mgeans(at)provide.net Guest
Posted: Mon Nov 13, 2006 11:26 am Post subject: Lyc Knockoff 92 octane compatable |
Has anyone heard of or had exposure to an experimental
assembled and tested engine with the correct combustion
ration (I think is 8 or 8.5:1) that will allow the use of
92 octane auto fuel?
I met an seasoned hanger flyer once who suggested that I
find the engine that I want to use and then fit an airframe
to it that will suit my needs to alleviate a lot of
headache.
I think Kitplanes has touched on this in the past possibly
with Mftrs as Superior or Titan (engines not kits as in
Tornado or T-51). Don't quote me on the Mftr's as I don't
recall who they were only that they would take the auto
fuel. This could be a promising addition to an airframe
which could pass the time line of avgas extinction. It
would also be cost effective.
This might spark (no pun intended) the auto vs avgas "war"
as I've seen such discussions referred to before.
Matt Geans
Builder Wanna-be
apilot2(at)gmail.com Guest
Posted: Mon Nov 13, 2006 11:54 am Post subject: Lyc Knockoff 92 octane compatable |
I can't help you on the experimental side, but I do know of a pilot
that used to use 91 octane unleaded in his 180hp Lyc O-36A1D (8.5:1
compression) powered Mooney. He sold the aircraft, so I only know what
occured while he had it and was using mogas. Two issues. 1. He was
able to get mogas with MTBE that supposedly was safe for STC'd mogas
use. Obviously that is nearly unobtainable now, and ethanol use is
very widespread, meaning your fuel system better be designed to
withstand ethanol. Even here in PHX he could only get the mogas with
MTBE in the summer, as the fuel was switched to ethanol in the winter.
2. Bigger problem was that mogas eventually disolved the variety of
PRC that Mooney used in 1967 when the plane was built, into a goo, and
the tanks eventually leaked so bad he had to choose between a complete
strip and reseal or go with STC'd bladders. He chose the
bladders..which added 30lbs to his empty wt.
AFAIK he never had any issues with vapor lock nor detonation. However,
that was with standard mags and mag timing. Who knows what would
happen with electronic ignition.
headache.
Matt Geans
Builder Wanna-be
Rick S.
Posted: Mon Nov 13, 2006 12:53 pm Post subject: Lyc Knockoff 92 octane compatable |
On Lycomings site it say mogas of 91 octane is OK to use on the "X" series engines.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Posted: Mon Nov 13, 2006 2:02 pm Post subject: Lyc Knockoff 92 octane compatable |
Pardon my ignorance, all.
What is the difference between mogas and the auto fuel at
my local Shell station? None? Is mogas what the aviation
techies call car gas? IE mo-tor gas-oline?
Matt Geans
Builder Wanna-be
On Mon, 13 Nov 2006 16:24:21 -0500
linn Walters <pitts_pilot(at)bellsouth.net> wrote:
I burn 92 octane in my Pitts. The engine is an
O-360-A-4A. I think it's 8.5 or 9.5 ...... can't recall.
Been using mogas in it for 25 years now. It sees 3300
to 3400 RPM a lot when I'm trying to disorient myself.
I've never had any problems with mogas ..... with
the exception of when I got some fuel with alcohol in it.
Ate up all the rubber diaphragms in the PS-5 carb and
the fuel pump. Lesson learned.
Linn
of
airframe
>headache.
possibly
don't
"war"
>Matt Geans
>Builder Wanna-be
Admin.
page,
Rick S.
Posted: Mon Nov 13, 2006 2:36 pm Post subject: Lyc Knockoff 92 octane compatable |
Motor Gas...or gas used in any gas motor that doesn't fly...things that fly get AVGAS or Jet Fuel (JP-whatever depending on the grade)...MOGAS has been used in airplanes as Linn attests to and many others have used it as well, but in daze of old and 100LL-a-plenty why would you want to use MOGAS and foul your engine?
This was how we easily distinguished the difference in my Air Force days, at the motor pool, all the pumps said Mogas...followed later by Unleaded. I laways thought actual MOGAS leaded fuel and low octane (read cheap) like 85 or less. Others may have other origins...that's my take on the name.
Rick S.
40185
RV-10
40185 |
Posted: Mon Nov 13, 2006 6:23 pm Post subject: Lyc Knockoff 92 octane compatable |
Matt, you're terribly perceptive. With your high level of intelligence, you'll make an excellent builder!!!
Linn
mgeans(at)provide.net (mgeans(at)provide.net) wrote:
[quote] Quote: | --> RV10-List message posted by: <mgeans(at)provide.net> (mgeans(at)provide.net)
Matt Geans
Builder Wanna-be
linn Walters <pitts_pilot(at)bellsouth.net> (pitts_pilot(at)bellsouth.net) wrote:
Linn
| of
| airframe
Quote: | to it that will suit my needs to alleviate a lot of
headache.
| possibly
| don't
Linn
| 0 --> RV10-List message posted by: linn Walters
Linn
| 1 Quote: | Quote: | --> RV10-List message posted by: linn Walters
Linn
| 2 --> RV10-List message posted by: linn Walters
Linn
| 3 --> RV10-List message posted by: linn Walters
Linn
| 4 [b]
Posted: Mon Nov 13, 2006 6:39 pm Post subject: Lyc Knockoff 92 octane compatable |
Rick wrote:
Foul your engine??? The whole reason I went to mogas (auto fuel) is
that I got tired of cleaning the rocks (lead) out of my plugs!!! At
that time, using mogas was akin to heresy. I didn't really want to go
through the hassle of sneaking my fuel onto the airport and into my
airplane, but the hassle of the plugs was bigger.
Quote: | This was how we easily distinguished the difference in my Air Force days, at the motor pool, all the pumps said Mogas...followed later by Unleaded. I laways thought actual MOGAS leaded fuel and low octane (read cheap) like 85 or less. Others may have other origins...that's my take on the name.
Really??? They said mogas??? I have to admit that the only place I put
(military) gas in the vehicles ...... the pump didn't say anything but
how many gallons! No labels, no octane rating .... nothing! There were
two pumps .... diesel and gasoline. Life was much simpler then!!!
Linn
Quote: |
Rick S.
40185
Rick S.
jjessen
Posted: Tue Nov 14, 2006 7:47 am Post subject: Lyc Knockoff 92 octane compatable |
Hey! Don't laugh. I can't remember 5 cents per gallon (it was 30 cents
when I went to college), but I sure did like to watch my uncle's pumps and
the spinning whirl in the glass bulb. I also liked to climb on top of the
tank trucks and watch them get filled with #2 oil. Such was entertainment.
John J
Posted: Tue Nov 14, 2006 10:23 am Post subject: Lyc Knockoff 92 octane compatable |
Rick wrote:
Quote: |
Yeah foul the engine, there wasn't enough octane to keep the plugs from fouling in the line trucks...not with lead but carbon, matter of of fact once a month they would close the runways and the line trucks would get a chance to burn some of it off....yeah there was a diesel pump there too but we were talking mogas...left diesel alone..
Besides Linn....I thought you would comment on when the pumps had "Ethel" on them and you could watch the gas swirl arounf the glass top for a nickel a gallon
Well, those didn't say ethel (ethyl) either. Just had a red star on the
light on top. Turning the crank hurt my shoulder, though! Sure
was an improvement getting electricity out in the boonies! 'Course, I
didn't have too many nickels back then either.
Linn
Quote: |
Rick S.
40185
