jean-paul.roy4(at)tlb.sym Guest
Posted: Sat Nov 11, 2006 5:19 am Post subject: LRI Probe location |
Good day listers, I'm actually building my wings (both at the same time since I have 2 tables).
As I am looking forward to install a LRI (Lift Reserve Indicator) on my 701, I wondered if it would be indicated to prepare ahead of time for the installation of the probe (cutting the opening for the probe and installing the vinyl tubing inside the wing before skinning).
Now my question; Where exactly do I cut the opening for the probe ? ie beside wich rib and how far from the leading edge ? How big of an opening ?
Thanks kindly for any infos.
Jean-Paul Roy
Angliers, Qc.
working on wing skeleton
p.mulwitz(at)worldnet.att Guest
Posted: Sat Nov 11, 2006 6:00 am Post subject: LRI Probe location |
Hi Jean-Paul,
I mounted mine in pretty much the same place as the pitot-static probe except on the other wing. I mounted both of them on "Inspection plates" to prevent damage while moving the wing around before final use.
I don't remember exactly where on the chord the probe was mounted. I think I remember some direction on this question on the LRI drawings.
Good luck,
Paul
XL fuselage
At 05:18 AM 11/11/2006, you wrote:
Quote: | Good day listers, I'm actually building my wings (both at the same time since I have 2 tables).
Jean-Paul Roy
Angliers, Qc.
Posted: Sat Nov 11, 2006 10:27 am Post subject: LRI Probe location |
Thanks Paul, that gives me a good idea. I was going to install them on ''plates'' as well.
J.P.
challgren(at)mac.com Guest
Posted: Sat Nov 25, 2006 8:41 am Post subject: LRI Probe location |
Jean-Paul:
I put my LRI in the left wing tip in line with the lightening holes. The inspection plate to be installed will allow access to both the LRI and the wing tip light.
The placement was suggested by the Owner of LRI. He indicated it could go any where there would not be disturbed ahead of it.
Stan
Jean-Paul Roy
Angliers, Qc.
