		Eric_Kallio
  Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
				 Posted: Sat Nov 25, 2006 7:34 am    Post subject: Wing leading edge questions |
				I am getting ready to start the leading edges of my wings and plunk down some more money for accessories. I intend on purchasing the Gretz 1000 heated pitot, the Duckworks HID landing lights, and the AFS AOA. After reviewing the archives several of you had said that you were putting the light and the AOA on the last bay. Any feedback on how that worked out as far as space and ease of maintenace for the future? I was also looking at simply closing the stall horn holes and not installing it, as others have done. Does any body flying think that is something I should still install? Finally any other tips or gotchas out there. I have been all over Tim's and Deems's sites...pretty much live on those, and Mike Howe's also. Thanks for your feedback.
 Eric Kallio
 #40518 SB wings
		Deems Davis
				 Posted: Sat Nov 25, 2006 8:08 am    Post subject: Wing leading edge questions |
				Eric, FWIW If I were doing it over I would move the Gretz mount 1
 bay/rib closer to an access panel/hole than where I mounted it.
 Deems Davis # 406
 Finishing - ( A Misnomer ! )
 http://deemsrv10.com/
 Eric_Kallio wrote:
 Eric Kallio
 #40518 SB wings
 http://forums.matronics.com/viewtopic.php?p=76864#76864
		jchang10
				 Posted: Sun Nov 26, 2006 5:58 am    Post subject: Wing leading edge questions |
				Hi Eric...
 I finished my leading edges not that long ago. Instead of ordering/installing
 any of the accessories, I left the outer rib clecoed, so I could order and
 install accessories some time later.
 With the stall warning gizmo, I had not even considered not installing it, since
 it's such a useful thing to have. Are people just forgoing the mechnical stall
 indicator, for the AOA, or replacing it with something better?
 Jae
  _________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
		John Ackerman
  Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
				 Posted: Sun Nov 26, 2006 7:28 am    Post subject: Wing leading edge questions |
				Jae, I decided to forego the mechanical stall warning.
 One still has to fill the little stall warning locator holes in both
 leading edges.
 I don't know of a real good way, but filled mine with West System
 epoxy made really thick with their high density filler.
 If you do that, you may want to wax and tape the skin to make cleanup
 easier, but not right at the holes...
 John Ackerman
 On Nov 26, 2006, at 6:57 AM, Jae Chang wrote:
  matronics_rv10(at)jline.com>
  Hi Eric...
  installing
  order and
  mechnical stall
  Jae
		noel(at)blueskyaviation.n Guest
				 Posted: Sun Nov 26, 2006 11:13 am    Post subject: Wing leading edge questions |
				intresting thead. this gets a little long and I am not using an e-mail with
 spelling so this is witen in what I call ACS (artisic crative spelling)
 It has been quite a long time since I finished 325HP acualy almost 4
 aircraft ago (or was it 5?).  I am not a really big proponet of AOA units I
 have installed two different units on three different aircraft with limited
 end usfullness, by that I mean once you have goten all the nice lights and
 or dials to hit red as soon as the nose falls over you prity well have the
 aircarft under control and know were you are.  However, The RV-10 with its
 large CG envlope, Large paylode weight, Large theator of operations (very
 much unlike a KitFox)I noticed that an AOA unit would be NICE, I aualy had
 the stock stall warning set up so when it squaked I knew that it was time
 to add some speed and power.  Solo, or with two people I rarly ever had the
 stall warning go off but with pepole in the  back it was usual.
 Anyway
 I thought that A little more fuel would be nice.
 the HID ligts in the leading edges are almost a must.
 The Gretzs pitot tube with the power saving, pitot tube saving, good
 fealling LEDs to tell you it is On and Hot or cold is great (it gose aft of
 the spar not in the leding edge.
 My thoughts, your milage will (and should) vary.
 Noel
 Original Message:
 Date: Sun, 26 Nov 2006 08:27:35 -0700
 Subject: Re: Wing leading edge questions
 leading edges.
 John Ackerman
  Hi Eric...
  installing
  order and
  mechnical stall
  Jae
		rvbuilder(at)sausen.net Guest
				 Posted: Sun Nov 26, 2006 1:08 pm    Post subject: Wing leading edge questions |
				Hmm, I think I just put rivets in mine.
 Michael
				 Posted: Mon Nov 27, 2006 10:16 am    Post subject: Wing leading edge questions |
				The AoA's are generally much better at showing stall information (when
 was the last time you saw a jet with a stall tab). Because I am going
 with the AoA Pro, I for one didn't see the point of putting the old
 mechanical tab out there.
 Michael Sausen
 -10 #352 Fuselage
		n223rv(at)wolflakeairport Guest
				 Posted: Tue Nov 28, 2006 7:43 pm    Post subject: Wing leading edge questions |
				Why not dimple and install a rivet to nowhere???
