Before closing up the top of the TailconeBefore closing up
Rick S.
PostPosted: Tue Nov 07, 2006 9:34 pm    Post subject: Before closing up the top of the TailconeBefore closing up Reply with quote
Actually water tight is easy...the USAF way.
Apply a light coat of proseal the the face of the joggle but not too close to the holes and not the panel. Place a sheet of the "good" plastic wrap like 1 or 2 mil visqueen tightly over the opening, no wrinkles, on top of the proseal AFTER using a hole punch to open up the screw holes, (line the holes up too) install the panel with a bit of petro jelly on each screw snug up the screws and let it sit for a day or two. Remove the panel and using a sharp razor knfe...X-acto works good trim the opening, a single edge razor blade works gfood to get the ozzed bead off the edge of the joggle outside of the skin. I've use this technique to reseal more access panels on the F-16 than I can think about.
Rick S.
40185
Rick S.
RV-10
40185
Tim(at)MyRV10.com
PostPosted: Sat Nov 11, 2006 9:42 am    Post subject: Before closing up the top of the TailconeBefore closing up Reply with quote
John,
I don't mean to nit pick after the fact, but the reason I used
screws was so the hole through the longerons wouldn't have to be
any larger than necessary, hence weaker. I think mine are #8
screws. Not necessarily a big deal, but large holes through
a longeron would be something I'd run by vans. Just posting
here so future builders might benefit from the advice too.
John Jessen wrote:
[quote] Update:
Last night I put in two pieces of angle running across from one side to
the other between the F-1007 and the F-1008 in the tailcone (see
picture). It took a couple of hours to figure out where I wanted it,
cut some angle that was extra, get it to the right shape, drill the
holes and so on. It took another couple hours thinking about it,
talking about it, etc. All for 2 angles that may, just may be used to
hold a magnetometer or some such thing. I can't imagine what some of
the more complex mods are costing folks in terms of build time!
However, do this before putting on the top skin of the tailcone, should
you even remotely consider hanging an AHRS or some other electronic
marvel back there. Worth doing. I'm also going to put in extra wires
for the rudder trim, for the camera in the VS fairing, and for the two
lights in the HS that I turn on when on long final to light up my tail
art.
Finally, at someone's suggestion posted on this list, I downloaded the
MS PowerToy to resize pictures. I use Irfanview to make the photo
albums for my website, but for quick and easy, my goodness, get the
resize powertoy. Well worth the couple minutes to download and
install. Just right click any photo you're viewing and select the size
and you're done. One of the better tools.
John Jessen
#40328 (Hey, Bruce, thanks for the jigs. Just noticed them last night)
*Sent:* Wednesday, November 08, 2006 9:48 AM
*To:* 'rv10-list(at)matronics.com'
*Subject:* RE: Before closing up the top of the
TailconeBefore closing up the top of the Tailcone
Well, one thing for sure, it all depends on which glass unit you
decide on. Rob's 3500 has the AHRS in the unit. The Chelton's have
both remote, with some placing the magnetometer in the wing, the
AHRS in various locations. Etc Etc. I'm not quite settled on the
panel, and not quite settled on air conditioning, or a hat shelf, so
will place a "shelf" aft of the F-1007, just in case, to hold
whatever, or nothing. I almost agree to wait for the top skinning,
but then you have a major component not done. Others have closed it
up, made their decisions, crawled around in amazing contorted
positions to install, and are doing nicely flying from coast to
coast. So.... I'll compromise and move on. I've been on this
tailcone for an eternity and would like to get off of it.
John Jessen
#40328
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*Bill DeRouchey
*Sent:* Wednesday, November 08, 2006 8:46 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Before closing up the top of the
My recommendation is to not button down the top three tail skins
until everything else is completed on the entire aircraft. You
can start and even perform slow taxi tests with these skins
off. If you are going to install a remote magnetometer or AHRS
you can swing the compass and relocate the unit as needed. Keep
all clecos away from the AHRS as they are iron based.
I have constructed a simple shelf aftmost between the main
fuselage longeron and the elevator trim servo mechanism. My
first AHRS in installed in that location was affected by the
trim servo motor (not running). I scrapped this AHRS for other
reasons and now tasked to locate the Cross-bow properly.
You can not locate the AHRS just behind the baggage bulkhead no
matter how high it is installed above the floor. Variable
magnetic fields from the baggage will affect your heading
information in uncontrollable ways.
The Cross-bow has a good hard iron calibration routine so my
next approach will be to locate it far aft and calibrate the
magnetic interferrence from the trim servo motor out of the
heading. With this approach there is only one source of
interferrence.
My suggestion is to delay installation of the three top skins to
the very end. I will report back after I am satisfied with my
AHRS installation.
Bill DeRouchey
billderou(at)yahoo.com <mailto:billderou(at)yahoo.com>
N939SB, flying with a few pit stops
*/Chris <toaster73(at)earthlink.net>/* wrote:
I'd consider the ability to keep it water tight as well.
One other way of thinking about these considerations is just
to not bother
planning ahead. Just finish the airframe and then install
the various
pieces of gear. then you will be sure that it can be
serviced later and you
will have figured out the best way to contort yourself to
get at it for the
future maintenance.
-Chris Lucas
#40072 (cabin side skins)
jjessen
PostPosted: Sat Nov 11, 2006 10:14 am    Post subject: Before closing up the top of the TailconeBefore closing up Reply with quote
It's always good to nit pick. I did think about that, and figured that the
longerons going across might actually be of some stiffening benefit if the
plane wants to hit something solid and those seat belts decide to buckle the
longerons, which they probably would do. The holes, of course, being firmly
filled with the bolts. I may be wrong, and thus my entire tailcone is
ruined and unsafe. Oh, well.
If I were to do it again, I would use something smaller, even simply pop
rivet a lighter angle. I had longeron material left over and went ahead
with trying to beef up the structure.
