k4cod(at)bellsouth.net Guest
Posted: Sat Nov 18, 2006 8:36 pm Post subject: Oil Filter Cooler |
Is anyone still using this list? I have a question. Has anyone tried
putting cooling fins on the oil filter to help with summer time oil cooling
problems? I purchased some clamp on fins from J.C. Whitney a while back,
but haven't ever installed them. Just wondering if anyone has tried this
and if it did any good. During July and August here in the south I have to
watch my temps pretty closely and keep the cruise rpm down a bit.
Jim Weston
CH601HDS with Stratus since 1998
Concord, Georgia
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
gkrysztopik(at)satx.rr.co Guest
Posted: Sun Nov 19, 2006 4:57 am Post subject: Oil Filter Cooler |
Hey Jim,
Yup, I'm still here. I was wondering about those too. I thought my
cooling was perfect but after moving to TX, I found it was on the edge
during the summer. I opened my inlet more and that let me fly thru the
summer but I still had to step climb to keep it cool. I hate to go with
an oil cooler so I'm interested in any options. I'm hoping that a new
cowling design will do it. Maybe the larger oil pan from RAM? Maybe an
air duct to the oil filter in addition to the fins? Maybe an oil cooler
is best, we'll see.
gary
d3dw(at)sbcglobal.net Guest
Posted: Sun Nov 19, 2006 5:09 am Post subject: Oil Filter Cooler |
Hi Jim,
Yes, I did the very same thing with no effect, though the ones I used were small.
Jim, I live in Longview, Texas, as you may remember, and flying in the high nineties is a regular thing in the summer.
My oil temp rarely exceeds 190 degrees now. I haven't seen it reach 200 in over four years even in the hottest weather. I attribute this to two things.
1. My muffler is totally wrapped in a heat muff with air pasing over it all the time. this alone will reduce oil temp by as much as thirty degrees.
2. I have an adjustable door/window in the cowling directly in front of the oil pan...and baffles on the lower cowl along either side of the oil pan to direct flow. In the winter I have to close it to heat the oil and warm up more quickly. This door is simply a square piece of sheet with an angle added on the lower edge for handle on the inside to slide it up and down. It is through bolted with little round head bolts...one on each side to hold it at one of three settings: wide open, medium and nearly closed.
Jim Weston <k4cod(at)bellsouth.net> wrote:
[quote]--> Stratus-List message posted by: "Jim Weston"
Jim Weston
Concord, [quote][b]
kellymeiste(at)jcwifi.com Guest
Posted: Sun Nov 19, 2006 7:52 am Post subject: Oil Filter Cooler |
Jim,
Yes I installed the JCW fins on my oil filter.
I also purchased the JCW remote oil filter kit. I now have my oil filter
under the belly of the plan approx under the passengers feet. This kit also
allows for an oil fitter that's twice the size of the wix filter that is
used on a stock installation. This setup allows for very easy oil filter
changes (I like that). Also with the large oil filter and approx 6 feet of
oil line to fill I now run an extra qt of oil in my system. The location of
the oil filter with the heat sink fins installed acts like a small oil
cooler.
My oil temp is much more stable now under all conditions. My oil temps in
the summer still run in the 215 - 220 range but like I said it seems to hold
there better without a sudden up swing in oil temp if I climb. The stable
oil temp really helps keep the water temps down also.
My installation has the exhaust wrap plus a heat shield between the muffler
and oil pan, and a additional air scoop just below the oil pan.
Photos of these installations are available if you wish to see them.
BUT if I lived in TX I think I would opt for the installation of a small oil
cooler.
Kelly Meiste
601 HD (150 hrs)
Posted: Sun Nov 19, 2006 11:37 am Post subject: Oil Filter Cooler |
<![if !supportLists]>1. <![endif]>My muffler is totally wrapped in a heat muff with air pasing over it all the time. this alone will reduce oil temp by as much as thirty degrees.
I had to remove the stock exhaust to get my oil temps anywhere near normal. It was ceramic coated and wrapped, and I tried a simple heat shield that didn’t seem to work so I made both pipes go straight back into a single muffler under the belly. That improved my temps a lot. That was with an enclosed cowling. Then I opened the bottom like the zeniths and that helped a lot. I’d like to enclose the cowling again so I’ll be reworking everything soon. I spose the oil cooler makes sense.
gary
fultz(at)trip.net Guest
Posted: Sun Nov 19, 2006 5:31 pm Post subject: Oil Filter Cooler |
Jim,
Have you got plenty of airflow over the oilpan? That's all it took on a
friends AVID.
