Low Fuel Alarm.
Goto page Previous  1, 2
Wingrider
PostPosted: Sat Nov 25, 2006 6:46 pm    Post subject: Re: Low Fuel Alarm. Reply with quote
[quote="Trainnut01(at)aol.com"]Rich
No. It only has one set of contacts. But if it was mounted high in the tank it would turn off when the fuel level rose above it. It could also be inverted to turn on when the fuel level reaches it. Not sure what that would be good for unless you wanted a full tank warning.
Carroll Jernigan
Lenoir City TN
Not a full tank warning but to shut off the transfer pump when the tank is full. I'm thinking of using a momentary switch to pull in a holding relay that energizers the transfer pump. When the tank is full the float switch opens breaking the circuit to the holding relay and shutting off the transfer pump.
Rich Whittington
Tullahoma, TN
Zenith 601HDS
Corvair 3 Liter 120HP
Page 2 of 2
