dan(at)azshowersolutions. Guest
Posted: Wed Nov 22, 2006 5:45 am Post subject: From Steam to Glass |
I am at a crossroad in building my panel and was wondering if anyone here has actually made the switch to an all glass panel? I have an EFIS as well as an EIS (EMS), yet I still feel the need (want) to put the steam air speed &VSI next to it. If you have gone through this "weaning" process...how was it? Do you still feel the need for (a round) speed? <g>
Dan B, Mesa AZ
KF-IV 314DW
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Wed Nov 22, 2006 6:33 am Post subject: Re: From Steam to Glass |
Kind of depends on what you'll use the airplane for and what you find easier to stay on top of. I really have been in an IFR-capable Kitfox and for back-up to the Dynon the owner has a round-dial altimeter, airspeed, and an electric horizon. This combination is also pretty common in the RV-airplanes. About 30 years ago I worked for Lockheed on the L-1011 and we had customers order the vertical tape engine instruments who found that non-round displays were so counter-intuitive that they retrofitted round dials. The benefit of round dials is that with a glance they are easier to interpret. I'm flying VFR and personally (important word) like to have round dial displays of heading, airspeed, and altitude just because I find that I have a more intuitive knowledge of where things are. I don't want an artificial horizon, DG, etc. On the other hand, my boss likes the high-tech toys and has a RV-9 with a really bare-looking panel that just has a Dynon, Garmin 296, EIS , transponder/encoder, and com radio.
_________________ Remember that internet advice may only be worth what you pay. |
Ben-PA
Posted: Wed Nov 22, 2006 6:36 am Post subject: Re: From Steam to Glass |
Dan,
I installed an Horizon Sport HZ EFIS and don't miss the ASI at all. The only need you would have for one is if you plan to fly IMC.
Ben
25.19 KB |
643 Time(s) |
_________________ Sign up on the Kitfox Frappr Map:
http://www.frappr.com/kitfox
You can see where fellow Kitfoxers live and pictures of their planes. Be sure to post some pictures of you, your plane, or share the scenery of the Kitfox world. |
lcfitt(at)sbcglobal.net Guest
Posted: Wed Nov 22, 2006 8:29 am Post subject: From Steam to Glass |
Dan, I am of the steam gauge era, not necessarily by choice as that is all
there was when I was panel building. I have taken off a couple of times
with the pitot blocked, once due to a too quick preflight forgetting to
remove the "remove before flight" ribbon and another time thanks to a mud
dobber. It was a bit antsy for me, but that was just because I hadn't
landed without gauges before. The landings were fine as it isn't hard to
see feel and listen for the normal seat of the pants inputs. With GPS for
cruise and fuel management back-up, I don't find any issues with the glass
panel.
One thing, though, tests have found that a glance at a needle is more
readily understood than a look at a number. This is spoken from a
fundamental ignorance of what the displays look like. I would suspect that
there would be some sort of graphic display for the quick scan.
Lowell
