0-540 B2B5?
CJohnston(at)popsound.com
PostPosted: Tue Nov 14, 2006 4:54 pm    Post subject: 0-540 B2B5? Reply with quote
Hey all – I perused the archives and couldn’t find anything on the 0-540 B2B5 or its suitability for the RV-10. Anyone know if this is usable, or where I might be able to find out? cj#40410fusewww.perfectlygoodairplane.net
ddddsp1(at)juno.com
PostPosted: Tue Nov 14, 2006 5:28 pm    Post subject: 0-540 B2B5? Reply with quote
Chris,
I believe that is a 235 HP motor with 7.5:1 comp pistons in it. It is compatible with the RV10 if it has the right EARS on the motor mounts. Is it an O-540 or IO-540?
Dean
40449
________________________________________________________________________
Visit http://www.juno.com/value to sign up today!
bcondrey
PostPosted: Tue Nov 14, 2006 5:36 pm    Post subject: Re: 0-540 B2B5? Reply with quote
Chris,
Tim has this info posted on his website at
http://myrv10.com/tips/engine_IO540.html
The basic engine is compatible (it's a parallel valve) however you'll want to check both the mounting ear size as Dean said and also the counterweights. The 2nd digit in the suffix is usually a '4' if it has the proper counterweights for a Hartzel compact hub prop. It might also be missing the prop governer drive gear. Both of these are simple to change (especially with your background).
Take a look at one of the charts on the above web page and you should get all the info you need.
Bob
PostPosted: Tue Nov 14, 2006 5:51 pm    Post subject: 0-540 B2B5? Reply with quote
It’s 0-540. does this mean I can change the pistons and it becomes a 260 hp version?
cj
40410
PostPosted: Tue Nov 14, 2006 6:00 pm    Post subject: 0-540 B2B5? Reply with quote
Sweet. Thanks bob.
bcondrey
PostPosted: Tue Nov 14, 2006 8:29 pm    Post subject: Re: 0-540 B2B5? Reply with quote
Sort of... look at the lineage of yours from one of the basic models and then do the same for the IO-540-D4A5. Most of the differences will be accessories, counterweights, mags, etc.
For your engine, the jugs will have to come off to change the pistons. Doing this also exposes the crankshaft counterweights which could changed at the same time. The other obvious thing was that your engine doesn't have the drive gears for a prop governer. I took a quick look at the parts manual and it appears that you would have to split the case to put them in.
Let me know if you want/need more info and I can get you more detail.
Bob
ddddsp1(at)juno.com
PostPosted: Tue Nov 14, 2006 9:14 pm    Post subject: 0-540 B2B5? Reply with quote
Chris,
We did the exact thing to our B2B5 you wanna do. More than happy to tell you HOW and WHAT if you wanna call. The worm gears for the prop governor drive are PRICEY! Let me know.
Dean 40449
GRANSCOTT(at)aol.com
PostPosted: Wed Nov 15, 2006 4:02 am    Post subject: 0-540 B2B5? Reply with quote
In a message dated 11/14/2006 8:30:26 PM Eastern Standard Time, ddddsp1(at)juno.com writes:
Is it an O-540
O-540
