Going as far as possible and
staying airborne for as long as possible are not thesame thing.
Cheers
Pat
dhkey(at)msn.com Guest
Posted: Wed Nov 08, 2006 3:36 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
they call it minimum sink the other is called best glide, just like Vx and
Vy.
| Quote: | From: "pat ladd" <pj.ladd(at)btinternet.com>
Reply-To: kolb-list(at)matronics.com
To: <kolb-list(at)matronics.com>
Subject: Re: Kolb Glide Ratio (UNCLASSIFIED)
Date: Wed, 8 Nov 2006 22:42:10 -0000
>the same.>>
Hi there,
Cheers
Pat
Posted: Wed Nov 08, 2006 4:53 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
| If you keep that the point on the windshield and the point on the
ground on
| top of each other, you will touch down at that point. >>
| Hi John,
| seems to me that if you are landing short and try to keep the spot
on the
| windscreen and the spot on the ground lined up you could end up in a
stall
| and in contrast if you are landing long you could finish up in a
steep dive.
| Pat
Hi Pat:
Sorry I confused you. My error.
Hopefully, no one will be dumb enough to hold the spot on the
windshield while stalling or on the other hand, diving into the
ground. I was assuming most folks knew to maintain proper airspeed
while gliding.
Take care, keep up your airspeed, and don't dive into the ground,
_________________ John Hauck
Titus, Alabama |
lcottrell
Posted: Wed Nov 08, 2006 4:57 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
For what its worth, I cut the engine on my Firestar at 8000 feet msl,
established a speed of 45 mph, glided 6 miles to camp. Repeated the same
exercise using a GPS for both only this time I set the speed for 50, ended
up the same place within a 100 feet. The ground level was 3990, (Alvord
Desert)
Larry
biglar
Posted: Wed Nov 08, 2006 8:09 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
OK, according to my calcy-lator, that works out to just under 8:1. And that
at a pretty good altitude. Pretty good - much better than I expected.
Lar.
Larry Bourne
Palm Springs, CA
www.gogittum.com
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Thu Nov 09, 2006 8:16 am Post subject: Re: Kolb Glide Ratio (UNCLASSIFIED) |
| Quote: | | Boeing 737 has a fairly good glide ratio |
There used to be a 'rule of thumb' for the 737 so called 'Double Hush' approach;
Range; Twice your Altitude
Time; Half your Altitude
So, from 30,000 ft; Range about 60 nm, Time about 15 minutes.
That gives a glide ratio of about 12:1, but, like you say, not exactly the best type for an off airport landing !!!
In my current Turbo Prop type, weight and therefore inertia makes a considerable difference in the profile (at idle thrust) with a lightly loaded aircraft going down considerable faster than if your heavy.
FYI
David
Do not Archieve.
jim
Posted: Fri Nov 10, 2006 8:32 am Post subject: Re: Kolb Glide Ratio (UNCLASSIFIED) |
Glide ratio = Lift/Drag
Glide ratio at best glide speed is (Lift/Drag)max, or L/D max.
Kolbs (and all ultralights) have fairly high drag for their size. The amount of lift will be = to the weight, which for an UL is not much while flying (500 to 800# gross weight).
Thus we have a (small number)/(big number), which yields a small number, i.e., poor glide ratio.
Jets have a good glide ratio because they are very low drag (no struts, small thin asymmetrical wing, retractible gear, etc.) and high lift. They are high lift because they fly fast and lift goes up as the square of speed. Best glide on the A4 Skyhawk is 320 Knots. You have a great L/D max, but your rate of descent is 2000 fpm with the gear up. Put the gear down, drop the flaps, and the ROD would probably drop to 6000 fpm.
_________________ Jim
N. Idaho |
Posted: Fri Nov 10, 2006 9:08 am Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
they call it minimum sink the other is called best glide,>>
Hi Dave.
indeed they do. Its about 30 years or more since I flew a sailplane last and
just couldn`t remember the terms. I look at the picture on my den wall now
and there is me in this sleek 19 metre span , shiny fibreglass bird, water
tanks, poitive and negative flaps, retractable wheel, long glass nose with
me almost laying on my back to fly it and I think. Good Grief did I really
fly that.
