		RRTRACK(at)AOL.COM Guest
				 Posted: Sat Nov 18, 2006 8:26 pm    Post subject: KITFOX HELP NEEDED |
				Hello Kitfox owners and builders
    I am the proud new owner of a very nice Kitfox V Vixon. I am  having it transported, and need help to remove the wings for transport. If there  is anyone that is familiar with removing the wings on this model so I can get it  into an enclosed trailer I would like to talk to you. It is in the Atlanta area  if anyone could help on Monday afternoon.
    I built an Avid Flyer in 1987 and have been flying it ever since. I  love the Avid, but want to move up to a newer faster type of plane without the  losing the fun factor the Avid always has.
    This forum has provided a lot of useful information and inspiration.  I hope this Kitfox will keep me enjoying the thrill of flight for the next 10  years or more.
  Mark
  RRTRACK(at)AOL.COM (RRTRACK(at)AOL.COM)
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		roncarolnikko(at)hotmail. Guest
				 Posted: Sat Nov 18, 2006 9:24 pm    Post subject: KITFOX HELP NEEDED |
				Mark I can tell you some of the things to be careful with.   The fuel from
 the tank and hose must not touch the window so have plans to plug both the
 line and tank if cut or what is needed.  Secure the flaperon so as not to
 over rotate and damage where the hinges will hit the end of slots.  I folded
 the wings and hung from rafters in garage with a rope safetied to each spar
 and a strap around wing near tip.  Ropes to pull slightly away from
 fuselage. Removed strut brace, all strut nuts, lower bolt, then upper bolts
 to free the strut.  The plane then rolled forward and left the wings
 hanging.  Two people make the job a breeze in a garage.  Good luck and good
 questioin as prevention is WAY better than the cure.   Ron NB Ore
  	  | Quote: | 	 		  From: RRTRACK(at)aol.com
 Subject: KITFOX HELP NEEDED
 Date: Sat, 18 Nov 2006 23:26:20 EST
 anyone
 into
 if
 love
 years or more.
 Mark
 _RRTRACK(at)AOL.COM_ (mailto:RRTRACK(at)AOL.COM)
 Fixing up the home? Live Search can help
		smokey_bear_40220(at)yaho Guest
				 Posted: Sat Nov 18, 2006 10:06 pm    Post subject: KITFOX HELP NEEDED |
				Hi Mark,
 To add another method, here is how I did mine for
 transport:
 First, as was already said, use 2 people.  Much less
 risk.
 I leveled my plane, since mine is a tail dragger, but
 you are ahead on this already.
 Second, disconnect all flight control, fuel and wiring
 connections.
 Third, I found that a padded step ladder fit under my
 wings near the outboard end at a rib.  Not sure if the
 trigear will fit the same???  The taildragger gear may
 be taller.
 Fourth, remove the lift struts being careful not to
 damage anything top or bottom.  Remove the bottom bolt
 first, but leave in place.  Lub the bottom for easier
 removal.  Undue the top bolts and be careful for wing
 setteling.  Make sure not to drop the strut and bend
 the bottom tabs.  The second person may need to lift
 the wing slightly for strut removal at the top.  Once
 the top is disconnected, rotate the strut gently fore
 and aft to undue the bottom.  Don't poke your wing
 while looking at the bottom.
 Fifth, undue the spar bolts and carefully remove the
 wing with someone on both ends.
 Nothing extra needed except the ladder and padding.
 Make sure to have a place to lay the wing down.  I
 built 2 inverted "T" stands with padding for the wings
 to stand on their noses on either side of the T.  Just
 strapped the wings to the T's.
 Kurt S.  S-5
 --- RRTRACK(at)aol.com wrote:
  	  | Quote: | 	 		   Hello Kitfox owners and builders
  years or more.
  Mark
 Don't quit your job - take classes online
 www.Classesusa.com
		Tom Jones
				 Posted: Sun Nov 19, 2006 6:07 am    Post subject: Re: KITFOX HELP NEEDED |
				Mark, I have no Vixen experience but did learn wing instilation and removal by the school of hard knocks building my classic 4.  You probably already know this from your Avid building, but just in case, here's some things to think about.
 It is very easy once you know how.  At least one helper is a must.  Two helpers is better.  Proping the wing tip up before you start takes the strain off one helper.
 Before you remove any strut or spar attach bolts or pins have the helper hold on to the wing tip and keep ahold of it until the wing is off the plane.  It is hard to visulize what will happen when you start removing the attachment hardware.  It can fool you and a wing can swing foreward or backward by suprise and you cannot stop it by yourself.  Your hands will already be full.
 I suspect the Vixen will stay upright on its wheels with one wing but be ready for it to tip to the other side when the first wing is removed.
 Tom Jones
