Painting N601EZ is finally done
larry(at)macsmachine.com
PostPosted: Tue Nov 21, 2006 3:24 pm    Post subject: Painting N601EZ is finally done Reply with quote
Hi guys,
N601EZ is finally painted and the annual inspection was finished this
morning. There were questions about how much paint was added to the
airplane by weight. Until W& B this morning I’d only measured thickness
from .0015 to .0025. The plane gained 15 lbs, not counting going to
thicker gear plate weldments 1-lb each, 6 lbs of wheel pants etc. The
empty weight for paint went from 729 lbs to 744 lbs. That’s 3 to 4 lbs
more than I’d calculated for a1-1/2-gallon base coat, 1-gallon trim coat
and 2-gallons of primer. I had a quart of base color, a quart of white
primer and ½-gallon trim color left over. Idaho Snow and Bayou Blue.
Really pleased with the paint and the process. I made more work of it
(April to November) than most and nearly every mistake as well. Even so,
I’d recommend the paint to anyone who wants to paint at home. It’s very
forgiving and extremely tough. Most mistakes are repairable and the
process is consistent throughout. I was given a cell phone number for
24/7 tech support and used it more than once. Their manual is very good
and describes all the paint processes for the aluminum aircraft in
easily understood English.
I spent under $2800.00 for the paint, 2 paint guns, booth, fresh air
system, filters, lacquer thinner, distilled water, timer, spares et all,
etc. A chapter member builder wanting to paint his RV6 bought everything
but the DeVilbiss finish gun. The booth was marked for reassembly,
knocked down in the space of 2 hours, loaded into a pickup bed and was
gone within two days of mentioning it at a chapter meeting. This too
reduced the cost.
It’s the paint job I wanted, without getting too near a professional
job. It cleans up well and improves what was becoming a scruffy
unpainted 601. There are several things to do like soundproofing and
completing the interior. Best recommendations, paint before flying if
you can. I know, it's just too much fun to stop, but you’ll save 100
hours of cleaning and surface prep.
Links below show the finished product and my paint page shows the booth,
special equipment and processes involved.
http://www.macsmachine.com/images/completion/full/601ezclosefrtrt.gif
http://www.macsmachine.com/images/completion/full/601ezfrontright.gif
Anyway, I had to show it to you,
Happy flying,
Larry McFarland at www.macsmachine.com
gboothe(at)calply.com
PostPosted: Tue Nov 21, 2006 3:53 pm    Post subject: Painting N601EZ is finally done Reply with quote
Larry,
She's a beauty!!
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
N601EZ is finally painted...
pacificpainting(at)comcas
Larry,
You probably said this in a previous post, but what paint did you use?
Wasn't it the waterborne stuff. NICE PAINT JOB.
Dave in rainy Salem
gfmjr_20(at)HOTMAIL.COM
PostPosted: Tue Nov 21, 2006 3:55 pm    Post subject: Painting N601EZ is finally done Reply with quote
Larry--
Nice job-----------bet your glad it's over with
George May
601XL912s
Reply-To: zenith-list(at)matronics.com
To: zenith-list <zenith-list(at)matronics.com>
Subject: Painting N601EZ is finally done
Date: Tue, 21 Nov 2006 17:22:33 -0600
Hi guys,
from .0015 to .0025. The plane gained 15 lbs, not counting going to thicker
gear plate weldments 1-lb each, 6 lbs of wheel pants etc. The empty weight
for paint went from 729 lbs to 744 lbs. That’s 3 to 4 lbs more than I’d
calculated for a1-1/2-gallon base coat, 1-gallon trim coat and 2-gallons of
primer. I had a quart of base color, a quart of white primer and ½-gallon
forgiving and extremely tough. Most mistakes are repairable and the process
is consistent throughout. I was given a cell phone number for 24/7 tech
support and used it more than once. Their manual is very good and describes
all the paint processes for the aluminum aircraft in easily understood
English.
but the DeVilbiss finish gun. The booth was marked for reassembly, knocked
down in the space of 2 hours, loaded into a pickup bed and was gone within
two days of mentioning it at a chapter meeting. This too reduced the cost.
It’s the paint job I wanted, without getting too near a professional job.
It cleans up well and improves what was becoming a scruffy unpainted 601.
There are several things to do like soundproofing and completing the
interior. Best recommendations, paint before flying if you can. I know,
it's just too much fun to stop, but you’ll save 100 hours of cleaning and
surface prep.
Happy flying,
Get free, personalized commercial-free online radio with MSN Radio powered
by Pandora http://radio.msn.com/?icid=T002MSN03A07001
naumuk(at)alltel.net
PostPosted: Tue Nov 21, 2006 4:43 pm    Post subject: Painting N601EZ is finally done Reply with quote
Congrats.
Bill Naumuk
HDS Fuselage
Townville, Pa
Gig Giacona
PostPosted: Tue Nov 21, 2006 5:23 pm    Post subject: Re: Painting N601EZ is finally done Reply with quote
Great job. I've got a question for you. The color on the tail where the N# is. Is that paint or vinyl?
W.R. "Gig" Giacona
601XL Under Construction
PostPosted: Tue Nov 21, 2006 5:54 pm    Post subject: Painting N601EZ is finally done Reply with quote
Gig,
The numbers are vinyl and the blue whatchamacallit is paint. I'd have
surely used vinyl if I'd known any more about vinyl before I
decided to paint the blue there. Additional trim lines or decoration
will certainly be vinyl as it is easy to get centered and sticks well.
Larry McFarland
W.R. &quot;Gig&quot; Giacona
PostPosted: Tue Nov 21, 2006 5:57 pm    Post subject: Painting N601EZ is finally done Reply with quote
Dave,
Gig,
The paint is the water thinned urethane and catalyst called waterborne
paint. In stead of the high VOC thinners that only thin and convey the
paint, they do not isolate the isocyanate's that can kill you. With AFS
paint, distilled water used to thin and deliver the paint and it also
captures the isocyanate's so they don't go after your lungs and tear
ducts. You can be harmed if you oversaturate your booth by not moving
air or forget to wear your respirator. Refer to the link below for more
information.
http://www.stewartshangar21.aero/AFS.htm
Dave Ruddiman wrote:
<pacificpainting(at)comcast.net>
Larry,
Dave in rainy Salem
> <larry(at)macsmachine.com>
> Hi guys,
> morning.
bob(at)frontrange-pc.com
PostPosted: Tue Nov 21, 2006 7:44 pm    Post subject: Painting N601EZ is finally done Reply with quote
Larry! - She's a thing of beauty!
Bob Percival
701 - plans - glacial pace
Ron Lendon
PostPosted: Tue Nov 21, 2006 8:27 pm    Post subject: Re: Painting N601EZ is finally done Reply with quote
Looking good Larry. Very inspiring!
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
