Fiberglass parts.
pacificpainting(at)comcas
PostPosted: Wed Nov 15, 2006 7:41 pm    Post subject: Fiberglass parts. Reply with quote
Does anyone know if the fiberglass parts supplied by ZAC are polyester or epoxy resin?
larry(at)macsmachine.com
PostPosted: Thu Nov 16, 2006 6:12 am    Post subject: Fiberglass parts. Reply with quote
Dave,
The original parts were polyester. Can't say about current ones, but
I'd bet they still are.
Larry McFarland - 601HDS at www.macsmachine.com
or epoxy resin?
lrm(at)skyhawg.com
PostPosted: Thu Nov 16, 2006 7:03 am    Post subject: Fiberglass parts. Reply with quote
Polyester probably, Isophthalic maybe, epoxy mostly likely not. My guess would be polyester, because it's the easiest to get and cheapest. If they have their work done at a real fiberglass shop (which I doubt, because of the poor workmanship), it would be Isophthalic. Most shops buy Isophtahalic in bulk, it's easier to work, used a lot in chopper guns and is chemical resistant.
But, Polyester is fine for the kind of parts they supply. They are not high stress parts and don't need to be chemical resistant.
Larry, N1345L, www.skyhawg.com
AZFlyer
PostPosted: Thu Nov 16, 2006 1:10 pm    Post subject: Re: Fiberglass parts. Reply with quote
Dave,
If your asking polyester vs epoxy because you plan to add material to the tips, I seem to recall using epoxy when I modified the really poor quality parts supplied. I believe epoxy resin will stick to either, but polyester resin has a hard time with anything except polyester.
Rough up the surface before applying, mix in micro-balloons, and when dry, you can shape it to whatever. I can not believe ZAC sends out such poor quality fiberglass parts...
Mike
Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"!