Heigh Ho. Tempus fugit!
Cheers
Pat
Posted: Fri Nov 10, 2006 2:17 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
Gliders might just be the best looking plane there is. I like flying them
too. I go several times a year.
Date: Fri, 10 Nov 2006 17:08:28 -0000
Hi Dave.
and just couldn`t remember the terms. I look at the picture on my den wall
now and there is me in this sleek 19 metre span , shiny fibreglass bird,
water tanks, poitive and negative flaps, retractable wheel, long glass nose
with me almost laying on my back to fly it and I think. Good Grief did I
really fly that.
Cheers
Pat
Posted: Fri Nov 10, 2006 2:30 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
"David Key" <dhkey(at)msn.com>
them
David:
Maybe as a lawn ornament.
I fly the best looking plane there is, a Kolb mkIII.
My mkIII is also self launching, gives me the option of when and where
I want to land, and allows me to go-around if I screw up my landing.
All the while being mighty purty!!!
Take care,
mkIII, purty, 1 each.
mkIII pilot is purty also.
DO NOT ARCHIVE
Titus, Alabama |
bill_joe(at)bellsouth.net Guest
Posted: Fri Nov 10, 2006 2:56 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
Well said John......hehe
Posted: Fri Nov 10, 2006 3:11 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
Fellow Kolbers take pity on this guy. Having flown too close to the sun
he now suffers from radiation damage.
anonymous bb do not archive
On 10, Nov 2006, at 5:29 PM, John Hauck wrote:
them
David:
Take care,
DO NOT ARCHIVE
Posted: Fri Nov 10, 2006 3:44 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
robert bean <slyck(at)frontiernet.net>
BB:
Naw!
Got a good tan though.
Springlike weather at hauck's holler, alabama.
mkIII (2,583.5 hours)
912ULS (0.0 hours)
Warp Drive (0.0 hours)
Pilot (well-worn)
DO NOT ARCHIVE
Titus, Alabama |
Posted: Fri Nov 10, 2006 3:45 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
Sorry, I didn't mean to send that to the group!!
APilot(at)webtv.net Guest
Posted: Fri Nov 10, 2006 7:58 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
Here is a technical question. I love my Mark III Classic. BUT, it is
noisy. I use a Geo Metro engine which is great, but still noisy. I
have heard that if one cuts a slot in the after part of the exhaust, it
will be quieter. I now get 270 lbs of thrust at 5000 ft density
altitude which is about 325 lbs at sea level. I will be trying this
slot soon along with a thrust test to see if there is a difference in
noise and in thrust. Has anyone ever tried this on a four cycle engine?
Posted: Fri Nov 10, 2006 8:02 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
My experience in sailplanes is limited. The Grob 103 is slick and easy
to fly and stays up with a real good glide ratio. The Schwitzer 2-33 is
a dog, but fun to fly. The most fun and easiest to fly was a PW-3 which
has a glide ratio about in the middle of the Grob and the dog.. But,
all of them required some altutude to operate in and so the beauty of
low level flight is lost. I love my Kolb except for the noise. I am
thinking of building a flying trailer and putting the engine back there.
Richard Pike
Posted: Fri Nov 10, 2006 8:49 pm Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
If you can access Tony Bingelis' book Firewall Forward, it has some good
ideas in it. It is too late right now, I will email you some scans off list
tomorrow.
Richard Pike
Kingsport, TN 3TN0
Posted: Sat Nov 11, 2006 1:28 am Post subject: Kolb Glide Ratio (UNCLASSIFIED) |
I put some Dynamat Extreem sound barrier on the fuse between the ailieron
push pull tubes. Worked well. Another option I tested is to hang it from the
lexan piece that sits behind you. I can send photos if you like contact me
off list.
[quote]From: "Richard Pike" <richard(at)bcchapel.org>
Date: Fri, 10 Nov 2006 23:48:13 -0500
tomorrow.
Richard Pike