Andy
Posted: Mon Nov 20, 2006 7:35 am Post subject: Oil Filter Cooler |
Andy,
I have the Zenith scoop at the front of the cowl and I opened up some slots
on the bottom rear of the cowl to allow some high pressure air to flow
through and over the back side of the oil pan. This helped some, but my oil
temps still run a bit higher than I'd like during summertime temps. I also
wrapped my pipes and muffler with high temperature exhaust wrap that I'm
told is used on race cars. That seemed to help the most. The heat from the
muffler seems to be the biggest offender. So, I can see where Gary would
have received a lot of help from moving the muffler to the underside of the
aircraft.
Jim
Posted: Mon Nov 20, 2006 11:00 am Post subject: Oil Filter Cooler |
Jim,
From my experience you have assessed this correctly. The muffler heat is the offender. If you have room to wrap your muffler in a heat muff with 1/2" or so space, then duct air into it and out, it will do wonders. I use mine for cabin heat and it is plenty, as well as shielding the oil pan and blowing cool air over the muffler continuously. Like I said earlier, I recorded very significant reduction in oil temp.
I made my muff with a small sheet of aluminun...rolled to fit and connected with a strip of nut plates. On either end I used semi-circular aluminum standoffs of 1/4" plate, like two "C's" butted against each other for a spacer to creat the 1/2" chamber around the muffler. Has worked great now for years.
Earlier in the process I tried wrapping the manifold in exhaust wrap, too, but I didn't like that. don
Andy,
aircraft.
Jim
frank.hinde(at)hp.com Guest
Posted: Mon Nov 20, 2006 11:11 am Post subject: Oil Filter Cooler |
Just for fun, Have you tried dropping your sensor into a pan of boiing water?...I have known guages to read incorrectly.
Frank
From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Don Walker
Sent: Monday, November 20, 2006 10:59 AM
To: stratus-list(at)matronics.com
Subject: RE: Oil Filter Cooler
Jim,
Andy,
aircraft.
Jim
-----Original Message-----
[mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Andy Fultz
Sent: Sunday, November 19, 2006 8:31 PM
--> Stratus-List message posted by: "Andy Fultz"
Jim,
friends AVID.
Andy
n556p(at)yahoo.com Guest
Posted: Mon Nov 20, 2006 11:16 am Post subject: Oil Filter Cooler |
Yes, Jim,
There are still some of us monitoring this list. Not much action
recently.
I've heard that the oil filter cooling fins do work. I have no
personal experience with them, yet. I plan to put them on the filter
on my Stratus when I get ready to fire it up.
Phil Raker N556P Zenith HDS/Stratus ~85% completed
| Quote: | From: "Jim Weston"
Subject: Oil Filter Cooler
tried putting cooling fins on the oil filter to help with summer
time oil cooling problems? I purchased some clamp on fins from
J.C. Whitney a while back, but haven't ever installed them. Just
wondering if anyone has tried this and if it did any good. During
July and August here in the south I have to watch my temps pretty
Jim Weston
Concord, Georgia
Compare mortgage rates for today.
Get up to 5 free quotes.
Www2.nextag.com
Posted: Mon Nov 20, 2006 7:53 pm Post subject: Oil Filter Cooler |
Greetings Frank!
Nice to hear from you again, glad to see your still monitoring this list.
Kelly
Do not achieve
vadert(at)telusplanet.net Guest
Posted: Mon Nov 20, 2006 8:32 pm Post subject: Oil Filter Cooler |
List
I began subscribing to the list about three or four months ago. Thought the list was dead. Good to see others are using it. I don't have a Stratus but do have an EA81 with belt redrive in my Kitfox IV. First flight was Aug 26 2005, Second flight same day, engine out, off field landing, lots of damage. Engine fired up and ran smoothly two days after accident. Airframe is currently repaired and am going over the engine/fuel sytem/electrical this winter. Aerocarb Throttle body, Leburg ignition. Reductions belt redrive. Haven't positively identified the cause of the engine out yet but will work through things over the winter. Looking forward to more posts to get more information on possible weak spots to monitor when I fly again this spring. Can't wait.
Tim Vader
Kitfox IV
Calgary, Alberta,
Posted: Tue Nov 21, 2006 7:23 am Post subject: Oil Filter Cooler |
Two things to look for.
1) The Subaru ignitor chip is notoriously feeble...You really should replace this with a TP 45 module from NAPA.
2) Did you have a valve guide failure?...It would be unusual for this to stop the engine completly though.
Frank
From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Tim Vader
Sent: Monday, November 20, 2006 8:31 PM
Subject: Re: Oil Filter Cooler
List
Tim Vader
Kitfox IV
Calgary, Alberta,
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.kitlog.com">www.kitlog.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Stratus-List">http://www.matronics.com/Navigator?Stratus-List
Posted: Tue Nov 21, 2006 7:25 am Post subject: Oil Filter Cooler |
Hello Kelly,
Yes this was such low volume I forgot to unsuscribe...But I will hang around an reply if anyone needs my opinion (whether they think they do or not... ..)
