601XL Wing trouble - check the print first!
slook(at)mchsi.com
PostPosted: Tue Nov 21, 2006 6:38 am    Post subject: 601XL Wing trouble - check the print first! Reply with quote
Yep. I have the most current of both the plan and the assembly
manual. The error is in the current assembly manual. My bad for not
cross-checking with the print.
Just tossing this out here as a warning to anyone else just starting
that you have got to check the print rather than blindly use the
assembly manual.
Steve
At 09:45 PM 11/20/2006, you wrote:
The prints are the bible. I always check the ZENITH AIRCRAFT
BUILDERS PAGES to see if there are any updates before moving on to
the next major section of the prints.
I just did it for you
6-W-8 08/05 WING SKINS
08/05 is the most current update to that print.
Steve Look
Monticello, IL
www.ilrt66.com
"Dogs have owners, Cats have staff"
