Posted: Sat Nov 11, 2006 7:38 am Post subject: Cockpit Noise |
Just food for thought... Are you sure that all that noise is exhaust noise.
My direct drive VW made enough noise to wake the dead so I added a muffler
and a nice four into one exhaust system where I had four separate unmuffled
pipes. It made no difference. When I switched to a redrive the noise got
MUCH better. Then I got wondering about the muffler so I pulled it off. The
noise stayed the same and the power went up. My conclusion was that the
noise was prop noise.
When I reworked my motor mount to lower the engine the noise came back big
time! Now I think the noise is from vibrations that aren't being dampened as
well by the new mount. The new mount uses Lycoming bushings as vibration
dampeners and they don't work as well as the Lord dampeners that Kolb
supplied. I'm tuning the bushings and looking for softer ones.
So from my experience I would suggest you look at reducing vibrations being
transferred to the airframe and look into sound deadening. David Key has a
suggestion and a product that might help both of us. Dave would you share
your photos with all of us?
Rick Neilsen
Redrive VW powered MKIIIc
dhkey(at)msn.com Guest
Posted: Sat Nov 11, 2006 1:48 pm Post subject: Cockpit Noise |
First the sound proff(SP) stuff is heavy-thick rubber like.
I bought the stuff and folded it over once, put in in my sling seat taped it
over my head. Took off and flew for 10 minutes, then reached back and pulled
the stuff off and there was a big diffrence!!
I put it on the back and put it on my lexan thing.
I'm sure the prop noise was a major factor, so I covered the gap in the back
it was open before. That hole in the back was acting like a giant megaphone
through the cockpit. I was most impressed most by the pieces hung off the
lexan. It works great. It puts the SP right behind my head and goes down to
my mid sholders. It folds against the sides and really works well. I have to
pieces of SP stuck together and the lexan is in the middle. I can really
notice the diffrence and I think the tower can too.
I won't win best looking plane at the next flyin but I'll be able to hear
who does.
(EMail me for pics.)
I got it on Ebay searh for "Dynamat Xtreme Extreme BULK"
I got one 32"x18" Sheet 4 SQ FT, one sheet is all you need.
It costs me $14 plus shipping, all you need is one sheet.
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Wed Nov 15, 2006 1:36 pm Post subject: Re: Cockpit Noise |
Quote: | That hole in the back was acting like a giant megaphone |
Just wondering, Does the Tube back to the tail feathers also act like a drum with each passing of the nearby prop tip thus passing the noise back up the tube to the cockpit cage ?
Has anyone done any work on this theory by having some sound deadening material inside the tube at that point at least ?
Resonation can travel well within the confines of a tube especially if harmonics are involved.
Just curious. David
Richard Pike
Posted: Wed Nov 15, 2006 1:53 pm Post subject: Cockpit Noise |
I cut out a thick plug of foam rubber and stuffed it into the tube just
behind my right elbow to keep cold air from flowing out of it. Don't know if
it is quieter, but my elbow has quit turning blue...
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Wed Nov 15, 2006 2:54 pm Post subject: Cockpit Noise |
David
I have been trying to make my MKIII quieter since I lowered my engine by
adding sound deadening material everywhere I could think of with no luck. I
never considered the fuselage tube but that could be it. definitely worth
checking. My tube is plugged near the tail feathers but not on the fuselage
end so it might be even more noisy.
Good idea.
Rick Neilsen
APilot(at)webtv.net Guest
Posted: Wed Nov 15, 2006 3:23 pm Post subject: Cockpit Noise |
You make a good point of air coming forward in the Mk III tube. I have
been wondering about cutting a louver in the under side of the nose cone
to relieve the vacuum which would also stop the forward movement of air
in the tube. According to Mr. Newton, the reaction would be less from
the forward moving air. However, the drag of a louver would be more.
Hard to figure.
Vic