Frank
From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Kelly Meiste
Sent: Monday, November 20, 2006 7:54 PM
Greetings Frank!
Kelly
Do not achieve
GKrysztopik(at)satx.rr.co Guest
Posted: Tue Nov 21, 2006 8:15 am Post subject: Oil Filter Cooler |
when did the enigne die - climbout or level cruise? full-power? i ask
because fuel flow can be an issue. has fuel flow been tested on the
ground at climbout attitude? is there a three-stage fuel filtering
system (course filter in tank, gascolator, and fine filters before
carb)? were gascolator and filters clean? is there redundant power to
the ignition (or computer)? if not, there should be and if so, was
backup power on or did it not keep the engine running? how long was
the engine running before it died? was it very hot? electricals can
quit when hot then work again when cold. is the alt working and wired
correctly? maybe it was running off of the battery until it died.
good luck, send more info so we can brainstorm. also send to
airsoob/flysoob and others can suggest things to check. email lists
are great for group troubleshooting.
gary
Posted: Tue Nov 21, 2006 8:24 am Post subject: Oil Filter Cooler |
Kelly,
Do you have a specific JCW number for the fins and remote oil filter
kit? I'd be very interested in seeing the pictures
of your remote filter installation and mounting. This sounds like a
really keen application.
Larry McFarland - 601HDS at www.macsmachine.com
Kelly Meiste wrote:
<kellymeiste(at)jcwifi.com>
Jim,
filter under the belly of the plan approx under the passengers feet.
This kit also allows for an oil fitter that's twice the size of the
wix filter that is used on a stock installation. This setup allows for
very easy oil filter changes (I like that). Also with the large oil
filter and approx 6 feet of oil line to fill I now run an extra qt of
oil in my system. The location of the oil filter with the heat sink
fins installed acts like a small oil cooler.
in the summer still run in the 215 - 220 range but like I said it
seems to hold there better without a sudden up swing in oil temp if I
climb. The stable oil temp really helps keep the water temps down also.
muffler and oil pan, and a additional air scoop just below the oil pan.
small oil cooler.
Kelly Meiste
601 HD (150 hrs)
Posted: Tue Nov 21, 2006 7:01 pm Post subject: Oil Filter Cooler |
Hi Larry,
Yes I still have the info & photo's, I'll try to dig it out for you
tomorrow.
FWIW, I just re-installed my radiator heater last weekend, this time I made
adjustable louvers to dump the hot air out the bottom if I fly on warm days,
I'll shoot you a photo of that installation as well.
Have a Happy Thanksgiving with the family!
Kelly
don not achieve
Posted: Thu Nov 23, 2006 11:00 pm Post subject: Oil Filter Cooler |
Frank
Thanks for the advice. I'm running the Leburg (www.leeburg.freeserve.co.uk/) ignition system. Two magnets on a modified drive pulley on the crankshaft give my ignition module timing and RPM data. The ignition module then tells the coil when to fire each of the plugs. Advance curve is built into the ignition module. I found the stock Subaru electronic ignition finicky and replaced it with this system early on. Seems to work very well but I will be dualling the system from the coil on back before next flight.
I had 50+ hours of ground running on the engine before first flight and didn't seem to have any problems. The engine fired up and ran smoothly two days after the accident. What would be the symptoms of a valve guide failure?
Tim Vader
Posted: Fri Nov 24, 2006 5:48 am Post subject: Oil Filter Cooler |
Kelly,
I'd be interested to see your pics of the remote filter
installation and cowl flaps, too. Thanx muchly.
| Quote: | From: "Kelly Meiste"
for you tomorrow.
this time I made adjustable louvers to dump the hot air out
the bottom if I fly on warm days, I'll shoot you a photo of
Kelly
Posted: Fri Nov 24, 2006 9:01 am Post subject: Oil Filter Cooler |
Usually the engine will "cough" as it snaps off chunk of guide which then gets mashed in the combustion chamber.
Engine stoppages have happened though, if yours just quit without running really rough before hand I would suspect the ignition system.
Is it possible you had oil starvation?...Unlikely, but I know the that some Soob motors have the oil pickup over an inch above the floor of the sump and it gets uncovered duing climbout.
Did you have fuel pressure at the carb when the engine quit?
Good luck...I know the feeling...I think I have just trashed my new Lycoming...Wont know till I get the borescope test one next week but I think I have...I feel sick..
Frank
Sent: Wednesday, November 22, 2006 8:56 AM
Frank
Tim Vader
