		kirkhull(at)kc.rr.com Guest
				 Posted: Mon Nov 20, 2006 4:18 pm    Post subject: prop pitch and reduction |
				I was just wandering what pitch people were running with what reduction ratio?
 I was told by the prop shop that with a 100 HP and 2.2 reduction on a 70” warpdrive to use around 14 deg.  I have been using 17 ˝  deg and getting a little noise from the reduction  at low power settings
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Malcolmbru(at)aol.com Guest
				 Posted: Mon Nov 20, 2006 4:42 pm    Post subject: prop pitch and reduction |
				is the plain level is the prop hub  perfectly vertical?  do you  realy have 17%? becouse 3% would give you a realy weard rpm setting at max  rpm    mal
				 Posted: Mon Nov 20, 2006 8:11 pm    Post subject: prop pitch and reduction |
				The procedure done to set the pitch was correct with 17 ˝ being the correct pitch ( using same equipment used to set pitch on connies ) I think that the prop shop was thinking that was a lot of pitch for an 80HP engine but the 100 HP seems to have no problem with it other then the slight noise at idol.  I was just wandering if others were using that much pitch with a similar reduction ratio.  I have a Subaru with a 2.2 reduction.  What are others running?
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Malcolmbru(at)aol.com
  Sent: Monday, November 20, 2006 6:41 PM
  Subject: Re: prop pitch and reduction
    	  | Quote: | 	 		  |   www.aeroelectric.com  | 	  0123456789012345
		propellerdesign(at)tele2. Guest
				 Posted: Mon Nov 20, 2006 11:44 pm    Post subject: prop pitch and reduction |
				Kirk,
  100 HP at what engine / prop RPM ?
  and what it top Speed?
  with 100 HP you will make 115 - 120 MPH  SL ??
  say 2500 RPM and 117 MPH for an example will be  around 16,7 deg (at) 75% of the radii.
  2400 RPM and 117 will be 17,35 deg (at) 75%  radii
  2300 RPM and 117 will be 18 deg (at) 75%  radii
  Jan Carlsson
  www.jcpropellerdesign.com
  [quote]   ---
				 Posted: Tue Nov 21, 2006 6:13 am    Post subject: prop pitch and reduction |
				I have a stratus 100 HP Subaru conversion with a 2.2 to 1 reduction and a 70 in warpdrive.  The max Hp is at 5400 RPM but I am getting 115 mph at 4500 RPM and full power
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of JC Propellerdesign
  Sent: Tuesday, November 21, 2006 1:44 AM
 Kirk,
 Jan Carlsson
				 Posted: Tue Nov 21, 2006 7:25 am    Post subject: prop pitch and reduction |
				Kirk,
  My guess is you have 85 - 90 hp at 4500, The  stratus page didn't say max torque, (should be in that rpm range)
  If you want all Power (and if engine have) at  5400 my "guess" is that you need 17 - 17,5  deg at 75% (not at  tip)
  and if you have just 90 hp at 5400 you want 16,25 -  16,75 deg
  If you know where max torque is, it is a good thing  to prop it so you are around or above that rpm at climb speed.
  I think if you reduce the pitch little you will  gain speed and climb
  Jan
  [quote]   ---
				 Posted: Tue Nov 21, 2006 8:25 am    Post subject: prop pitch and reduction |
				Thinks I will try 16.5 and see what happens.  Max torque is at 3800 RPM
  Sent: Tuesday, November 21, 2006 9:24 AM
 Kirk,
 Jan
