CrownLJ(at)verizon.net Guest
Posted: Mon Nov 13, 2006 3:42 pm Post subject: Jim Shumaker VGs |
Jim,
What VG configuration did you end up with and what wing do you have? Did your try to optimize it, or place it as told? I tried to find it in the archives, which was helpful, but I couldn't find the final answer.
larry
Jim Shumaker
Posted: Mon Nov 13, 2006 6:57 pm Post subject: Jim Shumaker VGs |
Larry
I had a reference point that I started from but I applied them several ways. I tried the 10% cord and found it to be way too far back. I wound up with them at 3 inches (horizontal) from the leading edge. Will probably go a little closer to the leading edge the next time I apply them. I tried applying fewer than 100 but that did not work as well. Put one pair in each swale between the ribs and false ribs.
Jim Shumaker
_________________ Jim Shumaker |
Jim Shumaker
Larry
I have the mode III undercambered wing.
Jim Shumaker
Fox5flyer Guest
Posted: Tue Nov 14, 2006 4:36 am Post subject: Jim Shumaker VGs |
Thanks for the information Jim. Were you able to determine any noticeable performance or stall characteristics at the 3 inch point?
Deke
