GenGrumpy(at)aol.com Guest
Posted: Sun Nov 19, 2006 3:39 pm Post subject: Front seats hard to slide |
For those who have their birds flying, how did you solve the front seats being so hard to slide when sitting in them?
I'm now at 30 hrs and have had them out twice to silicone lube them. They slide ok for a couple of flights, then get very hard to slide again.
Anybody found a permanent solution to ease the slide?
Grumpy
#40404, 30 hrs and counting
DO NOT ARCHIVE
gommone7(at)bellsouth.net Guest
Posted: Sun Nov 19, 2006 3:59 pm Post subject: Front seats hard to slide |
I wish Have that problem now.
Hugo # 40456 finish canopy
Date: 2006/11/19 Sun PM 06:38:52 EST
Subject: Front seats hard to slide
Grumpy
DO NOT ARCHIVE
flysrv10(at)gmail.com Guest
Posted: Mon Nov 20, 2006 5:26 am Post subject: Front seats hard to slide |
I put white grease on them. They seem to be getting better with 100+ hrs of use. Passenger seat still binds but, it also is getting better.
Rob Kermanj
On Nov 19, 2006, at 6:38 PM, GenGrumpy(at)aol.com (GenGrumpy(at)aol.com) wrote:
[quote] For those who have their birds flying, how did you solve the front seats being so hard to slide when sitting in them?
Grumpy
DO NOT ARCHIVE
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.kitlog.com">www.kitlog.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
| [b]
jesse(at)itecusa.org Guest
Posted: Mon Nov 20, 2006 6:18 am Post subject: Front seats hard to slide |
Grumpy,
Of the 6 seats I have installed and worked with, only one of them was hard to slide. I noticed that it was actually easier to slide with a person sitting in it than without, because you can get the leverage needed. Pushing back is easiest, because you can push with your feet. Pulling forward is harder, but you can grab the bar and pull, which makes it easier. Overall, I don’t think it is every seat. I don’t know if it has to do with the installation of the rails, the plastic slides on the bottom of the seat, or the rails being not-perfectly-straight to start with. Were your rails extremely hard to install? I have noticed that some are and some aren’t.
So, in answer to your question, I don’t know what to say except that not all seats are hard to slide, so you apparently just got lucky….twice. It has also been my experience that they get easier to slide with use, not harder. But, we can’t let our experience dictate truth, they just illustrate it, so saying the seats are hard to slide or easy to slide as truth isn’t accurate. There has to be some explanation why some slide easily and some hard. Have you talked to Van’s or Oregon Aero?
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GenGrumpy(at)aol.com
Sent: Sunday, November 19, 2006 6:39 PM
Grumpy
DO NOT ARCHIVE
| Quote: | | www.aeroelectric.com | 0123456789012345
-- Release Date: 11/20/2006 6:48 AM
11/20/2006 6:48 AM
Posted: Mon Nov 20, 2006 6:59 pm Post subject: Front seats hard to slide |
Jesse, I haven't talked to Van's yet, but intend to do so.
I was hoping someone had experienced similar problems and solved them already.
Mine slide ok for a while after lubing them up, then they go back to very hard to move again, even with me sitting in them. Pulling forward is obviously the hardest to do.
grumpy
In a message dated 11/20/2006 8:23:27 AM Central Standard Time, jesse(at)itecusa.org writes:
Grumpy,
Do not archive.
Jesse Saint
I-TEC, Inc.
http://www.itecusa.org/
W: 352-465-4545
C: 352-427-0285
Posted: Mon Nov 20, 2006 7:25 pm Post subject: Front seats hard to slide |
I just looked at N415EC today and the same seat that was hard to move
before still is. I thought it was loosening up, but it appears not to be.
Let me know what Van's says (although they probably won't offer much in
the way of an explanation). They might refer you to Oregon Aero. If they
consider the seat defective, then it might be RMA'able. They might just
say, "grease it and deal with it."
Jesse
| Quote: | Jesse, I haven't talked to Van's yet, but intend to do so.
already.
obviously
the hardest to do.
grumpy
Grumpy,
to
sitting
is
but
think
the
install? I
all
has also
But,
saying
There
Do not archive.
Jesse Saint
I-TEC, Inc.
W: 352-465-4545
C: 352-427-0285
Jesse Saint
I-TEC, Inc.
www.itecusa.org
rvreynolds(at)macs.net Guest
Posted: Wed Nov 22, 2006 4:02 am Post subject: Front seats hard to slide |
Have you checked to see if the lower rails are parallel?
Are the seat rails parallel?
Are they "in plane"? Check by running strings (dental floss) in the
form of an X from the front of one side to the back of the other (two
strings).
Richard Reynolds
On Nov 20, 2006, at 10:25 PM, Jesse Saint wrote:
to be.
much in
If they
just
Jesse
> already.
> to very
> obviously
> the hardest to do.
> grumpy
> Grumpy,
> was hard
> to
> sitting
> Pushing back
> is
> harder,
> but
> don’t
> think
> installation of
> the
> being
> hard to
> install? I
> that not
> all
> seats are hard to slide, so you apparently just got luckyâ
> €¦.twice. It
> has also
> harder.
> But,
> it, so
> saying
> accurate.
> There
> Have you
> Do not archive.
> Jesse Saint
> I-TEC, Inc.
> W: 352-465-4545
> C: 352-427-0285
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Posted: Wed Nov 22, 2006 4:50 am Post subject: Front seats hard to slide |
I have not, but I can't imagine a way to change them if they are not parallel because of the way they attach. I can imagine that even being 2mm out of square from the front to the back of the rails could make a big difference in how they slide, but with 750 nutplates (roughly) holding them in, I can't see a way to possibly change those 2mm.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
wvu(at)ameritel.net Guest
Posted: Wed Nov 22, 2006 8:02 am Post subject: Front seats hard to slide |
Perhaps some of those 750 screws are tighter than others causing a slight
warp in the rails, otherwise I think the only way is to shave some of the
white stuff off somehow ....
Anh
