air.guerner(at)wanadoo.fr Guest
Posted: Fri Nov 17, 2006 12:36 am Post subject: oil thermostat vs cowl flap |
Hello Nigel,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Thank you for your comments on my inlet cowl flap you saw in <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />Vichy. Some additional information: the lower position is to be used on the ground only. The flap must be raised to the neutral position just before take-off. If you don’t, it is very difficult to actuate in flight due to the huge aerodynamic forces. From neutral to the upper position, it can be adjusted at will in flight to control the CHT and oil temperatures: especially useful in winter.
Remi Guerner
F-PGKL, XS S/N395 monowheel, 912S, Airmaster, 435 hours
When I was at Vichy this year I met one of our French owners (sorry I
forgot his name). He has a very clever inlet cowl flap. It is part of
the lower cowl in front of the radiators and has a hinge at the rear of
it. In very hot weather it is lowered below the normal cowl allowing
more cooling air in. In cold weather it is raised impeding airflow to
the radiators. This is all controlled from the cockpit so that inflight
adjustments can be made. [quote][b]
nwcmc(at)tiscali.co.uk Guest
Posted: Sun Nov 19, 2006 4:37 am Post subject: oil thermostat vs cowl flap |
Hi Remi
Thanks for coming back to me. If you have any photos or diagrams showing your setup I would be grateful. In particular how you arrange the linkage and control of the flap would be interesting.
Probably best to communicate direct to me at nwcmc(at)tiscali.co.uk (nwcmc(at)tiscali.co.uk).
Nigel Charles
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Rémi Guerner
Sent: 17 November 2006 08:35
Subject: oil thermostat vs cowl flap
Hello Nigel,
Thank you for your comments on my inlet cowl flap you saw in Vichy. Some additional information: the lower position is to be used on the ground only. The flap must be raised to the neutral position just before take-off. If you don’t, it is very difficult to actuate in flight due to the huge aerodynamic forces. From neutral to the upper position, it can be adjusted at will in flight to control the CHT and oil temperatures: especially useful in winter.
Remi Guerner
<![if !supportLineBreakNewLine]> <![endif]> [quote] -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!) November is the Annual List Fund Raiser. Click on the Contribution link below to find out more about this year's Terrific Free Incentive Gifts provided by: * AeroElectric www.aeroelectric.com * The Builder's Bookstore www.buildersbooks.com * Aeroware Enterprises www.kitlog.com * HomebuiltHELP www.homebuilthelp.com List Contribution Web Site --> http://www.matronics.com/contribution Thank you for your generous support! -Matt Dralle, List Admin. - The Europa-List Email Forum - --> http://www.matronics.com/Navigator?Europa-List [b]
